EmbDev.net
Forum: Analog Circuits I burnt my PZEM-061 AC volt ammeter
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Syed (Guest)
Rate this post
useful
not useful
I would like to repair my AC volt ammeter PZEM-061 which got burnt due
to connecting an AC dimmer switch to it ( I had made using Triac BTA41 )
but there was no load on the dimmer, I just rotated the pot to check any
changes in voltage.
I have checked the 50ohm resistor and 1mf capacitor are good but dont
know which component got damaged.
Please help me repair the PZEM-061 as its very useful tool for me.
Thanks in advance.
: Moved by Moderator
von Franko P. (sgssn)
Rate this post
useful
not useful
Hi, seems you're joking;
The item (resistor?) between the connector and the big capacitor looks
burnt. Don't you see?
regards
Gerhard
von Syed (Guest)
Rate this post
useful
not useful
Yes, It is burnt but its showing the correct 50ohms value on MM. I
removed from pcb and checked as you too doubted it. Then I checked the
diode M7 its also fine then I tested the zener diode which is giving
zero ohms in both the directions.
I will remove it from pcb and test again to reconfirm. Wondering whats
the value if it has to be replaced.
Apart from repairing the VA meter I would appreciate if someone can
explain what went wrong in my above testing which burnt my va meter
(PZEM-061).
Thanks Gerhard, for your response.
Regards,
Syed
von Syed (Guest)
Rate this post
useful
not useful
I removed the Zener from above pcb and it is shorted. It is showing
0ohms resistance in both directions.
Hope other components and chips are working.
I need the value of Zener diode for replacement.
Thanks in advance for helping me in repairing my VA meter.
Regards,
Syed
von Mario P. (Guest)
Rate this post
useful
not useful
there is a description for the powersupply in this device. Maybe it
helps?
Beitrag "Kompliziertes Kondensatornetzteil"
Mario P.
von Toxic (Guest)
Rate this post
useful
not useful
Syed wrote:
> Wondering whats
According to the german thread it's a 12V zener diode.The TO of the
german thread also replaced the 1uF X2 capacitor with a 0.33uF X2 to
reduce the heat of the 100 Ohm resistor.He also wrote that the voltmeter
works fine with 3.3V and just draws 1mA
Regarding your triac problem.
The 100 Ohm resistor (in series with the X2 capacitor) reduces the
inrush current for the zener diode.Without this resistor it wouldn't
take long to short out the zener diode.
Just imagine:You connect the voltmeter exactly at the time when the
mains voltage reaches it's maximum value and the X2-capacitor is
completely discharged.You would get a huge inrush current(10,20...50
amps) to charge the X2 capacitor.This current must be reduced to an
acceptable level.Maybe to 2 amps or less.The capacitor will charge up
quite quickly in a very short time,so that a zener diode can cope with
it.
I am now assuming(!) the following:
The constant sharp rise of the triac controlled voltage always hurts the
zenerdiode constantly with - let's say - 2A in rush current but in a
manner that is worse than it would be with a pure sine wave.
English is not my native language so it's a bit difficult for me to
exactly explain what I actually want to say.
Anyway: With LTspice one could exactly simulate what's really going
on,when a capacitor power supply is fed with an "unusual signal"
I think that by replacing the zener diode your voltmeter should be fine
again.
But there is something else that makes me wonder.Why is that inrush
current limiting resistor in such a bad condition?Even if the Diode
fails it should not cause any damage to it.Maybe it's not properly
designed or the Chinese are well aware of it and kept it that way to
make the voltmeter as cheap as possible...Should your voltmeter work
again,I would probably try to increase the value of the resistor and
reduce the value of the X2 capacitor.Saves heat and money.
von Toxic (Guest)
Rate this post
useful
not useful
I might not be that wrong at all.I just simulated your circuit with
LTspice.The first picture shows the voltmeter connected normally to the
mains.The second picture shows it connected to a simple phase dimmer.
If you compare the 2 pictures you will see that the zener diode is
constantly hit with a 6A pulse every 10ms if the phse dimmer is in use
which in the end lead to the diode's demise.
I also uploaded the LTspice files so that other users can simulate the
circuit themselves and correct me if I did something wrong or
misinterpreted the diagrams.I am not Einstein - at least not yet 😉
von Syed (Guest)
Rate this post
useful
not useful
I am very happy to inform that my VA meter is working now :). I didn't
find the smd zener in my market but i got IN4742a. I kept the rest of
the components as is because they were all ok except zener.
Hope that the meter works well with 4742a.
I am really thankful, Toxic for your help and the efforts you have put
down to understand and resolve my issue. I must appreciate your
professional approach and I am just a learner in electronics and keep
making small gadgets for utility.
By the way your English is far superior and you have good command in
expressing the technicalities. :)
Once again thanks for your help. I would surely get in touch with you if
I face any other issues.
But you are no less than Einstein for me :D
Regards,
Syed
von Toxic (Guest)
Rate this post
useful
not useful
Well done and I really mean it.
For a beginner not bad: you found the faulty part and replaced it
yourself which can sometimes be a bit tricky.The diode you bought should
be working fine.
Let's not forget  @Mario P. for posting the link.
Note:
Never use a simple phase dimmer as a (variable) voltage source for
complex devices like TVs,Amplifiers etc. They usually expect a pure sine
wave.
Simple phase dimmer can be used to dim old fashioned incandescent bulbs
as they just contain a purely resistive wire and not complex electronic
parts like in a modern Led bulb.
von Syed (Guest)
Rate this post
useful
not useful
Actually I made this dimmer/speed control circuit for my old drill
machine which does not have speed control. It always operated on full
speed. With this module I got more control in doing different jobs.
I got very good software LTspice which can really help to see how the
circuits perform.
Thanks & regards,
Syed
von Eduardo S. (Company: ninguna) (edusolano)
Rate this post
useful
not useful
help me: Lima Peru, by mistake I connected the AC 220v current where the
thyroid coil is connected and it exploded, then I inverted the cables in
their correct position, but now the screen turns on, the button works
normally, the rest blinks, but it does not measure the current that
passes What has burned and be able to search and replace it and try?
Help me, what can I change? I'll send you a photo, I've already removed
the zener diode (of what value is it) and mine doesn't have the R13
resistor. Apparently it burned but you can't see anything. The diode
measures 1 on one side and 800 on the other. I attached photos. I
removed it by carefully cutting the capacitor and desoldering the zener
diode to take a photo. I want to know the values ​​of the zener diode
resistor to try.
von Edson (Guest)
Rate this post
useful
not useful
Boa Noite, o seu problema não é nenhum componente,  os bornes do tc esta
com a trilha rompida, o resistor cmd R500 que é de 0,5 homs ele é o R13
faça o teste de continuidade do bornes até o R7 e o outro parafuso é o
R8 é só seguir as trilhas. Boa Sorte
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
