EmbDev.net
Forum: FPGA, VHDL & Verilog FPGA development resources
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Andreas S. (andreas) (Admin)
Rate this post
useful
not useful
*CPLD or FPGA?*
The main difference is that CPLDs are smaller than FPGAs, i.e. you can
fit a lot more logic inside a FPGA than inside a CPLD.
* CPLDs: address decoders, bus interfaces, simple memory controllers,
(video) signal generators
* FPGAs: complex CPUs, high speed I/O, signal processing, encryption
*VHDL or Verilog?*
The difference is mainly in syntax, you can get the same synthesis
result with both languages. VHDL is more verbose than Verilog (which can
be an advantage or disadvantage, depending on how you look at it). In
Europe VHDL is much more widely used than Verilog, in the US Verilog
seems to be slightly more popular.
Basic rules for VHDL development
See "http://embdev.net/articles/VHDL":http://embdev.net/articles/VHDL.
Chip vendors
* "Xilinx":http://www.xilinx.com
* "Altera":http://www.altera.com
* "Lattice":http://www.latticesemi.com
* "Actel":http://www.actel.com
Boards
* also see the FPGA vendors' websites
* "Digilent":http://www.digilentinc.com
Tutorials
* TODO
IP Cores
* "Opencores":http://opencores.org - CPUs, USB, Ethernet, encryption,
If you want to suggest any additions to this post, please reply below.
von Juha (Guest)
Rate this post
useful
not useful
I think this site would be helpfull. Here is some basic things and some
more advanced.
http://www.fpga4fun.com/
von Shahul A. (Company: pantech solution) (shahulakthar)
Rate this post
useful
not useful
Here is a Source for learning FPGA and VHDL concepts
http://allaboutfpga.com/
von René D. (Company: www.dossmatik.de) (dose)
Rate this post
useful
not useful
for verfication
http://www.stefanvhdl.com/
a good simulator is the combination GHDL and GTKwave
http://sourceforge.net/projects/ghdl-updates/
http://gtkwave.sourceforge.net/
I have written an introduction for this simulator
http://www.dossmatik.de/ghdl/ghdl_unisim_eng.pdf
von Warren T. (doctorwkt)
Rate this post
useful
not useful
I found the book "Free Range VHDL" to be an excellent book about the
language and also about best practices when writing VHDL code. Link:
http://freerangefactory.org/shop.html#FreeRangeVHDL-Book
Cheers, Warren
von FPGA4student.com (Guest)
Rate this post
useful
not useful
von peter (Guest)
Rate this post
useful
not useful
i programmed fbga with xp2 lattice chip to switch lvds from ipu and gpu.
The screen resolution of 1440x900 and 1600x900 is good. but 1920x1200
results are bad. I think the data and clk channel n and p output from
the chip is not good. You let me ask how I write code to ensure that clk
and data out are good
von Mark P. (mphil)
Rate this post
useful
not useful
I found these IP for Ethernet very useful:
http://www.fpga-cores.com/
For those who likes C++ this is very good to fast and easily create CPU
/ RISC-V systems for FPGAs:
http://www.fpga-cores.com/instant-soc/
von MARC M. (magicianpe)
Rate this post
useful
not useful
Simple VHDL Editor with access to IP Core library:
http://sba.accesus.com/software-tools/sba-creator
SBA (Simple Bus Architecture):
Some Open IP Cores for SBA:
https://github.com/mriscoc/SBA-Library
von Dmitry A. Senjakin (Guest)
Rate this post
useful
not useful
A lot of FPGA-based processor cores.
http://www.mycores.biz/
Project has some cores, C-to-assm and assm-to-binary compiller, debug
system and kernel software.
Multiprocessor cores, multithread cores.
von Vipin K. (Company: Nazarbayev University) (vipinkmenon)
Rate this post
useful
not useful
I am creating a Youtube playlist for those who are interested to
start/learn/try hardware-software codesign with Xilinx Zynq APSoC
platform. There are already 40 Videos and hoping to add about 100 Videos
from basic to advanced level. Basic background in Verilog and C
programming are assumed. All source code are made available through git
repo.
https://lnkd.in/gnw7Au8
von Alexander S. (Company: Home) (alex_isr)
Rate this post
useful
not useful
CPLD or FPGA?
>i.e. you can fit a lot more logic inside a FPGA than inside a CPLD.
 Main different CPLD from FPGA that :
CPLD work immidiatly after power up
FPGA after power up need time for load from external or internal flash
memory.
 It's present some application wich need work immidiatly after power up
and can be released only by CPLD.
P.S.
 FPGA can lose it design and stop work after short time power down or
power spike and need it reload.
 CPLD does not have this problem.
 Regards Alex.
: Edited by User
von ktorkkelson (Guest)
Rate this post
useful
not useful
@Alexander S. you really have no clue of these things!
First, do your homework before stating things.
Cheers :)
Rate this post
useful
not useful
 Perhaps Wikipedia have clue of these things :
 The most noticeable difference between a large CPLD and a small FPGA is
the presence of on-chip non-volatile memory in the CPLD, which allows
CPLDs to be used for "boot loader" functions, before handing over
control to other devices not having their own permanent program storage.
A good example is where a CPLD is used to load configuration data for an
FPGA from non-volatile memory.
 https://en.wikipedia.org/wiki/Complex_programmable_logic_device
FPGA loads it from external memory (typically on every power-on)
https://en.wikipedia.org/wiki/Field-programmable_gate_array
Rate this post
useful
not useful
> repo.
 Usually I put real ModelSim project which you can start and check
simulation of design and see that design really work.
You don't need to build ModelSim  project and design TestBench file .
ModelSim simulation tools you can download from Altera's site.
 Regards Alex.
: Edited by User
von Mark P. (mphil)
Rate this post
useful
not useful
If you are working with Wishbone Instant SoC now supports Wishbone in a
very nice way.
See https://www.fpga-cores.com/wishbone/
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
