EmbDev.net
Forum: µC & Digital Electronics ch55xduino - CH552 serial print to txd port
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Henrik A. (henrikandersen)
Rate this post
useful
not useful
Im working on a CH552 project using ch55xduino IDE with a Development
Board: “CH552 Core Board by WeActStudio”
I trying to write a simple text “Hello,World" to an cpu port (31) TXD.
But can not get the code working, can any give me hand with the code
Has anybody used Serial0.println or Serial1.println
USBSerial_print(“Hello,World”); works perfect !
Code:
void setup() { Serial1.begin(9600); while (!Serial1); }
void loop() { Serial1.println("Hello,World"); delay(1000); }
von Thomas Z. (usbman)
Rate this post
useful
not useful
ch55xduino uses SDCC for compiling. Therefore no c++ syntax is allowed.
try using the underscore instead of the dot.
e.g.
Serial1_println("Hello World");
and for output at P3.1 Serial0_println();
Rate this post
useful
not useful
Hello Thomas,
Thanks for your suggestions, unfortunately I'm still not getting any
data out on ant of the ports.
I have tried to connect my serial capture program ( RealTerm ) to any
port without result.
When I connect Rx to TX my serial capture program, the capture program
echo what I type, so I'm sure the capture program works fine.
I also have no compile error, so looks like CHxxDuino accept:
- Serial0_println("Hello World");
- Serial1_println("Hello World");
USBSerial_println("Hello World"); works fine ! using Arduino Serial
Monitor.
Any other suggestions ?
void setup() {
void loop() {
Serial0_println("Hello World");   // print to P1.7
Serial1_println("Hello World");   // print to P3.1
USBSerial_println("Hello World"); // print to USB ( Works fine )
delay(100);
Rate this post
useful
not useful
I dont use Arduino code on that board, so my knowledge is very limited.
But here is the thing:
Output on TX0 or TX1 usually requires to TI =1 (U1TI = 1) in Non
Interrupt mode to signal the transmiter is empty. I suppose this is done
in Serial0_begin() and Serial1_begin().
void setup() {
  Serial0_begin(9600);
  Serial1_begin(9600);
void loop() {
Serial0_println("Hello World0");   // print to P1.7
Serial1_println("Hello World1");   // print to P3.1
delay(100);
: Edited by User
von Pierre B. (pierreaps)
Rate this post
useful
not useful
I appreciate your advice, but regrettably I'm still not able to pull any
data out of any of the ports.
von Klaus S. (kseege)
Rate this post
useful
not useful
Could You already successfully run any of the examples?
Maybe Your problem is located in a lower level.
Best regards
Klaus
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
