EmbDev.net
Forum: µC & Digital Electronics P3 Motherboard only starts with cmos battery removed
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Halim M. (gmipf)
Rate this post
useful
not useful
My motherboard is a Gigabyte GA-6VXE7+ (rev. 1.0). Without a battery
installed the motherboard starts and posts, I can enter bios etc.
Everything seems fine. With a battery installed the motherboard doesn't
react at all, no fan spin, nothing. The pwr header still has 5v but
shorting does nothing. I need to remove the battery, turn off the psu,
wait until the voltage on the pwr header drops to 0V. After that the
motherboards starts again without a battery. To me it seems like a short
somewhere when the battery is installed. I also have removed the battery
holder and found some battery leakage which I have cleaned up, the
traces below seemed ok to me there. My other theory is the diode which
connects to the battery 3v line. The place where the rtc and cmos ram is
located seems to be the southbridge VIA VT82C596B. I don't know how to
go further, any ideas?
von ●DesIntegrator ●. (Company: FULL PALATINSK) (desinfector)
Rate this post
useful
not useful
did U ever reset the BIOS?
Rate this post
useful
not useful
Yes, with its cmos reset jumper. Even started the board without the
eeprom at all. Electrically it starts with the battery removed.
von Peter E. (Company: S&P) (eosangel)
Rate this post
useful
not useful
Rate this post
useful
not useful
> eeprom at all.
and what does the board do w/o the chip?
Rate this post
useful
not useful
The holder is already removed. If i just touch +/- from the battery to
its solder points the board will refuse to start.
●DesIntegrator ●. wrote:
>> eeprom at all.
it just starts as usual, fans spinning. But only with the battery not
connected. No difference, except no beeping at all since no code is
executed.
Rate this post
useful
not useful
With just the battery connected but no psu i measure 0.6v on the pwr
header. Is that behaviour normal? On an another board there is always
0v.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
