EmbDev.net
Forum: µC & Digital Electronics "Problem Reading Temperature from DHT11 Sensor via RS485 Between Raspberry Pi 4 and Raspberry Pi Pic
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Rıdvan Ç. (rdvan)
Rate this post
useful
not useful
I want to read the temperature data from the DHT11 sensor connected to
the Pico using RS485 between Raspberry Pi 4 and Raspberry Pi Pico. I use
the following code for this, but when I use it like this, I can send
data from Raspberry Pi without any problems. However, when I send data
from Raspberry Pi Pico, if I assume the temperature is 25, sometimes I
can read this value from Raspberry Pi and sometimes I can't. I tried to
adjust the correct time with Time.sleep() but I couldn't succeed. How
can I solve this?
Raspberry Pi Code
import serial
import time
RS485 = serial.Serial('/dev/serial0', baudrate=9600, timeout=1)
def send_data(data):
    ser = serial.Serial('/dev/serial0', baudrate=9600, timeout=1)
    ser.write(data.encode())
    print("data sent")
temperature = 0
while True:
    data_to_send = "xtemperature"
    time.sleep(1)
    send_data(data_to_send)
    time.sleep(1)
    while True:
        received_data = RS485.readline().rstrip()
23
        received_data = received_data.decode('utf-8')
24
        print(received_data)
25
        time.sleep(1)
26
        received_value = int(received_data)
27
        if 0 <= received_value <= 70:
28
            temperature=received_value
29
            break
30
31
    break
32
print("TEMPERATURE : ",temperature)
Raspberry Pi Pico Code
from machine import Pin
import time
from dht import  DHT11
uart_tx = machine.Pin(4)  # TX pin: GPIO 0
uart_rx = machine.Pin(5)  # RX pin: GPIO 1
uart = machine.UART(1, baudrate=9600, tx=uart_tx, rx=uart_rx)
def response():
    received_data = uart.read()
    try:
        received_string = received_data.decode('utf-8').strip()
        print("DATA :")
        print(received_string)
        if received_string:
            if received_string[0] == 'x':
                pin = Pin(15,Pin.IN,Pin.PULL_UP)
23
                d = DHT11(Pin(15))
24
                d.measure()
25
                T = d.temperature()
26
                x=0
27
                while x<150:
28
                    x=x+1
29
                    T=d.temperature()
30
                    send_data = str(T)
31
                    data = (send_data + "\r\n")
32
                    time.sleep(1)
33
                    uart.write(data.encode('utf-8'))
34
                    print("data sent")
35
                    print(data)
36
37
                return received_string
38
39
    except UnicodeError:
40
        pass
41
    return ""
42
43
44
while True:
45
    if uart.any():
46
        incoming_data = response()
47
        print(incoming_data)
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
