EmbDev.net
Forum: Analog Circuits Soldering station Ersa RDS-80
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Leonid S. (leo62)
Rate this post
useful
not useful
Soldering station Ersa RDS-80. A diode or zener diode with a gray stripe
is leaking.
We need help in identifying this part and its denominations.
: Moved by Moderator
von argos (Guest)
Rate this post
useful
not useful
Below you can find a very crude schematic. Looks like the diode in
question, probably a generic silicon model (1N4148 or similar), protects
the switching transistor from reverse current/voltage.
https://www.fingers-welt.de/phpBB/viewtopic.php?t=7176
Rate this post
useful
not useful
All diodes 1N4148 with a black stripe, and this one with a gray.
I would like to get a specific answer on this detail.
von OSchlaffel (Guest)
Rate this post
useful
not useful
Zener diode
  Vz   |\'|  Vf
          Vf
   . Vz |
Why do you think the diode is leaking?
von Steven (Guest)
Rate this post
useful
not useful
Leonid S. wrote:
> A diode or zener diode with a gray stripe is leaking.
What do you mean if you say "leaking".
Please show the characteristic curve.
Rate this post
useful
not useful
Tester readings in diode test mode.
: Edited by User
von Steven (Guest)
Rate this post
useful
not useful
What are these numbers?
Rate this post
useful
not useful
The tester displays the voltage drop in millivolts.
https://www.youtube.com/watch?v=3ET6FU3mKuU&t=90s
: Edited by User
Rate this post
useful
not useful
Eventually BAS81, 82, 83, 85, 86
Rate this post
useful
not useful
Rate this post
useful
not useful
von false friend (Guest)
Rate this post
useful
not useful
OSchlaffel wrote:
> Eventually
Mal nachschlagen!
Rate this post
useful
not useful
OSchlaffel wrote:
> В итоге BAS81, 82, 83, 85, 86
Many thanks.
: Edited by User
von With me is not good cherry eating (Guest)
Rate this post
useful
not useful
false friend wrote:
> OSchlaffel wrote:
>> Eventually
> Mal nachschlagen!
My dear mister choral society, I think I am spidering, why are you
making down your collegue in full trains. His tip shines to be first
cream. I would like to let me out but I will make me on the socks.
Rate this post
useful
not useful
I'm sorry, I have a jump in the bowl and I hope I did not walk on
anybody's bisquit
Rate this post
useful
not useful
Leonid S. wrote:
> Many thanks.
Hello Leonid,
the BAS8x could possibly be that diode you're looking for. MELF diodes
with one grey stripe is only the BAS8x ones.
Actually, as I saw, are these ones only awailable from Vishay, note,
that this ones from Vishay have a black stripe instead of the grey one.
But the parameter should be equivalent as can be seen in the datasheet.
Verify therefore other photos of the RDS80 board. You'll find some with
that diode have a black stripe.
But could you find out why the diode has become faulty?
The SOT23 device (possibly a transistor), which is connected to that
diode, could be faulty too.
You also have to check other components become possibly faulty.
What is the matter with that soldering station?
Regards
von Netzbeschmutzer (Guest)
Rate this post
useful
not useful
> anybody's bisquit
Silly boy, but that german sayings literally translated into English
sound funny...
Rate this post
useful
not useful
Netzbeschmutzer wrote:
> Silly boy
My dear mister choral society, when I read this I looked stupidly out of
the laundry. It is not sausage, because of language like this the forum
is  transforming into a juice shop.
Rate this post
useful
not useful
You are great! You made me laugh head off. What a pity, Englishmen will
not really understand your great jokes. Please keep on joking in the
"juice shop"!
Rate this post
useful
not useful
OSchlaffel wrote:
> Вы также должны проверить, что другие компоненты могут быть
> неисправными.
> Что с той паяльной станцией?
  The station has been operating for over 10 years. She began to
experience similar symptoms described here:
Similarly, the 3b smd pnp transistor sot-23 (bc856) and this unknown
diode were heated.
   All other elements are working and this transistor next to the diode
is also working. I assume that the transistor opens when the triac is
closed by the command from the processor for
 supplying voltage +5 v at the time of measuring the resistance of the
soldering iron heater.
   Also, for this unknown diode at a certain moment, a voltage of 24V is
suitable.
the soldering iron heats up when the triac is closed.
   There were cases when the plug came off when working with the
soldering station
soldering iron cord. Perhaps at this moment without load, the process
failed and both voltages + 5v and an alternating voltage of 24v were
encountered on this ill-fated diode, which was the result of a
malfunction.
    Apparently it was a Schottky diode, I put 1N4148. The station is
working properly now, time will tell.
: Edited by User
Rate this post
useful
not useful
Hi Leonid,
nice to hear that your soldering station is now working.
With a 1N4148 it should be functioning as well as withe the BAS8x ones.
But if you order some parts in the future so also place some BAS8x ones
to your order Maybe the 40V (BAS81) type should be good enough, but I
would choose the 60V (BAS83) to ensure a safety margin.
Than by time I would replace the 1N4148 by the BAS83.
Regards
Rate this post
useful
not useful
I have already ordered in the online store (BAS83) and I definitely want
to change 1n4148.
: Edited by User
Rate this post
useful
not useful
The diode is in the voltage divider, and takes an active part in
measuring the resistance heating element of the soldering iron. From
characteristics depends temperature.
: Edited by User
von Lubi (lubi)
Rate this post
useful
not useful
somebody now the exact numbers of the thing i just  can  read thats a
ATMLH820 but can not read anymore is short the numbers the other thing
is that i can't find somthing with ATMLH820  found something with
ATMLH822  i am  not sure if is the same .
von Messi 9. (Company: group) (maxwellaa697)
Rate this post
useful
not useful
von Steffen E. (steffene)
Rate this post
useful
not useful
So it seems this is about the EEPROM bottom left on your attached pic?
No guarantees, I often just quickly glare over the contents of  sites
and documents
So "ATMLH820" is just *"ATMH" + date code* and is not sufficient info to
identify that EEPROM,  because you can find different Atmel products
with "ATMLH820"
But here are some indicators for what that part could be, NO GUARANTEES
Here somebody states that it is an Atmel 24C02, alongside your picture
of the pcb. He writes "Speicher: Atmel 24C02". One can barely see the
characters of the second line, but looks like "24C02BN" to me
Beitrag "Re: RDS-80 verhält sich seltsam"
Here there is a pcb from elektroda.pl that seems to look like the one
you are showing, but there is an EEPROM from ST on that spot, an ST
24C02, which maybe might be compatible to your Atmel chip
see also attachment
https://www.elektroda.pl/rtvforum/topic3450385.html
So maybe your part might be an AT24C02x, based on all the above
Just to show an example of an AT24C02, the first attachment shows an
Atmel 24C02B with date code "ATMLH820" and product code "02B"next to the
data sheet marking info
Atmel 24C02b data sheet
https://ww1.microchip.com/downloads/en/devicedoc/doc5126.pdf
Source for the  Atmel 24C02 pic
https://romiani.com/product/atmlh820/
: Edited by User
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
