EmbDev.net
Forum: FPGA, VHDL & Verilog UART, FPGA VHDL
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Lukáš K. (Company: Stu) (kalajkak)
Rate this post
useful
not useful
Hello, I have a problem and I'm asking for help. I want to implement
this code on the nexys 50 a7 ​​board. The idea of ​​how the board should
work is that if I enter an eight-bit number on the switch, the segment
display will show me what works. But when you click the button where the
rd_uart variable is, nothing happens. it should be downloaded to the PC
through putty. When typing on the keyboard, it should be displayed on
the segment board, but only the tx light on the board flashes, but the
rx vbc led does not flash, do you know where the problem is? I am
sending a link to gifthub. :
https://github.com/KrizLuk0/digital-electronics1/tree/main/UART_FPGA/project_U25
von Rick D. (rickdangerus)
Rate this post
useful
not useful
Divide your problem and debug:
- build an UART test transmitter to transmit a known pattern every e.g.
100 ms
- if the tx works connect a counter/fsm to the transmitter and send a
more complex pattern (e.g. 1-2-3-4-...)
- if the counter/fsm output is the same as you expect it, connect your
keyboard to the fsm...
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Lukáš K. wrote:
> nothing happens
Your task sounds reasonably simple. Your solution looks incredible
complicated. Why the heck do you need a fifo here? All interaction ist
done by humans, so it is really sllllllooooowwwwwww regarding the 50MHz
FPGA.
What switch?
> the segment display will show me what works.
In what manner?
Which one?
> the button where the rd_uart variable is
> it
What ist "it"?
> should be downloaded to the PC through putty.
Putty is a software running on the PC. So maybe it should be received
and visualized by Putty.
What keayboard?
> it should be displayed on the segment board
In what manner?
So you want do display 2 informations on the 7seg display: the switches
and the RX value? So: what has priority on the 7seg display?
I understand your description this way:
- from FPGA to PC
1. you enter some binary code on the dip siwtches
2. this code is displayed on the 7seg display (in hex? or decimal?)
3. when you press a button the code is sent via async serial (and
afterwards somehow displayed on the PC Screen)
- from PC to FPGA
4. when you hit a key on the PC keyboard, some (ASCII?) code is sent via
serial
5. the FPGA receives the data and shows it in some manner on the 7seg
display
Is that correct?
Rate this post
useful
not useful
Yes, exactly as you describe, but the implementation does not work
Rate this post
useful
not useful
Split up the whole job in a TX and a RX section like Rick D. already
advised.
What about simulation? The simulator is the debugger for your VHDL
design. Do you have a test bench? What does it look like?
Rate this post
useful
not useful
I'm not sure if I understand correctly. Are you saying that I should
separate the FIFO because it's unnecessary? Then, can I connect the
output from RX (DOUT) directly to the segment display? And similarly,
connect the switches directly to TX?
Rate this post
useful
not useful
Lukáš K. wrote:
> Are you saying...
Correct, thats would be my direction. Why using a fifo when nothing is
stopping you from writing the display whenever you want. An adjustment
of a new value takes longer for sure than sending the last value.
But as said: simulate your design before going on hardware.
Have a look at my RS232 implementation. Think about it and why it needs
much less lines of code than yours:
http://www.lothar-miller.de/s9y/categories/42-RS232
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
