Karte Clonen
Gast #7458530
bin Anfänger, würde gerne meine Karte Clonen, habe einen China Lesegerät der zeigt mir beim Scannen IC Type-A an.
Wenn ich die Software benutze wo dabei war (wCopy nfcPro) bekomme ich beim lesen diese Meldung: The Sak of the card is an unsupported type. You can also try to check Card type forced conversion to standard SAK08 card (for special type of SAK) and try again.
Wenn ich dann unter Einstellungen SAK08 anklicke, fängt es an den Key A und B zu suchen, leider ohne Erfolg. Es läuft eine Schleife die unendlich scheint. Mifare Classic 'Dark-Side' Attack to reover at least 1 key for card where NO keys are known.
Key A sectors: Key B sectors:Attack: 3-A diff Nt:0 auths:0 Attack: 3-A diff Nt:1 auths:1 Attack: 3-A diff Nt:2 auths:2 Attack: 3-A diff Nt:2 auths:3 Attack: 3-A diff Nt:2 auths:4 Attack: 3-A diff Nt:2 auths:5 Attack: 3-A diff Nt:2 auths:6 Attack: 3-A diff Nt:2 auths:7 Attack: 3-A diff Nt:2 auths:8 Attack: 3-A diff Nt:2 auths:9 Attack: 3-A diff Nt:2 auths:10 Attack: 3-A diff Nt:2 auths:11 Attack: 3-A diff Nt:2 auths:12 Attack: 3-A diff Nt:2 auths:13 Attack: 3-A diff Nt:2 auths:14 Attack: 3-A diff Nt:2 auths:15 Attack: 3-A diff Nt:2 auths:16 Attack: 3-A diff Nt:2 auths:17 Attack: 3-A diff Nt:2 auths:18 Attack: 3-A diff Nt:2 auths:19 Attack: 3-A diff Nt:2 auths:20 Attack: 3-A diff Nt:2 auths:21 Attack: 3-A diff Nt:2 auths:22 Attack: 3-A diff Nt:2 auths:23 Attack: 3-A diff Nt:2 auths:24 Attack: 3-A diff Nt:2 auths:25 Attack: 3-A diff Nt:2 auths:26 Attack: 3-A diff Nt:2 auths:27 Attack: 3-A diff Nt:2 auths:28 Attack: 3-A diff Nt:2 auths:29 Attack: 3-A diff Nt:2 auths:30 Attack: 3-A diff Nt:2 auths:31 Attack: 3-A diff Nt:2 auths:32 Attack: 3-A diff Nt:2 auths:33 Attack: 3-A diff Nt:2 auths:34 Attack: 3-A diff Nt:2 auths:35 Attack: 3-A diff Nt:2 auths:36 Attack: 3-A diff Nt:2 auths:37 Attack: 3-A diff Nt:2 auths:38 Attack: 3-A diff Nt:2 auths:39
habe bis auths: 10105 mal gewartet denke aber das es noch viel länger geht.
Danke
Moderator Persönliche Seite #7458572
Okay, Software ist wCopy nfcPro. Offenbar geht es um RFID-Karten.
Auf deutsch: "Der Kartentyp wird von dieser Software nicht unterstützt.". Du hast offenbar die falsche Software.
Welche Sak wird denn ausgegeben? Hier eine Liste von möglichen Saks:
https://nfc-tools.github.io/resources/standards/iso14443A/
Ob diese Liste vollständig ist, entzieht sich meiner Kenntnis.
Auf deutsch: "Du kannst ja mal so tun, als ob die Karte eine 'Mifare Classic' ist und es nochmal probieren".
Fazit:
Deine Software unterstützt den Kartentyp nicht, da die Sak für die SW unbekannt ist. Scheinbar verhält sich die Karte auch nicht wie eine Mifare Classic. Wirf die Software weg und versuche eine andere. Solange Du die Sak hier nicht angibst, können wir Dir auch keine SW nennen, welche die Sak (und damit den Kartentyp) unterstützt. Hinzu kommt, dass eventuell auch der Leser für diese Karte ungeeignet ist.
Also: Ohne nähere Angaben ist das ein Stochern im Nebel.
Gast #7458848
wieso illegal? würde gerne aus der Scheckkartenformat Karte es auf einen Schlüsselanhänger Chip kopieren, somit wäre es besser zum mitnehmen.
Lesegerät ist ein 10 frequenz NFC Smart Card Reader Writer RFID Kopierer Duplizierer 125KHz 13,56 MHz USB Fob Programmierer Kopie Verschlüsselt Schlüssel karte UID
kann den Aliexpress link senden wenn es erlaubt ist. https://de.aliexpress.com/item/4000286080220.html?spm=a2g0o.order_list.order_list_main.15.10505c5fCDwbdB&gatewayAdapt=glo2deu
Gast #7458852
Welche Software wäre gut? Danke
Frank M. schrieb:
Fazit:
Gast #7458856
Da ist mein Foto drauf, und habe dafür 15€ bezahlt, dachte wäre dann meins. ;-)
Schätze das ich hier falsch bin, es gibt wenige Helfer, mehr Klugsch...
#7458906
Vom Vermieter brauchst Du auch einen Berechtigungsschein wenn Du dir einen Schlüssel für die Schließanlage nachmachen lassen willst. Der Schlüssel bleibt Eigentum des Vermieters. Warum soll das mit der Zugangskarte deines Arbeitgebers anders sein?
#7458931
Das stimmt so nicht. Der Schlüssel gehört dem, der ihn bezahlt hat, nur der Vermieter kann beim Auszug die Vernichtung einfordern.
#7458933
In der Regel wird der Arbeitgeber nicht erlauben, dass du Kopien der Zutrittskarte erstellst. Ob die Karte selbst jetzt dir gehört oder dem Arbeitgeber, ist gar nicht so wichtig. Die darauf enthaltenen Daten, also die Informationen für die Zutrittsberechtigung, gehören dem Arbeitgeber.
Die Karte ist verschlüsselt, damit du keine Kopien machen kannst. Das Umgehen von Kopierschutzmaßnahmen ist nach EU-Recht illegal.
Gast #7459174
Peter M. schrieb:
Du müsstes erstmal rausfinden was das für ne Karte ist. Wenn es ne DESfire brauchst du das gar nicht erst versuchen.
Wenn es ne Mifare Classic wie in deinem Versuch, dann sollte das auch eigentlich nur Sekunden dauern. Daher wird es vermutlich keine sein.
Mit Android Handy ausgelesen: UID: XXXXXXXXXXX 7byte,CL2 ISO/IEC 14443, Type A ATQA: 0041 SAK: 20 ATS
Tag Type and Manufacturer: Unknown
„Wer Rechtschreibfehler findet, darf sie behalten.“
Moderator Persönliche Seite #7459189
Vincenzo schrieb:
SAK: 20
Wenn Du in den Link reinschaust, den ich hier gestern gepostet habe, würdest Du sehen, dass "SAK 20" entweder eine "IBM JCOP31 v2.4.1" oder eine "IBM JCOP41 v2.2" ist.
Schrieb ich schon gestern: Deine Software ist zu dumm. Es kennt den Kartentyp mit der SAK 20 nicht, obwohl der Hersteller IBM und die Karte JCOPx1 durchaus bekannt sind.
Fazit: Vergiss es. Glücklicherweise ist Deine SW zu dumm dafür. Und das ist gut so. Du willst offenbar einer weiteren Person Zugriff zu Räumen geben, in denen sie nichts zu suchen hat.
P.S.
Warum schreibst Du hier unter einem 2. Nicknamen weiter? Das ist nicht gestattet, wie oben schon bemerkt wurde.
Gast #7459198
Wendels B. schrieb:
Oh, und dann unter anderem Nick (laut Benutzungsbedingungen verboten) weitermachen mit einem neuen Wegwerfaccount. Das hatten wir (wohl) noch nicht.
Was schreibst Du für Müll? ist Dir langweilig? keine anderen Hobbys?
Es ist alles wie gehabt, Kindergarten....
Gast #7459206
Frank M. schrieb:
Vincenzo schrieb:
SAK: 20
P.S.
danke für deine Hilfe. Ich möchte zu 100% keine weitere Person zugriff gestatten. Um Gottes willen!
Es sollte vom Kartenformat ins Anhängerformat übergehen, weil mir die Karte im Geldbeutel schon paar kaputt gegangen ist, als Schlüsselanhänger wäre es Praktisch gewesen. War eine Dumme Idee. Werde mich jetzt wieder abmelden und mich nicht mehr anmelden. Damit mache ich einige gelangweilte Poster hier glücklich.
Werde auch nicht mehr reinschauen, spart euch die Zeit mit Besserwisser Kommentare.
