Benutzer Diskussion:Alex45
Brauche Hilfe kann das folgende .ASM nicht umwandeln: Bekomme bei STATUS,C und STATUS,Z immer Fehlermeldung
CPU configuration
list P=16F84 #include "p16f84.inc" __config _XT_OSC & _WDT_OFF & _PWRTE_ON
Define variables at memory locations
RAM
W_TMP equ H'0C' ; temporary store for w in interrupt STATUS_TMP equ H'0D' ; temporary store of status in interrupt
REMOTE_M equ H'0E' ; remote control input ms byte REMOTE_L equ H'0F' ; remote control input LS byte REM_FLG equ H'10' ; flag to indicate current remote control sequencing REM_CNT equ H'11' ; interrupt count for polling remote control signal REM_COD equ H'12' ; remote control bit counter mode. TOGGLE equ H'13' ; remote control toggle flag FLAG0 equ H'14' ; test flag 0 B_STAT equ H'15' ; B port input status at power up A_STAT equ H'16' ; A port input status at power up VALUE_1 equ H'17' ; delay value VALUE_2 equ H'18' ; delay value FLAG_RM equ H'19' ; flag to indicate continuous remote TG_BIT equ H'1A' ; counter of number of incorrect toggle matches FLG_HL equ H'1B' ; high or low remote control sign
define reset and interrupt vector start addresses
org 0 ; start at address 0000h goto MAIN ; normal service routines from Reset vector org 4 ; interrupt vector 0004h, start interrupt routine here goto INTRUPT
start interrupt by saving w and status registers before altered by interrupt routine
INTRUPT movwf W_TMP ; w to w_tmp storage swapf STATUS,w ; status to w movwf STATUS_TMP ; status in status_tmp bcf STATUS,RP0 ; select memory bank 0
check interrupt
btfsc INTCON,T0IF ; TMRO overflow interrupt flag then goto counter goto COUNTER ; TMRO overflow so increase counter goto RECLAIM ; end of interrupt reclaim w and status
adjust interrupt rate with counter
COUNTER movlw D'207' ; freq is 4MHz/4/2/50. = 100us addwf TMR0,f ; add to timer register and takes 2 cycles to start counting bcf INTCON,T0IF ; clear TMRO interrupt flag
check if RA3 has gone low for start of remote control sequence
btfss FLAG0,0 ; if flag set then test mode goto RM_SQ ; remote sequence started? bcf PORTA,1 ; * tracer for remote decode btfsc REM_FLG,1 ; is it the end of remote control sequence bcf PORTA,0 ; then clear RA0 stop start indicator RM_SQ btfsc REM_FLG,0 ; has remote control sequence started goto REM_SEQ btfsc PORTA,3 ; is RA3 low goto RECLAIM bsf REM_FLG,0 ; set beginning of remote control flag
movlw D'22' ; initial time period to wait till next start bit movwf REM_CNT movlw D'13' ; shift register counter movwf REM_COD bsf REMOTE_L,0 ; set first bit in remote control sequence clrf FLG_HL ; clear bit 1 in high low flag bsf REM_FLG,7 ; start bit flag set bsf PORTA,2 ; decode out (acknowledge LED driver) btfss FLAG0,0 ; if set then test mode goto RECLAIM bsf PORTA,1 ; * tracer for decode (reads level at this point) bsf PORTA,0 ; * start/stop trace goto RECLAIM
REM_SEQ btfsc REM_FLG,1 ; has it finished goto RECLAIM decfsz REM_CNT,f ; decrease interrupt counter for timing goto CKEDGE ; check if change in level bcf REM_FLG,7 ; clear start bit flag movlw D'18' ; 18 x 100us = 1.8ms or period between valid bits movwf REM_CNT rlf REMOTE_L,f ; least sig byte in remote control code sequence rlf REMOTE_M,f ; most sig byte movf PORTA,w ; check bit 3 portA andlw B'00001000' ; mask out bits except bit 3 movwf FLG_HL ; place in flag btfsc PORTA,3 ; check if high or low goto HI ; high so clear bsf REMOTE_L,0 ; if low set this bit bsf PORTA,2 ; if high clear this bit goto BY_HI ; bypass high HI bcf REMOTE_L,0 ; clear 0 bit bcf PORTA,2 ; acknowledge BY_HI btfsc FLAG0,0 ; if set test mode bsf PORTA,1 ; * tracer decfsz REM_COD,f ; decrease shift register count goto RECLAIM bsf REM_FLG,1 ; set end of remote control decoding flag goto RECLAIM
align change in level (edge detect) with REM_CNT counter
CKEDGE btfsc REM_FLG,7 ; start bit flag bypass edge detect as AGC level setting goto RECLAIM movlw B'00001000' ; select bit 3 for PORTA,3 andwf PORTA,w ; bit 3 xorwf FLG_HL,w ; compare PORTA,3 with FLAG (previous level) btfsc STATUS,z ; Z=1 if zero then no change goto RECLAIM ; no change movlw B'00001000' ; select bit 3 for PORTA,3 andwf PORTA,w ; bit 3 select movwf FLG_HL ; reload new level movlw 0x3 ; count of 3 for REM_CNT subwf REM_CNT,w ; is REM_CNT larger or equal to 3 btfss STATUS,c goto RECLAIM ; smaller than 3 movf REM_CNT,w sublw 0x6 ; check if 6 or less btfss STATUS,c goto RECLAIM ; larger than 6 movlw 0x4 movwf REM_CNT ; set REM_CNT to 4 to align with change in level
RECLAIM swapf STATUS_TMP,w ; status temp storage to w movwf STATUS ; w to status register swapf W_TMP,f ; swap upper and lower 4-bits in w_tmp swapf W_TMP,w ; swap bits and into w register retfie ; return from interrupt
RESET
Set ports A & B
MAIN clrf REM_CNT ; remote control polling counter clrf REM_FLG ; remote control flag status clrf FLAG0 ; test clrf FLAG_RM ; continuous remote bsf STATUS,RP0 ; select memory bank 1 movlw B'11111111' ; inputs movwf TRISB ; port B data direction register movlw B'10000000' ; movwf OPTION_REG ; TMRO prescaler is 2, PORTB pullups disabled movlw B'00011111' ; (1's are inputs) movwf TRISA ; A port data direction register bcf STATUS,RP0 ; select memory bank 0
check pin status
btfss PORTA,2 ; if RA2 high set the test flag goto IN_CK ; input check bsf FLAG0,0 ; set test routine (RA0 is start stop output for remote control) ; (RA1 is tracer) RA2 normally gives decoded output for ACK LED IN_CK movf PORTB,w ; portB input level (high is toggle, low is momentary) movwf B_STAT ; port B status movf PORTA,w ; look at RA1 and RA0 movwf A_STAT ; store in A status btfsc FLAG0,0 clrf A_STAT ; clear bits 0 and 1 if in test mode (so momentary) bsf A_STAT,2 ; set bit 2 for acknowledge LED bsf STATUS,RP0 ; select memory bank 1 movlw B'00000000' ; outputs movwf TRISB ; port B data direction register movlw B'10000000' ; movwf OPTION_REG ; TMRO prescaler is 2, PORTB pullups disabled movlw B'00011000' ; (1's are inputs) RA0-2 outputs movwf TRISA ; A port data direction register bcf STATUS,RP0 ; select memory bank 0 movlw B'00000000' ; lows movwf PORTB ; portB outputs low movlw B'00000000' movwf PORTA ; portA low
interrupt enable
bsf INTCON,T0IE ; set interrupt enable for TMR0 bsf INTCON,GIE ; set global interrupt enable for above
check remote codes
delay
RM_CK movlw D'100' ; set delay period of about 120ms between codes movwf VALUE_1 ; VALUE_1 = w movlw D'255' ; set delay period value 2 LP_1 movwf VALUE_2 ; VALUE_2 = w LP_2 decfsz VALUE_2,f ; decrease VALUE_2, skip if zero goto LP_2 decfsz VALUE_1,f ; decrease VALUE_1, skip if zero goto LP_1
btfss REM_FLG,0 ; remote control sequence started goto CLR_RM1 btfss REM_FLG,1 ; is remote control entered flag set goto RM_CK
count number of codes to delete end of code sequence if button held for several seconds
btfss FLAG_RM,0 ; is continuous mode set goto XFER movf REMOTE_M,w andlw B'00001000' ; toggle bit xorwf TOGGLE,w ; is toggle bit the same as last time btfsc STATUS,z ; if z is 1 then the same goto XFER decfsz TG_BIT,f ; toggle counter goto BY_STO ; bypass storing toggle bit clrf FLAG_RM ; clear continuous mode flag XFER movf REMOTE_M,w andlw B'00001000' ; get toggle bit movwf TOGGLE ; store toggle bit movlw D'06' movwf TG_BIT ; count times that toggle bit different BY_STO movf REMOTE_M,w ; most significant remote code andlw B'00110111' ; mask out bit 7 and 6 and toggle bit 3
xorlw B'00110010' ; compare with start bits and ms 3-bits of address btfss STATUS,z ; if zero then matching goto CLR_RMF
compare with address code out if invalid clear REM_FLG
if valid check command bits and ls 2 address bits then clear REM_FLG
btfss PORTA,4 ; check porta goto SAT2
SAT1 movf REMOTE_L,w ; least sig remote code xorlw B'00000000' ; bits 0-5 keycode (0), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto ZERO movf REMOTE_L,w xorlw B'00000001' ; bits 0-5 keycode (1), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto ONE movf REMOTE_L,w xorlw B'00000010' ; bits 0-5 keycode (2), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto TWO movf REMOTE_L,w xorlw B'00000011' ; bits 0-5 keycode (3), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto THREE
xorlw B'00000100' ; bits 0-5 keycode (4), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto FOUR movf REMOTE_L,w xorlw B'00000101' ; bits 0-5 keycode (5), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto FIVE movf REMOTE_L,w xorlw B'00000110' ; bits 0-5 keycode (6), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto SIX movf REMOTE_L,w xorlw B'00000111' ; bits 0-5 keycode (7), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto SEVEN movf REMOTE_L,w ; least sig remote code xorlw B'00001000' ; bits 0-5 keycode (8), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto EIGHT movf REMOTE_L,w xorlw B'00001001' ; bits 0-5 keycode (9), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto NINE
goto CLR_RMF
SAT2 movf REMOTE_L,w ; least sig remote code xorlw B'10000000' ; bits 0-5 keycode (0), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto ZERO movf REMOTE_L,w xorlw B'10000001' ; bits 0-5 keycode (1), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto ONE movf REMOTE_L,w xorlw B'10000010' ; bits 0-5 keycode (2), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto TWO movf REMOTE_L,w xorlw B'10000011' ; bits 0-5 keycode (3), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto THREE
xorlw B'10000100' ; bits 0-5 keycode (4), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto FOUR movf REMOTE_L,w xorlw B'10000101' ; bits 0-5 keycode (5), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto FIVE movf REMOTE_L,w xorlw B'10000110' ; bits 0-5 keycode (6), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto SIX movf REMOTE_L,w xorlw B'10000111' ; bits 0-5 keycode (7), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto SEVEN movf REMOTE_L,w ; least sig remote code xorlw B'10001000' ; bits 0-5 keycode (8), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto EIGHT movf REMOTE_L,w xorlw B'10001001' ; bits 0-5 keycode (9), bit 7 and bit 6 are ls address bits btfsc STATUS,z goto NINE
goto CLR_RMF
CLR_RM1 clrf FLAG_RM ; clear continuous mode flag CLR_RMF clrf REM_FLG ; remote flag cleared bcf PORTA,2 ; decoder out btfsc FLAG_RM,0 ; if set then already passed here goto RM_CK
movf A_STAT,w ; check portA status (high is toggle so anding will keep status) andwf PORTA,f ; clear all momentary outputs keep toggles at current status movf B_STAT,w andwf PORTB,f btfss FLAG0,0 ; if set then test mode goto RM_CK bcf PORTA,1 ; * tracer out bcf PORTA,0 ; * start stop for decoder goto RM_CK
ZERO btfsc FLAG0,0 ; if set then test mode goto CLR_RMF btfsc FLAG_RM,0 ; if set then already passed here goto CLR_RMF btfsc A_STAT,1 ; if set then toggle goto TOG_0 ; toggle (alternate mode) bsf PORTA,1 ; output high bsf FLAG_RM,0 ; set continuous mode goto CLR_RMF TOG_0 btfsc PORTA,1 ; if high clear goto CLR_0 bsf PORTA,1 ; low so set bsf FLAG_RM,0 ; ready for next remote control input goto CLR_RMF CLR_0 bcf PORTA,1 ; high so clear bsf FLAG_RM,0 ; ready for next remote control goto CLR_RMF
ONE btfsc FLAG0,0 ; if set then test mode goto CLR_RMF btfsc FLAG_RM,0 ; if set then already passed here goto CLR_RMF btfsc A_STAT,0 ; if set then toggle goto TOG_1 ; toggle (alternate mode) bsf PORTA,0 ; output high bsf FLAG_RM,0 ; set continuous mode goto CLR_RMF TOG_1 btfsc PORTA,0 ; if high clear goto CLR_1 bsf PORTA,0 ; low so set bsf FLAG_RM,0 ; ready for next remote control input goto CLR_RMF CLR_1 bcf PORTA,0 ; high so clear bsf FLAG_RM,0 ; ready for next remote control goto CLR_RMF
TWO btfsc FLAG_RM,0 ; if set then already passed here goto CLR_RMF btfsc B_STAT,7 ; if set then toggle goto TOG_2 ; toggle (alternate mode) bsf PORTB,7 ; 2 output high bsf FLAG_RM,0 ; set continuous mode goto CLR_RMF TOG_2 btfsc PORTB,7 ; if high clear goto CLR_2 bsf PORTB,7 ; low so set bsf FLAG_RM,0 ; ready for next remote control input goto CLR_RMF CLR_2 bcf PORTB,7 ; high so clear bsf FLAG_RM,0 ; ready for next remote control goto CLR_RMF
THREE btfsc FLAG_RM,0 ; if set then already passed here goto CLR_RMF btfsc B_STAT,6 ; if set then toggle goto TOG_3 ; toggle (alternate mode) bsf PORTB,6 ; output high bsf FLAG_RM,0 ; set continuous mode goto CLR_RMF TOG_3 btfsc PORTB,6 ; if high clear goto CLR_3 bsf PORTB,6 ; low so set bsf FLAG_RM,0 ; ready for next remote control input goto CLR_RMF CLR_3 bcf PORTB,6 ; high so clear bsf FLAG_RM,0 ; ready for next remote control goto CLR_RMF FOUR btfsc FLAG_RM,0 ; if set then already passed here goto CLR_RMF btfsc B_STAT,5 ; if set then toggle goto TOG_4 ; toggle (alternate mode) bsf PORTB,5 ; output high bsf FLAG_RM,0 ; set continuous mode goto CLR_RMF TOG_4 btfsc PORTB,5 ; if high clear goto CLR_4 bsf PORTB,5 ; low so set bsf FLAG_RM,0 ; ready for next remote control input goto CLR_RMF CLR_4 bcf PORTB,5 ; high so clear bsf FLAG_RM,0 ; ready for next remote control goto CLR_RMF FIVE btfsc FLAG_RM,0 ; if set then already passed here goto CLR_RMF btfsc B_STAT,4 ; if set then toggle goto TOG_5 ; toggle (alternate mode) bsf PORTB,4 ; output high bsf FLAG_RM,0 ; set continuous mode goto CLR_RMF TOG_5 btfsc PORTB,4 ; if high clear goto CLR_5 bsf PORTB,4 ; low so set bsf FLAG_RM,0 ; ready for next remote control input goto CLR_RMF CLR_5 bcf PORTB,4 ; high so clear bsf FLAG_RM,0 ; ready for next remote control goto CLR_RMF SIX btfsc FLAG_RM,0 ; if set then already passed here goto CLR_RMF btfsc B_STAT,3 ; if set then toggle goto TOG_6 ; toggle (alternate mode) bsf PORTB,3 ; output high bsf FLAG_RM,0 ; set continuous mode goto CLR_RMF TOG_6 btfsc PORTB,3 ; if high clear goto CLR_6 bsf PORTB,3 ; low so set bsf FLAG_RM,0 ; ready for next remote control input goto CLR_RMF CLR_6 bcf PORTB,3 ; high so clear bsf FLAG_RM,0 ; ready for next remote control goto CLR_RMF SEVEN btfsc FLAG_RM,0 ; if set then already passed here goto CLR_RMF btfsc B_STAT,2 ; if set then toggle goto TOG_7 ; toggle (alternate mode) bsf PORTB,2 ; output high bsf FLAG_RM,0 ; set continuous mode goto CLR_RMF TOG_7 btfsc PORTB,2 ; if high clear goto CLR_7 bsf PORTB,2 ; low so set bsf FLAG_RM,0 ; ready for next remote control input goto CLR_RMF CLR_7 bcf PORTB,2 ; high so clear bsf FLAG_RM,0 ; ready for next remote control goto CLR_RMF EIGHT btfsc FLAG_RM,0 ; if set then already passed here goto CLR_RMF btfsc B_STAT,1 ; if set then toggle goto TOG_8 ; toggle (alternate mode) bsf PORTB,1 ; output high bsf FLAG_RM,0 ; set continuous mode goto CLR_RMF TOG_8 btfsc PORTB,1 ; if high clear goto CLR_8 bsf PORTB,1 ; low so set bsf FLAG_RM,0 ; ready for next remote control input goto CLR_RMF CLR_8 bcf PORTB,1 ; high so clear bsf FLAG_RM,0 ; ready for next remote control goto CLR_RMF NINE btfsc FLAG_RM,0 ; if set then already passed here goto CLR_RMF btfsc B_STAT,0 ; if set then toggle goto TOG_9 ; toggle (alternate mode) bsf PORTB,0 ; output high bsf FLAG_RM,0 ; set continuous mode goto CLR_RMF TOG_9 btfsc PORTB,0 ; if high clear goto CLR_9 bsf PORTB,0 ; low so set bsf FLAG_RM,0 ; ready for next remote control input goto CLR_RMF CLR_9 bcf PORTB,0 ; high so clear bsf FLAG_RM,0 ; ready for next remote control goto CLR_RMF
end
