EmbDev.net
Forum: FPGA, VHDL & Verilog Puls generator
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Gerhard K. (gerhardkreuzer)
Rate this post
useful
not useful
I have a multi stage process and each step need some time. I want to
create some sequencer which is able to generate positive edges at
certain intervals and at the end /beginning of the cycle reset this
signals.
Not that complicated, I thought, but I fail totally.
If I do it in hardware:
Counter, 11 bit wide, increments at each clock cycle, some comparators,
comparing the actual count against a constant and if equal, set the
output for one clock cycle, ==> get my positive edge.
If I do it in Verilog:
always @ (negedge clk)
    begin
      if ( reset )
        reg_step = 3'd0;
        else
        if ( reg_step < 8'd240 || reg_sel != 3'd7 ) reg_step <= ( reg_step == 8'd240 ) ? 8'd0 : reg_step + 8'd1;
    end
  // Generate stage clocks and incremet wave index
  always @ (posedge clk)
    if ( reset )
      begin
        reg_sel      = 3'd7;
        reg_accu_clk  =    0;
        reg_lut_clk    =    0;
        reg_mix_clk    =    0;
      end
    else
      case ( reg_step )
        8'd2:
23
          begin
24
            reg_sel      = reg_sel + 3'd1;
25
            reg_accu_clk  = 0;
26
            reg_lut_clk    = 0;
27
            reg_mix_clk    = 0;
28
          end
29
        8'd10:
30
          reg_accu_clk <= 1;
31
        8'd20:
32
          reg_lut_clk   <= 1;
33
        8'd200:                          // 100 .. fails, 150 works, 150-20 = 130 * 2.5ns = 325 ns for the 12 bit sin_lut
34
          reg_mix_clk  <= 1;
35
      endcase
36
37
38
    begin
39
      if ( reg_step == 8'd2 )
40
        begin
41
42
          reg_accu_clk  = 0;
43
          reg_lut_clk    = 0;
44
          reg_mix_clk    = 0;
45
        end
46
47
      if ( reg_step == 8'd10 )  reg_accu_clk  <= 1;
48
49
      if ( reg_step == 8'd20 )  reg_lut_clk  <= 1;
50
51
      if ( reg_step == 8'd200 ) reg_mix_clk  <= 1;
52
    end
I tried two options.
In the simulation, everything is fine.
In real nothing works.
I use the RTL viewer and it was funny to see what the compiler thought
that I want to do.
Can some body help me and tell me, how I can implement such a simple
sequencer in Verilog or should I better start drawing a schematic using
primitives in my Quartus Prime?
What is the target:
At negedge, the counter advances/resets. At the posedge (the counter
value is stable I guess ...) the counter value is compared with some
constants and if there is one found to be equal, the output is 1, 0
otherwise.
I get posedges at certain poits in time (relative to the start),
synchronized with the posedge of my clock.
Sorry about code formatting ..
With best regards
Gerhard
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
