EmbDev.net
Forum: µC & Digital Electronics AVR Arithmatic
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Kishor S. (sonikishor)
Rate this post
useful
not useful
Found AVR code for 32 bit square root under AVR Arithmatic, topic 7.1
The code is look like assembly language but, some instruction is unknown
like "role r24"
and some jump lable not found any where in the code (like brcs 2f, brcs
3f etc)
can anybody make necessary correction ?
The code file is attached.
von Alexander S. (alesi)
Rate this post
useful
not useful
the code in your attachment sqrt32_Fb.txt  looks different compared to
the one at
https://www.mikrocontroller.net/articles/AVR_Arithmetik#Wurzel
;  Fast and short 32 bits AVR sqrt routine, avr-gcc ABI compliant
;  R25:R24 = SQRT (R25:R24:R23:R22)
;  rounded down to integer
;     Destroys R26,R27,R22,R23,R18,R19
;  Cycles incl call & ret = 260-300
;  Stack incl call = 2-3
.text
.global sqrt32_floor
.type sqrt32_floor, @function
sqrt32_floor:
    ldi   R19, 0xc0
    clr   R18               ; rotation mask in R19:R18
    ldi   R27, 0x40
    sub   R26, R26          ; developing sqrt in R27:R26, C=0
1:  brcs  2f                ; C --> Bit is always 1
    cp    R24, R26
    cpc   R25, R27          ; Does test value fit?
    brcs  3f                ; C --> nope, bit is 0
2:  sub   R24, R26
    sbc   R25, R27          ; Adjust argument for next bit
23
    or    R26, R18
24
    or    R27, R19          ; Set bit to 1
25
3:  lsr   R19
26
    ror   R18               ; Shift right mask, C --> end loop
27
    eor   R27, R19
28
    eor   R26, R18          ; Shift right only test bit in result
29
    rol   R22               ; Bit 0 only set if end of loop
30
    rol   R23
31
    rol   R24
32
    rol   R25               ; Shift left remaining argument (C used at 1:)
33
    sbrs  R22, 0            ; Skip if 15 bits developed
34
    rjmp  1b                ; Develop 15 bits of the sqrt
35
36
    brcs  4f                ; C--> Last bits always 1
37
    lsl   R23               ; Need bit 7 in C for cpc
38
    cpc   R26, R24
39
    cpc   R27, R25          ; After this C is last bit
40
41
4:  adc   R26, R19          ; Round up if C (R19=0)
42
    mov   R25, R27          ; return in R25:R24 as for avr-gcc ABI
43
    mov   R24, R26
44
    ret
45
46
.size sqrt32_floor, .-sqrt32_floor
Rate this post
useful
not useful
Ok, thanks
but where is jump locations ?
see line 16, brcs 2f
see line 20, brcs 3f
assembler shows an error on this instructions
von C-hater (c-hater)
Rate this post
useful
not useful
Kishor S. wrote:
> Ok, thanks
These notations are from C inline assembly language, which is very
different from an directly usable assembly language.
The understanding of this crude notation is simple: the number describes
the relative branch distance (in instruction words), the trailing
character denotes, if it is a forward branch or a backward branch. Of
course the 'f' stands for 'forward'.
So your task is: count instruction words up from the branch instruction
and insert a label at found point in source code. Finally replace the
branch target parameter by the name of this label.
von Norbert (der_norbert)
Rate this post
useful
not useful
That's so wrong, even the opposite wouldn't be any better!
1f or 1b (or any other number) simply points to a numbered label in
forward or backward direction.
Rate this post
useful
not useful
Thanks a lot,
I learn this new thing, after 25 yrs. of coding practice..........
Rate this post
useful
not useful
after so many efforts, I can't be able to assemble this code in assembly
language.
I cant interpret this keyword
"brcs 2f"
"brcs 2b"
and
sbrs R22,0 (at line 33)
can anyone explain ?
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
