EmbDev.net
Forum: FPGA, VHDL & Verilog Express a given function using a PLD.
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Xideden (xideden)
Rate this post
useful
not useful
Hi! I have an assignment, where we have to express a function f, using a
PLDcell.
The PLDcell is defined as such:
y <= i xor ((x(5) and x(4) and x(3)) or (x(2) and x(1) and x(0)));
How do I go about doing this? go from my function to expressing it using
a single PLDcell? (I am not trying to find the solution, I am trying to
learn/understand) I am stuck at the fact that the minimized function
only has 3 or-terms and 3 different variables, meanwhile the defined
PLDcell has 7 inputs..
I tried doing a truth table for each, the function and the PLDcell, and
try to find where it matches? but it doesn't seem like the correct way
because the PLDcell has 2^7 possible combinations. Happy to read stuff,
if someone can point me in the right direction :)
von Rick D. (rickdangerus)
Rate this post
useful
not useful
I would convert the truth table into an K-map:
https://en.wikipedia.org/wiki/Karnaugh_map
von Kay-Uwe R. (dfias)
Rate this post
useful
not useful
Karnaugh is not usuable for your expression. There are 7 input signals
(x(0) ... x(5) + i) - by far too much for Karnaugh.
If you want to transform the expression into a PLD representation (NOT -
AND - OR stages) you should look for 'De Morgan's rules'. Also, XOR must
be translated into a NOT/AND/OR expression first.
It is a lot of paper work to bring it into the right format. I would
suggest to do this first for an easier expression than this one.
However, you can ignore the science behind and just use the expression
as is. The PLD compiler will do the work for you.
von Foobar (asdfasd)
Rate this post
useful
not useful
Then you made a mistake in the minimization.  None of the 7 variables
(i, x(0) to x(5)) can be eliminated.
Rate this post
useful
not useful
This is how the PLD logic interprets your formula:
y =
   (    x(0) and     x(1) and x(2) and not i)
or (not x(0) and not x(3)          and     i)
or (not x(0) and not x(4)          and     i)
or (not x(0) and not x(5)          and     i)
or (not x(1) and not x(3)          and     i)
or (not x(1) and not x(4)          and     i)
or (not x(1) and not x(5)          and     i)
or (not x(2) and not x(3)          and     i)
or (not x(2) and not x(4)          and     i)
or (not x(2) and not x(5)          and     i)
or (    x(3) and     x(4) and x(5) and not i)
It is indeed very complex to come here, but you can try it by hand and
check your result using an online calculator, e.g.
https://www.dcode.fr/boolean-expressions-calculator
(replace x(0) with a, x(1) with b a.s.o.)
von Tau J. (Company: group) (fasgya30)
Rate this post
useful
not useful
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
