EmbDev.net
Forum: FPGA, VHDL & Verilog modulo 100 VHDL
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Matlabo (matlabo)
Rate this post
useful
not useful
Hi !
 I am trying to implement a modulo 100 counter.
I encounter some issues with the Bin2BCD part.
The thing is that the incrementation of the tens digit is done two by
two, like it goes from 0 to 2 then to 4 etc... and I don't understand
why ?
Any help is deeply appreciated.
P.S: In the attachment I also added the code of the other parts in the
Codes.rar file.
P.S2: I am running the simulation on ISE and it takes too much time. Any
tips in order to reduce the simulation time ?
: Edited by User
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Do you have a working test bench for that design?
I made one and it does not schow anything making any kind of sense to
me...
You must speed up your clock enables:
architecture Behavioral of diviseur is
    elsif rising_edge (Clk) then
--      if qt=50000000 then
      if qt=4999 then
        enlh <='1' ;
--      if qt100 = 500000 then
      if qt100 = 49 then
        en100h <= '1';
  end process;
end Behavioral;
> 50000000 ... 500000
The usual "off-by-one" problem: with a compare value of 500000 you count
500001 clock cycles. Considering that it is very crude to handle the
ones and hundreds by two separate prescalers:
      if qt=50000000 then
        enlh <='1' ;
        qt := 0;
      else enlh <= '0' ;
        qt := qt+1 ;
      end if;
        en100h <= '1';
        qt100 := 0;
      else
        qt100 := qt100 + 1;
      end if;
    end if;
Why don't you handle the digits in a way every "usual" counter does:
when the ones reach 9, then with the next clock the tens are
incremented and the ones are reset to 0. When the tens reach 9 then
with the next clock the hundreds are incremented and the tens are
reset. And so on...
Have a look at the code of the stop watch there:
http://www.lothar-miller.de/s9y/archives/88-VHDL-vs.-Verilog-am-Beispiel-einer-Stoppuhr.html
Its German, try Google translator.
BTW:
use IEEE. numeric_STD.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
Never ever both of them together! The numeric_std has all you need.
With both of them you will now and then encounter weird error messages
due to double definitions of some data types.
: Edited by Moderator
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
