EmbDev.net
Forum: FPGA, VHDL & Verilog Assignment of the Ports / Signals (Lattice Diamond)
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Pascal (Guest)
Rate this post
useful
not useful
Hello all
I use the IDE Diamond from Lattice.
VHDL beginner (!) ...but there is already a question to be asked.
As far as I can see, I only define in the VHDL code if a port is an
input / output. But when I synthesize the design, all inputs are
signaled as clock signals, which is not correct. The should be assigned
as normal inputs
Hope my problem is a bit more understandable with the pictures :-)
Question: How can I make TX-uC and RX1-RX8 normal inputs?
Many thanks for your help (in advance)
Pascal
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Pascal wrote:
> all inputs are signaled as clock signals, which is not correct.
Maybe you don't want or expect them to be clock inputs, but your
code is written in a way that the synthesizer recognizes all those input
signals as clocks.
As often the problem is not in the supplied snippet of code, it is
buried somewhere else in the code itself. So simply attach the
questionable VHDL file.
Never ever post any source code as a picture. Its very difficult to edit
source code delivered as a picture. Or to cut and paste a snippet of
code out of such a picture. Got the trick?
BTW1: why tose old fashioned std_logic_arith package out of the last
millenium. Use the numeric_std instead.
BTW2: why TX1..TX8 when VHDL allows you to define a vector TX(1 to 8)?
BTW3: why TX1..TX8 when usually a hardware designer would use TX7..TX0
or better TX(7 downto 0) for an 8-bit bus?
BTW4: you could ask the question in German by using the German part of
the forum: https://www.mikrocontroller.net/forum/fpga-vhdl-cpld
: Edited by Moderator
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
