EmbDev.net
Forum: µC & Digital Electronics AVR Assembler: Debugging IR Remote Control Transmitter
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Johannes T. F. (jofe)
Rate this post
useful
not useful
Hello,
I'm trying to develop a simple infrared remote-control transmitter,
using an ATmega88A, assembler and the NEC modulation (please see
https://www.mikrocontroller.net/articles/IRMP_-_english#NEC_+_extended_NEC
for details on that).
My program isn't working correctly yet – after testing with a receiver
failed, I connected a red LED to the output which produced the result
that can be seen in the attached video: the LED blinks, but the
transmission stretches out for circa one second, which is far too long –
an NEC transmission should take about 60 ms.
I initially suspected wrong timer settings, but couldn't find any error.
After reading through my code again and again, I decided to post it here
in the hope that someone might have a look at it and maybe find the
problem.
Thank you in advance for any help.
Best regards
– Johannes
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
A flashing LED is way too little to debug a serial interface. You should
connect a oscilloscope instead. Because with that you can determine the
real pulse times and check it against the mentioned
and find out the factor your timing is wrong.
When its "fairly ecacxt" the factor 8 you shuld check the correct
setting of the clkdiv8 fuse in your AVR.
: Edited by Moderator
Rate this post
useful
not useful
Lothar M. wrote:
> You should connect a oscilloscope instead.
Yes, that's true of course, but unfortunately I don't have a DSO at the
moment.
I already checked that; it's not programmed (i.e. value 1).
I used the UART successfully with the same hardware directly before I
flashed the current program, so the clock frequency has to be correct.
von S. L. (sldt)
Rate this post
useful
not useful
(Wilhelm M. - are you watching?)
Well now how about that?:
 ldi   temp0, 1<<WGM12  ; CTC mode
 xout  TCCR1A, temp0
WGM12 resides in TCCR1B.
Rate this post
useful
not useful
Oh yes, that was a mistake – thank you!
I corrected that and, in addition, another error (forgot to clear the
COM0A0 bit of TCCR0A in the ir_carrierOff macro, which caused the LED
not to be switched off at the end of every other transmission).
Now, it works perfectly.
Again, S. L., thanks for your help!
Have a nice evening,
– Johannes
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
