EmbDev.net
Forum: Analog Circuits speaker 4ohm 8 ohm maken?
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Erin (Company: avaq) (avaqsemi)
Rate this post
useful
not useful
Hi
I have 4 pioneer300 watt car speakers that I want to use on a regular
(240 volt) surround amplifier instead of a car radio.
But on that amplifier it says on a bright red sticker: speakers NOT LESS
THAN 8ohm.
Is there a trick to make a 4 ohm speaker 8 ohm?
By putting something in between like a coil or something like that?
I've heard about it but never had to look into it.
In a box, these speakers have a great sound, which is why I want to use
them
: Moved by Moderator
von Peter D. (peda)
Rate this post
useful
not useful
Simple put two 4Ω speaker in series.
von Gunnar F. (gufi36)
Rate this post
useful
not useful
or to use 2:1 transformer
von Stefan F. (Guest)
Rate this post
useful
not useful
But that redudes the power by 50% and has an effect on the sound
quality.
Anyway: this is better than having no sound at all.
von Michael B. (laberkopp)
Rate this post
useful
not useful
> quality.
Not if the 8 ohms only amplifier has 600W per channel, than the voltage
is sufficiently high to drive 2 speakers in series.
But considering 300W Pioneer, these are for sure speakers that can only
handle 30Wrms maximum. So even a poor audio amplifier will have enough
driving capabilty.
Rate this post
useful
not useful
Yes, it's surely worth a try.
von Εrnst B. (ernst)
Rate this post
useful
not useful
Checking Pioneer Speakers advertised with 300W randomly:
Might even be 40 Watts.
https://www.pioneer-car.eu/de/de/products/ts-g1730f
>> ... mit einer Nennbelastbarkeit von 40 Watt ist maximal mit bis zu 300 Watt
belastbar ...
He has a surround amp, so he probably wants to use 4 channels for his 4
speakers. If stereo is enough, then yes, that's what I'd try as well.
von Joachim B. (jar)
Rate this post
useful
not useful
Erin schrieb:
> I want
i want often so much, but never get it all. Life can be hard sometimes.
Better you want more easy thinks.
: Edited by User
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
