Bluetooth Programming
OP #2603310
Hello all,
I need some help from u.
My new project on Bluetooth programming for that i have BluecontrolCL/1
Adapter. one can see datasheet from this link.
 http://www.blueserial.de/pdf/BlueControl_Datasheet.pdf
I have configure this control as Slave with RS232
115200,8,None,1,Hardware and for AT command 1000 +++ as wrote in
Datasheet.
I have SPP Slave with COM3 and BS Config with COM5.
In Pc I have Win7 & terminal Program "TeraTerm".
In TeraTerm I give the serial connection to COM3. I configure Serial
Port COM3 same as Bluecontrol (115,200.8, None, 1, hardware).
with 'Local Echo' on.
Now i write AT command on Teraterm, but the problem is I got no responce
from controller. Why?
Accually my work is, this bluecontroller inserted with another machine.
Using bluetooth i transfer one Data file from this controller to
Notepad. (both have Bluetooth). For that i have to use C language for
writting program.
If anyone know how can i fulfil this task, pls help me.
pls reply me soon.
Max
