EmbDev.net
Forum: µC & Digital Electronics at89c51cc03 problems
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Francisco R. (Company: individual) (rodriguinhos)
Rate this post
useful
not useful
I need to read the flash contents in a"at89c51cc03" .
So i installed the components (adaptor rs232 ,cristal etc.).
Opening the flip I can read and write the microchip. However if i try to
read
one microchip that I have in other application allwais give "timeout".
It´s possible the user bootloader is programed to jump the can
bootloader?
and how can I access the flash in this mode?
Thanks
Rodrigues
von Holger T. (holgert)
Rate this post
useful
not useful
What version of chip do you have?
 * at89c51cc03u - uart bootloader type
 * at89c51cc03c - can bootloader type
What do you mean with:
> However if i try to read
Are you able to read the chip or not?
Beside the flash, are you able to read the signature of the chip?
: Edited by User
Rate this post
useful
not useful
Hi
The chip is "Atmel  89c51cc03ua-um".
Yes,I be  able to read and write, in a equal virgin chip.
The problem is when i try to read the chip, that i removed from an
application of mine,it gives always "Timeout".
Thanks for your replay.
Rodrigues
Rate this post
useful
not useful
May be something like this is set: BLJB != 0. In that case application
bootloader is used. You can bypass it by applying Hardware Condition
(RESET=high, PSEN=low, EA=high, RESET=low) . See Hardware Boot Process
in datasheet.
Rate this post
useful
not useful
I apply  reset hardware condition,(RESET=high, PSEN=low, EA=high,
RESET=low)
however  the result is always the same(Timeout error).
Remember the chip is programmed, and i can´t read the signature.
Thanks
Rodrigues
Rate this post
useful
not useful
Strange...
Just to be sure:
  * The chip (you can't read) contains a program and does work in
target?
  * You try to read that chip outside the target hardware?
  * When running the customer program in target hardware, is UART used
in that application? Otherwise, may be that chips UART is faulty.
Next:
  * I would try to reduce UART baud rate, e.g. 9600
  * use a logic analyzer an monitor ..CC03 pins Rx, Tx, EA, Reset, PSEN
  * Try to find and use a parallel programmer.
Best success!
Regards.
: Edited by User
Rate this post
useful
not useful
First of all thank you for your help.
Yes,the chip (I can't read) contains a program and it work in
target.The problem is that was a short-circuit and damaged the input
P0.0 (pin24).For that reason the target don´t make only one function.
Yes I read the chip outside (and inside) the target hardware, and the
result is the same,(Timeout error).
The customer program in target hardware, not use UART (pin 6 and 7 not
used)
but uses can network,P4.0 and P4.1 (pin 14,15).
I don´t bilieve the UART is faulty, maybe the user bootloader have some
instruction to jump for network can bootloader,if is that possible,I
don´t realy know.
I will try with a logic analyzer to see all signals, and then(if I have
no results),I wil try parallel programmer.
Do you know someone?
Thaks
Rodrigues
Rate this post
useful
not useful
In that case, you are already executing code in user flash FM0 and
"network can bootloader" is part of user application. Applying Hardware
Condition (see above) should prevent to reach that place.
No, I've never used a parallel programmer for it and was not engaged
with it.
: Edited by User
Rate this post
useful
not useful
HI,
OK, I will continue try.
I wish you a great year 2024
Rate this post
useful
not useful
HI,again.
 I'm back to say that I still can't communicate with the
chip,(programmed).
So in summary if I put a new (empty)chip in circuit,I can communicate
with it and make everything(read,writh,etc.) then I just change the chip
(put the programmed),and it gives (timeout error)even after reset
,(theoretically it should communicate since the conditions are the
same).
I analyzed the signals (with logic analyzer)and the diference is:
in a new chip we have first a tx signal(rx in chip),and after we have
the answer in rx(tx in chip), in other chip (the programmed),we have the
same signal but the chip does not respond.
I think we have two reasons for it: or the bootloader(FM1) is programed
to jump immediately fo FM0,(i don´t know if it is possible),or they
burned the inputs (rx and tx)on purpose since it was not used in
application.
If that's the case,does not make sense,they could put block bit´s to
level 2,
don´t you think?
Thanks
Rodrigues
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
