EmbDev.net
Forum: FPGA, VHDL & Verilog Verilog JK - help pls
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Daniel C. (Company: NON) (r_daniel)
Rate this post
useful
not useful
What is the problem that signal is not defined? How do you define an
initial value for the output?
module JK_Latch(Q, Qbar, J, K, Enable);
input J, K, Enable;
output Q, Qbar;
wire J_E, K_E;
and(J_E, J, Enable, Qbar);
and(K_E, K, Enable, Q);
nor(Q, Qbar, K_E);
nor(Qbar, Q, J_E);
endmodule
module TB_JK_Latch();
wire q, qbar;
reg j, k, e;
JK_Latch JK0(q, qbar, j, k, e);
initial
23
begin
24
    $monitor($time," j =%b, k=%b, q=%b, qbar=%b, enable=%b\n",j,k,q,qbar,e);
25
26
    j=1; k=0; e=1;
27
28
    #5 j=0; k=1;
29
    #5 j=0; k=0;
30
    #5 j=1; k=0;
31
    #5 j=1; k=1;
32
33
    #5 j=1; k=1; e=0;
34
    #5 j=0; k=1;
35
    #5 j=0; k=0;
36
    #5 j=1; k=0;
37
    #5 j=1; k=1;
38
end
39
endmodule
von Vancouver (vancouver)
Rate this post
useful
not useful
There is a permanent mutual dependency betwenn Q and Qbar that can not
be overridden by the input signals. So, since Q and Qbar are undefined
in the beginning, they remain undefined forever in the simulation. In
real hardware, they would fall into a random state which is mainly
determined by physical parameters of the technology.
By using the initial statement. But only in the simulation. initial will
not synthesize. Or you could extend your design by a reset signal that
forces Q or Qbar to a logic level.
I hope you are doing this just for learning and playing around in the
simulator. In real hardware designs, you would avoid latches as far as
possible. And if you really would need one, you would use a D-latch. And
if you really really would need a JK-latch, you would never use a
self-build combinatorial feedback latch but take a primitive from a
vendor library or emulate it using a D-latch. Actually, since more than
30 years, JK FFs and latches are used for stressing students, so unless
you are a student, you should forget about JK type memories.
And please stop using gate primitives in your design. Use boolean
expressions instead:
nor(Qbar, Q, J_E) is equivalent to
assign Qbar = ~(Q | J_E)
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
