Charging a Goldcap 0.1F
Gast #85735
many of the available versions of the 78er regulators have an build-in
current-limitation.
to see, if the regulator have an current limitation, look the exact
part number of the regulator an then look in the datasheet.
in other way it could be, that this fast charge isn't good for the
goldcap.
in this case I think you should measure the charge-current with an
Ampere-Meter. than look in the datasheet for the Goldcap and look there
for the internal resistor of the goldcap.
..so you can calculate the power, which is transformed in the goldcap
to heat, while it is charging and then decide if this power can damage
the Goldcap or not.
