EmbDev.net
Forum: Analog Circuits Looking for recommendation for full-bridge IC
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Wolfgang (pollvx)
Rate this post
useful
not useful
Good morning folks,
my problem in short:
I'm looking for the right full-bridge IC (single or double). I would
like to be able to both power it and control it with 24V and the output
voltage should also be +-24V. The load is only around 40mA.
Does anyone have a good suggestion?
Detailed explanation:
At work I'm working on a self-made model of an electric motor. Right now
it's built with a rotor with permanent magnets, which is turned by 6
individual coils, which I removed from old relais. The coils are
controlled with 24V by a PLC.
To improve the system I would like to be able to change the polarity of
the coils while running the motor. With the normal digital outputs of
the PLC I'm limited to only one polarity and analogue outputs provide
only +-10V.
After a day of research and puzzling about MOSFETs and full-bridges I
let go of the idea of building my own bridges, because I'm lacking the
know-how at this point. That's why I'm looking for fitting full-bridge
ICs to individually control the coils. The requirements would be that I
can both power and control the chip with 24V via the PLC and that the
output voltage is also 24V, which is the nominal value for the coils.
Greetings
Wolfgang
von Harald A. (embedded)
Rate this post
useful
not useful
Maybe the old fashioned L272 (max. 28V could be a bit tough) or a more
modern DRV8816
Edit: Sorry, missed your bipolar supply requirements.
: Edited by User
Rate this post
useful
not useful
Thank you for the suggestions!
I looked into the L272 and it raised some questions for me:
In the datasheet, there's an example for how to drive a DC motor. What
is the meaning of that new Value Vs1? Is that just supposed to set the
voltage difference between the output pins? If so, should that be ground
if I want to run the coils with 24V? And if so, could those inputs be
shorted to ground if I dont wish to modulate the voltage? [page 5,
Figure 9]
Another issue is power dissipation. With a supply voltage of 24V I get
200mW of power from just the circuitry and having a 40mA load adds
another 600mW. 800mW is within bounds, but should I perhaps take extra
care to glue a piece of metal on top to better dissipate heat?
Last is concerning switching the direction. Could too sudden of a switch
result in a potential of 48V for a moment because of the impedance of
the coil?
I don't quite understand what you mean?
: Edited by User
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
