EmbDev.net
Forum: µC & Digital Electronics Reset on LPC1768
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Prakash R. (Company: Coinel Technology Solutions) (prakash)
Rate this post
useful
not useful
Hello,
I am using LPC1768 and programming it using ISP. What i have observed is
that the programs that i load work fine but when i repower the LPC
board, the code starts to work only after a reset.
The code executions should start after powerup.
Kindly let me know what could be the possible issue.
: Moved by Admin
von M.K. B. (mkbit)
Rate this post
useful
not useful
Hello,
to me it looks like a problem with the power supply.
If you switch on the power, all the devices in your circuit draw
current. If this ist too much and the voltage drops below a certain
level, the controller might end up in an undefined state.
Solution might be too change something on your power supply. Or maybe
there is a parameter to delay the startup of your controller.
I hope this will help you!
von Lutz (Guest)
Rate this post
useful
not useful
Have you enabled the brown out detection? Another possibility is the
power supply: If you only switch off the power for a few seconds there
may be capacities in the circuit which holds the power on a sufficient
level. As a result the µC doesn't recognize the power loss.
von Martin T. (mthomas) (Moderator)
Rate this post
useful
not useful
Are there any loops in the initialisation which wait for bits to be
set/cleared by the hardware (something like while
(!(SOME_REG&SOMEMASK)){;})? IF so, check with "LED-blink-debugging" if
the code "hangs" in such a loop. Did you try with the ISP interface
connected and disconnected. Did you check the VCC, BSL and RST levels
with a scope? Do you use code from NXP's CMSIS package to init the
clock-system? If not, you may at least do a few tests with the code from
the package.
Rate this post
useful
not useful
Mk Bit wrote:
> Hello,
Thanks for your response. Ya it looks like problem hardware only.
I have herewith attached the circuit, It would be great if you check
this circuit
The reset and isp circuit i have uploaded to this link
The RST# goes to controller pin 17.
von TL431 (Guest)
Rate this post
useful
not useful
Is R22 470 Ohms? Together with the 10k (R21) the Reset Voltage might be
very low.
Rate this post
useful
not useful
> the package.
Thanks for your reply.
There are no loops in the initialization.
I have checked the VCC, BSL, RST lines
BSL line: default -> 3.1v
          After ISP switch - 0 -> 3.1v (the value changes from low to
high)
Vcc line: Default -> 3.3 v
          After Reset - 3.3v
RST line : Default -> 1.7v
           After Reset - 0 -> 1.7v (the value changes from low to high)
RST out Line: Default -> 3.2v
            after reset - 0-> 3.2v (the value changes from low to high)
These lines seems to be working fine, Any suggestions to the possible
problem??
von hamid (Guest)
Rate this post
useful
not useful
helloo
i have a challenge with lpc 1768 reset.
 in several case when i reset  this processor via  the  reset pin and
connect it directly to gnd the ic  will crashed and burnes.so that for
avoiding ic failing i should reset the ic reset pin via the resistance.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
