EmbDev.net
Forum: µC & Digital Electronics Can't understand instructions for Waveshare LCD PWM control
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Codierer (weichware)
Rate this post
useful
not useful
Hi, I have a Waveshare LCD whose brightness I want to control by PWM.
From my Raspberry PI, it has a dedicated PWM GPIO Port (the 12th port,
GPIO 18:
https://www.raspberrypi-spy.co.uk/2012/06/simple-guide-to-the-rpi-gpio-header-and-pins/).
(Edit: The LCD has its own power supply and is (till now) connected to
the Raspberry only by HDMI. It works so far like any normal monitor.)
The instructions for the PWM control look pretty simple:
https://www.waveshare.com/wiki/15.6inch_HDMI_LCD#accordion4.
The instruction there tells to remove a triode (OK) and use the GPIO 18
port of my Raspberry. There, I don't get how that should work (I've only
basic electrical knowledge). I've basically a 2nd electric circuit which
overlaps with that of the LCD -- how should that work? Do I solder, like
described, the lower pin of the LCD to my GPIO 18 port?
Do I have then to solder the upper pin of the LCD to a GND port of my
Raspberry? So that an electric circuit gets closed? Or is that
superfluous?
How does that work?
: Edited by User
von Matthias S. (Company: matzetronics) (mschoeldgen)
Rate this post
useful
not useful
Once you've removed the triode there's no more overlap - thats the
reason for the removal. The rest of the backlight driver ist still on
the display but now controlled through the PWM of the RPi.
von Stefan F. (Guest)
Rate this post
useful
not useful
You shall connect the pin that the arrow points to with GPIO18 of your
Raspberry Pi, using a piece of wire.
Only you know what you have. Can't you show photos of that?
Rate this post
useful
not useful
> Raspberry?
GND conection should be already be present by the HDMI cable.
Rate this post
useful
not useful
Of course the GND of both boards must be connected together, otherwise
it cannot work. But that is not related to the modification you want to
do.
First get the display working basically, then modify it. Otherwise you
cannot know which step failed.
Rate this post
useful
not useful
Thanks for the answers, I edited my question and hope that it clears
things up.
Rate this post
useful
not useful
I'm still confused, I think my problem was misunderstood because my
question was unclear, so I edited the original question.
Let me further explain it, by uploading the image from the linked
website, about the LCD instructions.
The instructions above the image are:
"Remove the triode shown in the figure below, and solder the PWM pin on
the pad indicated by the arrow on the right."
The LCD is (without that soldering stuff) only connected via an HDMI
cable to the Raspberry and works flawlessly (it has it's own power
supply).
I'm still unsure if it's enough to solder the GPIO 18 pin of the
Raspberry to only one pin on the Waveshare LCD, and how that works?
Rate this post
useful
not useful
Its not only one pin from the RPi you're connecting to the pad, there's
also a HDMI connection from the RPi to the display. It provides the
necessary grounding also for the PWM signal from the RPi to the LCD
Board.
Its true that only one wire from the RPi to the indicated pad would not
suffice, but the grounding's there by HDMI.
Rate this post
useful
not useful
> Board.
Nice, thanks for the explanation. That clears things up, always thought
of the HDMI connection as something completely different, because it's a
fixed standalone standard, not directly connected to the Raspberry Pi.
But your explanation makes sense.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
