1 | $ make writefuses
2 | avrdude -F -p atmega644p -P /dev/cu.PL2303-00101324 -c stk500v2 -v -U hfuse:w:0x99:m \
3 | -U lfuse:w:0x64:m -U efuse:w:0xfc:m && \
4 | avrdude -F -p atmega644p -P /dev/cu.PL2303-00101324 -c stk500v2 -v -U hfuse:r:hfuse.txt \
5 | -U lfuse:r:lfuse.txt && \
6 | echo "High Fuse Bits: \c" && od -d hfuse.txt | head -n 1 | sed -e 's/0000000 *//' | xargs -i perl -e 'tr= unpack("B32", pack("N",{})); tr =~ s/.*([01]{4})([01]{4}) /; print "tr\n";' && echo "Low Fuse Bits: \c" && od -d lfuse.txt | head -n 1 | sed -e 's/0000000 *//' | xargs -i perl -e 'tr= unpack("B32", pack("N",{})); tr =~ s/.*([01]{4})([01]{4}) /; print "tr\n";'
7 |
8 | avrdude: Version 5.6, compiled on Apr 15 2009 at 17:54:59
9 | Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
10 |
11 | System wide configuration file is "/usr/local/CrossPack-AVR-20090415/etc/avrdude.conf"
12 | User configuration file is "/Users/frgo/.avrduderc"
13 | User configuration file does not exist or is not a regular file, skipping
14 |
15 | Using Port : /dev/cu.PL2303-00101324
16 | Using Programmer : stk500v2
17 | AVR Part : ATMEGA644P
18 | Chip Erase delay : 9000 us
19 | PAGEL : PD7
20 | BS2 : PA0
21 | RESET disposition : dedicated
22 | RETRY pulse : SCK
23 | serial program mode : yes
24 | parallel program mode : yes
25 | Timeout : 200
26 | StabDelay : 100
27 | CmdexeDelay : 25
28 | SyncLoops : 32
29 | ByteDelay : 0
30 | PollIndex : 3
31 | PollValue : 0x53
32 | Memory Detail :
33 |
34 | Block Poll Page Polled
35 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
36 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
37 | eeprom 65 10 128 0 no 2048 8 0 9000 9000 0xff 0xff
38 | flash 33 6 256 0 yes 65536 256 256 4500 4500 0xff 0xff
39 | lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
40 | lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
41 | hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
42 | efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
43 | signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
44 | calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
45 |
46 | Programmer Type : STK500V2
47 | Description : Atmel STK500 Version 2.x firmware
48 | Programmer Model: STK500
49 | Hardware Version: 2
50 | Firmware Version Master : 2.10
51 | Topcard : Unknown
52 | Vtarget : 5.2 V
53 | SCK period : 10.9 us
54 | Varef : 5.0 V
55 | Oscillator : 3.686 MHz
56 |
57 | avrdude: AVR device initialized and ready to accept instructions
58 |
59 | Reading | ################################################## | 100% 0.01s
60 |
61 | avrdude: Device signature = 0x1e960a
62 | avrdude: safemode: lfuse reads as 62
63 | avrdude: safemode: hfuse reads as 99
64 | avrdude: safemode: efuse reads as FF
65 | avrdude: reading input file "0x99"
66 | avrdude: writing hfuse (1 bytes):
67 |
68 | Writing | ################################################## | 100% 0.00s
69 |
70 | avrdude: 1 bytes of hfuse written
71 | avrdude: verifying hfuse memory against 0x99:
72 | avrdude: load data hfuse data from input file 0x99:
73 | avrdude: input file 0x99 contains 1 bytes
74 | avrdude: reading on-chip hfuse data:
75 |
76 | Reading | ################################################## | 100% 0.00s
77 |
78 | avrdude: verifying ...
79 | avrdude: 1 bytes of hfuse verified
80 | avrdude: reading input file "0x64"
81 | avrdude: writing lfuse (1 bytes):
82 |
83 | Writing | ################################################## | 100% 0.02s
84 |
85 | avrdude: 1 bytes of lfuse written
86 | avrdude: verifying lfuse memory against 0x64:
87 | avrdude: load data lfuse data from input file 0x64:
88 | avrdude: input file 0x64 contains 1 bytes
89 | avrdude: reading on-chip lfuse data:
90 |
91 | Reading | ################################################## | 100% 0.00s
92 |
93 | avrdude: verifying ...
94 | avrdude: 1 bytes of lfuse verified
95 | avrdude: reading input file "0xfc"
96 | avrdude: writing efuse (1 bytes):
97 |
98 | Writing | ################################################## | 100% 0.01s
99 |
100 | avrdude: 1 bytes of efuse written
101 | avrdude: verifying efuse memory against 0xfc:
102 | avrdude: load data efuse data from input file 0xfc:
103 | avrdude: input file 0xfc contains 1 bytes
104 | avrdude: reading on-chip efuse data:
105 |
106 | Reading | ################################################## | 100% 0.00s
107 |
108 | avrdude: verifying ...
109 | avrdude: 1 bytes of efuse verified
110 |
111 | avrdude: safemode: lfuse reads as 64
112 | avrdude: safemode: hfuse reads as 99
113 | avrdude: safemode: efuse reads as FC
114 | avrdude: safemode: Fuses OK
115 |
116 | avrdude done. Thank you.
117 |
118 |
119 | avrdude: Version 5.6, compiled on Apr 15 2009 at 17:54:59
120 | Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
121 |
122 | System wide configuration file is "/usr/local/CrossPack-AVR-20090415/etc/avrdude.conf"
123 | User configuration file is "/Users/frgo/.avrduderc"
124 | User configuration file does not exist or is not a regular file, skipping
125 |
126 | Using Port : /dev/cu.PL2303-00101324
127 | Using Programmer : stk500v2
128 | AVR Part : ATMEGA644P
129 | Chip Erase delay : 9000 us
130 | PAGEL : PD7
131 | BS2 : PA0
132 | RESET disposition : dedicated
133 | RETRY pulse : SCK
134 | serial program mode : yes
135 | parallel program mode : yes
136 | Timeout : 200
137 | StabDelay : 100
138 | CmdexeDelay : 25
139 | SyncLoops : 32
140 | ByteDelay : 0
141 | PollIndex : 3
142 | PollValue : 0x53
143 | Memory Detail :
144 |
145 | Block Poll Page Polled
146 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
147 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
148 | eeprom 65 10 128 0 no 2048 8 0 9000 9000 0xff 0xff
149 | flash 33 6 256 0 yes 65536 256 256 4500 4500 0xff 0xff
150 | lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
151 | lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
152 | hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
153 | efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
154 | signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
155 | calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
156 |
157 | Programmer Type : STK500V2
158 | Description : Atmel STK500 Version 2.x firmware
159 | Programmer Model: STK500
160 | Hardware Version: 2
161 | Firmware Version Master : 2.10
162 | Topcard : Unknown
163 | Vtarget : 5.2 V
164 | SCK period : 10.9 us
165 | Varef : 5.0 V
166 | Oscillator : 3.686 MHz
167 |
168 | avrdude: stk500v2_command(): command failed
169 | avrdude: stk500v2_recv(): checksum error
170 | avrdude: stk500v2_program_enable(): bad STK600 connection status: Unknown (0x64)
171 | avrdude: initialization failed, rc=-1
172 | avrdude: AVR device initialized and ready to accept instructions
173 | avrdude: Device signature = 0x000000
174 | avrdude: Yikes! Invalid device signature.
175 | avrdude: Expected signature for ATMEGA644P is 1E 96 0A
176 |
177 | avrdude done. Thank you.
178 |
179 | make: *** [writefuses] Error 1
