EmbDev.net
Forum: FPGA, VHDL & Verilog Error that i can't fix T.T
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Marco (pastaman71)
Rate this post
useful
not useful
Goodmorning my dear friends, it's me again. I started to code the PI
controller for my project to calculate the error between the PWM and the
motor's encoder and the GHDL gives me an error that i can't fix( or
better, i have no idea of how should i fix it). I'll attach the code and
put the error down here:
PI.vhd:30:30: no function declarations for operator "-"
PI.vhd:36:72: no function declarations for operator "*"
what that means? what i did wrong?
thanks a lot in advantage <3
von Rick D. (rickdangerus)
Rate this post
useful
not useful
Marco wrote:
> what i did wrong?
** Error: pl.vhd(30): Type error resolving infix expression "-" as type ieee.NUMERIC_STD.SIGNED.
Your types didn't match:
    error  <= to_integer(ref) - to_integer(feed);
    signed <= integer         - integer;
See the defined functions in numeric_std:
https://tams-www.informatik.uni-hamburg.de/vhdl/doc/faq/FAQ1.html#4.8.1
Rate this post
useful
not useful
If you change the code to
  process(reference_signal, encoder_signal)is
  begin
    -- Calcolo dell'errore tra velocità di riferimento e velocità effettiva
    error <= ref - to_integer(feed);
    -- Calcolo del termine integrativo
    integral_term <= integral_term + error;
    -- Calcolo del segnale di controllo
    pwm_output <= resize( encoder_signal + natural(Kp) * error + natural(Ki) * integral_term, pwm_output'length); -- è l'equivalenente di (7 downto 0) ma più skillato
  end process;
It will compile, but you need to check with a testbench if it will work.
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
BTW: you don't need no process here. These are simply 3 concurrent
statements.
Rate this post
useful
not useful
First o all, I want to thanks everyone for the answers, but i have
another question about this. If i don't need a process here, where do i
need a process? It's only where there are more statements or what?
Thank you.
P.S. i will post more as  update about the work
Rate this post
useful
not useful
IT COMPILES!!! but why?
Rate this post
useful
not useful
Marco wrote:
> If i don't need a process here, where do i need a process?
You don't need the process here because inside it are only 3 statements
which are calculated without any relation to each other.
Or in other words: a concurrent statement has an implicit process with
an implicit sensitivity list.
This concurrent statement here:
a <= b + c;
Is the very same like that chatty process:
process (b,c) is
begin
  a <= b + c;
end process;
Hint: look as said for the defined functions of the operators.
E.g. for the - operator there is no overloaded functions for
integer-integer with a signed as a result. This would work also:
error  <= to_signed(to_integer(ref) - to_integer(feed)),8);
: Edited by Moderator
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
