A chipped, cracked or discoloured tooth can affect your confidence, and a badly damaged one can affect how you eat. The good news is that modern dentistry offers several ways to repair them. Two of the most common are crowns and veneers, and they solve different problems.
Here is how to tell them apart.
What Is a Zirconia Crown?
A crown is a cap that covers a tooth completely, restoring its shape, strength and appearance. A zirconia crown is made from a very strong ceramic. It is metal-free, which suits patients who prefer a more natural look, and it resists wear well, which is why it is used for both front and back teeth.
Crowns are usually recommended when a tooth is:
• Heavily decayed or worn down
• Cracked or weakened
• Treated with a root canal and needs protection
• Part of a bridge, where crowns support a replacement tooth
• What Are Composite Veneers?
Veneers are thin layers placed on the front of a tooth to improve its look. composite veneers use a tooth-coloured resin that is shaped and bonded directly onto the tooth. They are often chosen for small chips, minor gaps, uneven shapes and stains that whitening can't fix.
Compared with a crown, they usually need less removal of natural tooth, and they can often be adjusted or repaired later. The trade-off is that resin can stain or wear more over time than ceramic.
What About Bridges?
A bridge replaces a missing tooth by anchoring a false tooth to crowns on the teeth either side. It restores chewing and appearance without removable parts, but those supporting teeth must be reshaped, so it requires careful planning.
Understanding Zirconia Crown Price in Lahore
Patients often search for zirconia crown price in lahore before booking, but a single figure rarely tells the full story. Cost depends on:
• The number of crowns needed
• The quality and brand of the zirconia material
• The dental laboratory used to make it
• The dentist's training and experience
• Whether extra treatment, such as a root canal, is required first
Ask for an itemised estimate after your examination, and check what is included. A very low quote may reflect lower-quality materials or fewer follow-up visits.
Questions to Ask Before You Start
• Which material will be used, and why is it right for my tooth?
• How much of my natural tooth will be reshaped?
• How long should this restoration last with good care?
• What is the full cost, including follow-up?
Compare Calmly
It is reasonable to speak with more than one clinic. Many patients start by searching for a top dental surgeon in Lahore and comparing how each practice explains materials, planning and aftercare. Choose the team that explains things clearly and makes you feel at ease.
Restorative Care at Dental Surgeons
At Dental Surgeons, in Gulberg II, Lahore, crowns, bridges and veneers are planned around the individual patient, led by a consultant prosthodontist and supported by modern technology. Our aim is restorations that look natural and last.
Book Your Consultation
A consultation will show you which treatment suits your teeth and what to expect from start to finish.
Ready to restore your smile? Contact Dental Surgeons today to book your appointment.
