AVR+Bascom+SD
OP #936262
ich bin dabei unter BASCOM eine SD-Karte zum laufen zu kriegen. Ih
verwende folgenden Code:
$regfile = "m32def.dat"
$crystal = 16000000
$baud = 9600
Dim Abuffer(512) As Byte                                    ' Hold
Sector to and from CF-Card
Dim Wsrampointer As Word ' Address-Pointer for write
Config Pinb.4 = Output                                      ' define
here Pin for CS of MMC/SD Card
Mmc_cs Alias Portb.4
Set Mmc_cs
here Pin of SPI SS
Spi_ss Alias Portb.4
Set Spi_ss ' Set SPI-SS to Output and High por Proper work of
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes ,
Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 1
Spiinit ' Init SPI
Const Cperrdrivereset = 225 ' Error response Byte at Reset command
Const Cperrdriveinit = 226 ' Error response Byte at Init Command
Const Cperrdrivereadcommand = 227 ' Error response Byte at Read Command
Const Cperrdrivewritecommand = 228 ' Error response Byte at Write
Command
Const Cperrdrivereadresponse = 229 ' No Data response Byte from MMC at
Read
Const Cperrdrivewriteresponse = 230 ' No Data response Byte from MMC at
Write
Const Cperrdrive = 231
Const Cperrdrivenotsupported = 232 ' return code for DriveGetIdentity,
not supported yet
Waitms 1 ' Wait some time before initialising MMC/SD
Dim Gbdriveerror As Byte ' General Driver Error register
Dim Gbdriveerrorreg As Byte ' Driver load Error-Register of HD in case
of error
Dim Gbdrivestatusreg As Byte ' Driver load Status-Register of HD on case
of error
Dim Gbdrivedebug As Byte
$lib "MMC.LIB" ' link driver library
$external _mmc
Dim I As Word
Dim Sectornr As Long
Wsrampointer = Varptr(abuffer(1))
Input "Start?" , I
Gbdriveerror = Driveinit() ' Init MMC/SD Card
Print "INIT ";
Print Gbdriveerror
Do
Input "Sector: " , Sectornr
Print "Write sector:"
For I = 1 To 512
Abuffer(i) = I And &HFF
Print Abuffer(i);
Print " ";
Next I
Gbdriveerror = Drivewritesector(wsrampointer , Sectornr ) 'dauert 25ms
Input "Read sector" , Sectornr
Gbdriveerror = Drivereadsector(wsrampointer , Sectornr ) 'dauert 8ms
Print "Read ";
Print Gbdriveerror
For I = 1 To 512
Print Abuffer(i);
Print " ";
Next I
Waitms 1000
Loop
Nach dem Anschalten der Schaltung dauert es sehr lange bis erscheint,
dass die SD-Karte nicht erkannt wurde. Anstatt von "Driveinit()" habe ih
eben gerade "Drivecheck()" ausprobiert und sieht da, ich bekomme eine
"0" (erkannt) zurück. ABER: zu früh gefreut. Nehme ich die SD-Karte aus
der Schaltung bekomme ich trotzdem eine "0" zurück. Eine zweite Karte
hab ich auchshon erfolglos getestet. Was könnt ihr mir noch empfehel was
ich überprüfen sollte/könnte?
Gast #936633
Warum sind dann im Code 2 Auswahlmöglichkeiten für MMC_CS und SPI_SS?
PortB.4 wir im Programm einmal gesetzt und da bleibt er dann. Dann
könntest Du auch die Anschlüsse MMC_CS und SPI_SS auf + Ub legen und
das war es dann. ;-)
MfG Paul
OP #937088
Sehr schön! Ich habe die Frequenz auf 4MHz runtergesetzt und die
Deklarationdes SPI-SS Pins entfernt. Die Folge dessen war, dass ich eine
"0" zurückbekam (erkannt!!!) als die SD-Karte steckte - und der
Controller stehenblieb als die SD-Karte entfernt wurde.
Vielen Dank für eure Ratschläge!
OP #937706
Jetzt kommt mir aber noch eine grundlegende Frage auf: Wenn ich
beispielsweise die Zahl 5 Auf die Karte schreiben will, weiss ich nicht
wie ich das anstellen soll. Aus der BASCOM Hilfe werde ich zu dem Befehl
"Drivewritesector" nicht schlau. Kann mir wer helfen?
