EmbDev.net
Forum: FPGA, VHDL & Verilog How to instantiate another vhd file inside testbench, where the testbench is used for opening files
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Zahid (zahidsaleem)
Rate this post
useful
not useful
I am trying to learn how to read from file in VHDL, the vhdl_code.vhd
implements a low pass moving average filter, I already have a separate
vhdl code Read_File.vhd that reads the data, now I have to read the
column data from the file data2fpga.dat, and perform the low-pass
operations in vhdl_code.vhd. My question is, should the Read_file.vhd
should run as testbench or, how exactly i can perform this, i.e. how can
I invoke the vhdl_code.vhd into Read_file.vhd? Any guidance will be
highly appreciated. Thanks.
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Zahid wrote:
> should the Read_file.vhd should run as testbench
A testbench does not have any ports in its entity, because it is the
uppermost level of the design. So it looks like the ReadFile may be a
component of your testbench. And the testbench manages the
interconnets between the ReadFile and lab111 components.
Rate this post
useful
not useful
@Von Lothar, I never coded a testbench which has a component that
happens to be a testbench itself, this is the first time I am seeing it,
the problem is the clk signal, both entity lab111 and ReadFile have clk
ports, you are right, testbench should NOT have any ports, but I tried
to perform the operations nevertheless, & I got the error
"Declaration with designator "clk" already exists in this region."
  If it is not much to ask, I could not find any tutorials that have
similar problems, can you guide me to any literature or learning videos
so that I can learn & solve this problem?
Thanks a lot for replying to the previous message.
Zahid.
Rate this post
useful
not useful
In the testbench you define ak clock signal and in the very same test
bench you connect that clock signal to all components needing that clock
signal.
Look how iI do it there with some components (its German, but Google
translator will do it):
- http://www.lothar-miller.de/s9y/archives/57-Sinusausgabe-mit-PWM.html
Top level is the testbench which generates a clock signal. In the test
bench the clock ist connected to the SinusPWM. And in the SinusPWM there
are two components which also get that clock signal routed through.
So all in VHDL designs there only are entities which act as components
in other entities.
: Edited by Moderator
Rate this post
useful
not useful
Ok, thank you Mr. Lothar, your comment "So it looks like the ReadFile
may be a component of your testbench." solved my issue. You are right,
testbenches should not have entities, i created a new testbench,
instantiated both the ReadFile and Lab111 as components, make the
necessary port and generic maps & was finally able to load the data into
the testbench. Thanks again.
Best of Regards,
Zahid.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
