EmbDev.net
Forum: FPGA, VHDL & Verilog VGA controller problem.
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von JUNG Z. (Company: student) (dolemy)
Rate this post
useful
not useful
Hi. I need your help.
I'm trying to make vga_sync_controller which spec are 640x480/60hz.
I coded vga_sync.v by referrening FPGA PROTOTYPING BY VERILOG EXAMPLES
BOOK
I don't know why my code did not working properly, when I programmed
into my
FPGA board.
Here is my code & my sync timing simulation.
is there incorrect in my code?
// I programmed vga_test.v to my fpga board. //
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Does that timing fit to the VGA spec?
- https://www.epanorama.net/documents/pc/vga_timing.html
What should it do and what does it instead?
> when I programmed into my FPGA board.
Did you check the signals with an scope? Do they look liee the
simulation?
Rate this post
useful
not useful
1.
YES. as far as I know, I followed the timing spec for 640 x 480 / 60hz
but is it okay starting from display region?
my first region is display, then the back porch region, sync region,
front porch region are followed as sequential
below is my timing
h_sync
                       l_____l                             l_____l
<----display----><back><sync><front><----display----><back><sync><front>
2.
I just want to make a vga_sync. then, I want to combine this with my
pixel_generator module to output vga.
3.
Did you say about signal tap?
I didn't check it, thank you. I'll check it out right now
Rate this post
useful
not useful
Doesn't matter. All the monitor needs to recognize the VGA are the sync
signals. When yuo start the didplay rrgion at ghe wrong positions, then
simply the picturs on ghe screen is shifted a few pixels.
No, I meant a real life scope to measure the signals on their way to the
monitor. On those wires to yhe monitor the signals must appear with
correct timing and adequate levels.
von DSGV-Violator (Guest)
Rate this post
useful
not useful
Sometimes the on-screen display (OSD) of the connected monitor shows
useful information such as "Frequency not supported".
Therefore, before switching on the FPGA board, activate the status
submenu on your monitor and check whether there are any messages.
Sometimes the reversed polarity of V-sync can be a problem. The most
common mistake is an incorrect pin assignment and therefore no VGA
signal at all on the board's VGA connector.
vsync and hsync can be low enough to be checked with a modern multimeter
frequency measurement function. You can try this if you don't have an
oscilloscope handy.
Summary: Test your hardware before rewriting your software.
Rate this post
useful
not useful
2.
  I don't have any equipment to moniter real life scope. so, it is
  impossible.
Rate this post
useful
not useful
Change that.
When you don't know whether there are the
signals at the pins you want them, and whether they have the correct
levels and timings, then you do the job not in a way a real life
engineer would do it.
Its "fiddling and fumbling" instead of engineering".
With a scope.
: Edited by Moderator
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
