1 | //-----------------------------------------------------------------------------
2 | // ATMEL Microcontroller Software Support - ROUSSET -
3 | //-----------------------------------------------------------------------------
4 | // DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR
5 | // IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
6 | // MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
7 | // DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT,
8 | // INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
9 | // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
10 | // OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
11 | // LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
12 | // NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
13 | // EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
14 | //-----------------------------------------------------------------------------
15 | // File Name : Cstartup_SAM7.c
16 | // Object : Low level initialisations written in C for Tools
17 | // For AT91SAM7S with 2 flash plane
18 | // Creation : JPP 09-May-2006
19 | //-----------------------------------------------------------------------------
20 |
21 | // slightly modified by Martin Thomas:
22 | // - Disable Watchdog first
23 | // - project.h -> board.h
24 | // - modified parentheses for AT91C_BASE_PMC->PMC_MOR to avoid compiler warning
25 |
26 | ///// board.h ersetzt
27 | // #include "board.h"
28 | #define __inline static inline
29 | #include "AT91SAM7S256.h"
30 | #include "lib_AT91SAM7S256.h"
31 |
32 | ///// AIC init auskommentiert fuer Beispiel
33 | #if 0
34 | // The following functions must be write in ARM mode this function called
35 | // directly by exception vector
36 | extern void AT91F_Spurious_handler(void);
37 | extern void AT91F_Default_IRQ_handler(void);
38 | extern void AT91F_Default_FIQ_handler(void);
39 | #endif
40 |
41 | //*----------------------------------------------------------------------------
42 | //* \fn AT91F_LowLevelInit
43 | //* \brief This function performs very low level HW initialization
44 | //* this function can use a Stack, depending the compilation
45 | //* optimization mode
46 | //*----------------------------------------------------------------------------
47 | void AT91F_LowLevelInit(void)
48 | {
49 | unsigned char i;
50 |
51 | ///////////////////////////////////////////////////////////////////////////
52 | // Disable Watchdog (write once register)
53 | ///////////////////////////////////////////////////////////////////////////
54 | AT91C_BASE_WDTC->WDTC_WDMR = AT91C_WDTC_WDDIS;
55 |
56 | ///////////////////////////////////////////////////////////////////////////
57 | // EFC Init
58 | ///////////////////////////////////////////////////////////////////////////
59 | AT91C_BASE_MC->MC_FMR = AT91C_MC_FWS_1FWS ;
60 |
61 | ///////////////////////////////////////////////////////////////////////////
62 | // Init PMC Step 1. Enable Main Oscillator
63 | // Main Oscillator startup time is board specific:
64 | // Main Oscillator Startup Time worst case (3MHz) corresponds to 15ms
65 | // (0x40 for AT91C_CKGR_OSCOUNT field)
66 | ///////////////////////////////////////////////////////////////////////////
67 | AT91C_BASE_PMC->PMC_MOR = ( AT91C_CKGR_OSCOUNT & (0x40 <<8)) | AT91C_CKGR_MOSCEN;
68 | // Wait Main Oscillator stabilization
69 | while(!(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_MOSCS));
70 |
71 | ///////////////////////////////////////////////////////////////////////////
72 | // Init PMC Step 2.
73 | // Set PLL to 96MHz (96,109MHz) and UDP Clock to 48MHz
74 | // PLL Startup time depends on PLL RC filter: worst case is choosen
75 | // UDP Clock (48,058MHz) is compliant with the Universal Serial Bus
76 | // Specification (+/- 0.25% for full speed)
77 | ///////////////////////////////////////////////////////////////////////////
78 | AT91C_BASE_PMC->PMC_PLLR = AT91C_CKGR_USBDIV_1 |
79 | (16 << 8) |
80 | (AT91C_CKGR_MUL & (72 << 16)) |
81 | (AT91C_CKGR_DIV & 14);
82 | // Wait for PLL stabilization
83 | while( !(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_LOCK) );
84 | // Wait until the master clock is established for the case we already
85 | // turn on the PLL
86 | while( !(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_MCKRDY) );
87 |
88 | ///////////////////////////////////////////////////////////////////////////
89 | // Init PMC Step 3.
90 | // Selection of Master Clock MCK equal to (Processor Clock PCK) PLL/2=48MHz
91 | // The PMC_MCKR register must not be programmed in a single write operation
92 | // (see. Product Errata Sheet)
93 | ///////////////////////////////////////////////////////////////////////////
94 | AT91C_BASE_PMC->PMC_MCKR = AT91C_PMC_PRES_CLK_2;
95 | // Wait until the master clock is established
96 | while( !(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_MCKRDY) );
97 |
98 | AT91C_BASE_PMC->PMC_MCKR |= AT91C_PMC_CSS_PLL_CLK;
99 | // Wait until the master clock is established
100 | while( !(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_MCKRDY) );
101 |
102 |
103 | #if 0
104 | ///////////////////////////////////////////////////////////////////////////
105 | // Init AIC: assign corresponding handler for each interrupt source
106 | ///////////////////////////////////////////////////////////////////////////
107 | AT91C_BASE_AIC->AIC_SVR[0] = (int) AT91F_Default_FIQ_handler ;
108 | for (i = 1; i < 31; i++) {
109 | AT91C_BASE_AIC->AIC_SVR[i] = (int) AT91F_Default_IRQ_handler ;
110 | }
111 | AT91C_BASE_AIC->AIC_SPU = (unsigned int) AT91F_Spurious_handler;
112 | #endif
113 | }
