EmbDev.net
Forum: FPGA, VHDL & Verilog Instantiate module in verilog
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Thiều Quang A. (tuananh)
Rate this post
useful
not useful
Hi guys i have 2 module.
Fisrt module is generating clock signal
module ClockGenerator(
    output reg clk
// Define clock period parameters
parameter CLK_PERIOD = 10; // Define the clock period in simulation time
units
// Initialize clock
initial begin
    clk = 1'b0; // Start with the clock low
end
// Toggle the clock signal at every half of the period
always #((CLK_PERIOD/2)) clk = ~clk;
endmodule
Secound module is counter to 16 then reset to 0 when it reach 16
module CounterAndReset(
    output reg [3:0] count,
    input wire clk,
    input wire reset
// Define the maximum count value
parameter MAX_COUNT = 4'b1111;
// Initialize count
always @(posedge clk or posedge reset) begin
    if (reset) begin
        count <= 4'b0000; // Reset count to 0
    end else begin
        if (count == MAX_COUNT) begin
            count <= 4'b0000; // Reset count to 0 when it reaches
MAX_COUNT
        end else begin
            count <= count + 1; // Increment count
        end
    end
end
endmodule
I want to ask is how to combine these to module together. Thanks all
von Rick D. (rickdangerus)
Rate this post
useful
not useful
I would use a top level module (top.v) and there you can instantiate
both sub modules.
Untested example:
module top;
  reg main_clk;
  reg main_reset = 0;
  wire [3:0] main_count;
  ClockGenerator inst_1 (
    .clk(main_clk)
  CounterAndReset inst_2 (
    .clk(main_clk),
    .reset(main_reset),
    .count(main_count)
endmodule
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
