question LCD LED IPS
OP #7847772
If you store an any IPS LED LCD panel without using it for a long time (many years), will the pixels develop dead and stuck pixels? Can liquid crystals settle over time, leading to slow response times or "stuckness", where they may not change state correctly when turned on after years of inactivity? Do LEDs and backlights die or lose efficiency?
#7850775
Fortunately, neither you nor me will be around to see that.
The max time constant is ($RETIREMENT_AGE-$AGE) This is the reason older developer become more risk taking :-D
To answer the original question. I think there is a maximal storage time, but no one can tell it, because it is not only the liquid, it is also the rubber connection of the glas to the pcb, humidity, temperature, sealed in nitrogene or not. And even if you only think about the liquid, it can be different from different glas maker. Another important point the glue to seal the glas together and how carefully it is done. If you look carefuly for example you can find devices that are 20-30 years old where the glas becomes dark.
Vanye
