EmbDev.net
Forum: µC & Digital Electronics Detecting the SD Card using the USB2244 chip on PC
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Rene (mmrei)
Rate this post
useful
not useful
I am trying to use the USB2244 chip to access a SD card directly through
a USB connector on my PCB board. I built the circuitry as shown in the
image on a bread board. The SD card does not get detected on the PC.
Only the driver is detected on the PC which is displayed as a greyed
symbol of USB drive on the laptop.
It would be great if somebody could help me with the mistake. I would
really appreciate it.
Best regards!
Note: I am aware that the labels MISO/MOSI are incorrect and misleading
as the connection to the SD card is not a SPI connection. However, the
circuitry should work according to my understanding.
von Rene (mmrei)
Rate this post
useful
not useful
Here is some addition:
I am using USB to power up the USB2244. This line is connected to an LDO
that steps down the voltage to 3.3V which is connected to all the input
pins of the USB chip 6,14,22 and 36.
I detected the following problem: There is no 1.8V observed at pin 13
and 34 which should normally be the case (1µF capacitors are connected
as according to the data sheet).
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Rene wrote:
> the circuitry should work according to my understanding.
Even without any clock?
What voltage do you have at the reset pin? DS tells, that it must be at
least 2V to recognize a "high".
von Niklas G. (erlkoenig)
Rate this post
useful
not useful
Is the SD Card powered by the LM3480 as well? 100mA is way too little
for an SD card.
von Jim M. (turboj)
Rate this post
useful
not useful
That chip has a 24 MHz crystal in the datasheet that I am missing on
your schematic.
von Rene (mmrei)
Rate this post
useful
not useful
> on
> your schematic.
You are absolutely right. In my last test it was missing. However,
before I tried the same with a crystal connected and still it did not
work.
> little
> for an SD card.
You are also absolutely right. I tried a different LDO (LM3940 with 1A
max. output) and still it does not work. Still I do not get the desired
1.8V at pins 13 and 34 and do not get access to the SD card.
See image below.
: Edited by User
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
