Hallo alle, ich habe hier ein kleines Problem: root@phyCORE-AM335x:~ lsusb Bus 001 Device 001: ID 1d6b:0002 Bus 001 Device 002: ID 04b4:6572 Bus 001 Device 003: ID 18a5:0243 Bus 001 Device 004: ID 1c9e:f000 Hier wurden die beiden neu eingesteckt: root@phyCORE-AM335x:~ [ 33.430877] usb 1-1.4: USB disconnect, device number 3 [ 35.454284] usb 1-1.4: new high-speed USB device number 5 using musb-hdrc [ 35.555541] usb 1-1.4: New USB device found, idVendor=18a5, idProduct=0243 [ 35.562805] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 35.570526] usb 1-1.4: Product: STORE N GO [ 35.574859] usb 1-1.4: Manufacturer: Verbatim [ 35.579437] usb 1-1.4: SerialNumber: 070B2A5AAD5D7139 [ 35.590576] scsi2 : usb-storage 1-1.4:1.0 [ 37.363525] usb 1-1.3: USB disconnect, device number 4 [ 44.764282] usb 1-1.3: new high-speed USB device number 6 using musb-hdrc [ 44.866363] usb 1-1.3: New USB device found, idVendor=1c9e, idProduct=f000 [ 44.873596] usb 1-1.3: New USB device strings: Mfr=3, Product=2, SerialNumber=4 [ 44.881317] usb 1-1.3: Product: USB Modem [ 44.885559] usb 1-1.3: Manufacturer: USB Modem [ 44.890228] usb 1-1.3: SerialNumber: 1234567890ABCDEF [ 44.903259] scsi3 : usb-storage 1-1.3:1.0 root@phyCORE-AM335x:/dev ls block ram10 tty20 tty54 bus ram11 tty21 tty55 char ram12 tty22 tty56 console ram13 tty23 tty57 cpu_dma_latency ram14 tty24 tty58 disk ram15 tty25 tty59 fd ram2 tty26 tty6 full ram3 tty27 tty60 i2c-1 ram4 tty28 tty61 input ram5 tty29 tty62 kmem ram6 tty3 tty63 kmsg ram7 tty30 tty7 log ram8 tty31 tty8 loop-control ram9 tty32 tty9 loop0 random tty33 ttyO0 loop1 rtc tty34 ttyO1 loop2 rtc0 tty35 ttyO2 loop3 rtc1 tty36 ttyO3 loop4 shm tty37 ttyO4 loop5 spidev1.0 tty38 ttyO5 loop6 stderr tty39 ttyS0 loop7 stdin tty4 ttyS1 mem stdout tty40 ttyS2 mmcblk0 tty tty41 ttyS3 mmcblk0p1 tty0 tty42 urandom mmcblk0p2 tty1 tty43 usbdev1.1 mmcblk1 tty10 tty44 usbdev1.2 mmcblk1p1 tty11 tty45 usbdev1.5 network_latency tty12 tty46 usbdev1.6 network_throughput tty13 tty47 vcs null tty14 tty48 vcs1 ppp tty15 tty49 vcsa psaux tty16 tty5 vcsa1 ptmx tty17 tty50 watchdog pts tty18 tty51 zero ram0 tty19 tty52 ram1 tty2 tty53 Wo finde ich denn jetzt bitte den USB Stick um diesen zu mounten? Auf dem Beaglebone (ist nun ein eigenes Board basiernd am phyCore-AM335 mit ptxdist gebautem Kernel/Filesystem) hatte ich da /dev/sdX und nach usb_modeswitch für den UMTS-Stick /dev/ttyUSBX. Nun leider nicht. Ich glaub es hat was mit den udev Rules zu tun kenne mich da aber nicht aus.
    Embedded Linux erkennt USB Stick aber /dev/sdd wird nicht angelegt? /dev/ttyUSB bei UMTS-Stick auch!
    Re: Embedded Linux erkennt USB Stick aber /dev/sdd wird nicht angelegt? /dev/ttyUSB bei UMTS-Stick a
  guck mal was $ tail -f /var/log/syslog beim an/abstecken sagt
    Re: Embedded L erkennt USB Stick aber /dev/sdd wird nicht angelegt? /dev/ttyUSB bei UMTS-Stick auch!
  Ok kann ich leider nun erst Montag schaun.
  Hier mal der Log, beim an/ab stecken: root@phyCORE-AM335x:~ tail -f /var/log/messages Jan 1 00:00:04 phyCORE-AM335x user.info kernel: [ 6.987731] scsi0 : usb-storage 1-1.3:1.0 Jan 1 00:01:05 phyCORE-AM335x auth.info login[681]: root login on 'ttyO0' Jan 1 00:02:12 phyCORE-AM335x user.info kernel: [ 135.071502] usb 1-1.3: USB disconnect, device number 3 Jan 1 00:11:13 phyCORE-AM335x user.info kernel: [ 676.259765] usb 1-1.4: new high-speed USB device number 4 using musb-hdrc Jan 1 00:11:13 phyCORE-AM335x user.info kernel: [ 676.361022] usb 1-1.4: New USB device found, idVendor=18a5, idProduct=0243 Jan 1 00:11:13 phyCORE-AM335x user.info kernel: [ 676.368255] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Jan 1 00:11:13 phyCORE-AM335x user.info kernel: [ 676.376007] usb 1-1.4: Product: STORE N GO Jan 1 00:11:13 phyCORE-AM335x user.info kernel: [ 676.380310] usb 1-1.4: Manufacturer: Verbatim Jan 1 00:11:13 phyCORE-AM335x user.info kernel: [ 676.384918] usb 1-1.4: SerialNumber: 070B2A5AAD5D7139 Jan 1 00:11:13 phyCORE-AM335x user.info kernel: [ 676.396484] scsi1 : usb-storage 1-1.4:1.0 [ 772.893615] usb 1-1.4: USB disconnect, device number 4 Jan 1 00:12:50 phyCORE-AM335x user.info kernel: [ 772.893615] usb 1-1.4: USB disconnect, device number 4 [ 777.229766] usb 1-1.4: new high-speed USB device number 5 using musb-hdrc [ 777.331024] usb 1-1.4: New USB device found, idVendor=18a5, idProduct=0243 [ 777.338287] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 777.346008] usb 1-1.4: Product: STORE N GO [ 777.350341] usb 1-1.4: Manufacturer: Verbatim [ 777.354919] usb 1-1.4: SerialNumber: 070B2A5AAD5D7139 Jan 1 00:12:54 phyCORE-AM335x user.info kernel: [ 777.229766] usb 1-1.4: new h[ 777.367218] scsi2 : usb-storage 1-1.4:1.0 igh-speed USB device number 5 using musb-hdrc Jan 1 00:12:54 phyCORE-AM335x user.info kernel: [ 777.331024] usb 1-1.4: New USB device found, idVendor=18a5, idProduct=0243 Jan 1 00:12:54 phyCORE-AM335x user.info kernel: [ 777.338287] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Jan 1 00:12:54 phyCORE-AM335x user.info kernel: [ 777.346008] usb 1-1.4: Product: STORE N GO Jan 1 00:12:54 phyCORE-AM335x user.info kernel: [ 777.350341] usb 1-1.4: Manufacturer: Verbatim Jan 1 00:12:54 phyCORE-AM335x user.info kernel: [ 777.354919] usb 1-1.4: SerialNumber: 070B2A5AAD5D7139 Jan 1 00:12:54 phyCORE-AM335x user.info kernel: [ 777.367218] scsi2 : usb-storage 1-1.4:1.0 [ 781.699066] usb 1-1.4: USB disconnect, device number 5 Jan 1 00:12:59 phyCORE-AM335x user.info kernel: [ 781.699066] usb 1-1.4: USB disconnect, device number 5
  Was ergibt $ lsmod|grep usb IMHO sollte - sofern nicht einkompiliert - das Modul usb_storage geladen sein. Kernel-Modul usb_storage laden: $ modprobe usb_storage
  Die Module sind eincompiliert. Also usb_storage und usb_serial. Ich bekomme einfach keine device nodes angelegt. :-( Hab schon alle möglichen Kernel optionen probiert.
  Hoer mal dmesg mit grep usb: root@phyCORE-AM335x:/etc dmesg |grep usb [ 0.138732] usbcore: registered new interface driver usbfs [ 0.139007] usbcore: registered new interface driver hub [ 0.139221] usbcore: registered new device driver usb [ 0.139404] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3 [ 0.139709] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1 [ 0.205108] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host) [ 0.205261] musb-hdrc musb-hdrc.0: dma type: pio [ 0.205657] musb0: Enabled SW babble control [ 0.205688] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) [ 0.205688] musb-hdrc: MHDRC RTL version 2.0 [ 0.205718] musb-hdrc: setup fifo_mode 4 [ 0.205749] musb-hdrc: 28/31 max ep, 16384/16384 memory [ 0.205749] musb-hdrc.0: bulk split disabled [ 0.205780] musb-hdrc.0: bulk combine disabled [ 0.206329] musb-hdrc musb-hdrc.0: USB OTG mode controller at d083c000 using PIO, IRQ 18 [ 0.206481] musb-hdrc musb-hdrc.1: dma type: pio [ 0.206848] musb1: Enabled SW babble control [ 0.206848] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) [ 0.206878] musb-hdrc: MHDRC RTL version 2.0 [ 0.206878] musb-hdrc: setup fifo_mode 4 [ 0.206909] musb-hdrc: 28/31 max ep, 16384/16384 memory [ 0.206939] musb-hdrc.1: bulk split disabled [ 0.206939] musb-hdrc.1: bulk combine disabled [ 0.206970] musb-hdrc musb-hdrc.1: MUSB HDRC host driver [ 0.207000] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1 [ 0.207122] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.207122] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.207153] usb usb1: Product: MUSB HDRC host driver [ 0.207153] usb usb1: Manufacturer: Linux 3.2.0-SMA musb-hcd [ 0.207183] usb usb1: SerialNumber: musb-hdrc.1 [ 0.208496] musb-hdrc musb-hdrc.1: USB Host mode controller at d083e800 using PIO, IRQ 19 [ 1.299133] usbcore: registered new interface driver rtl8192cu [ 1.305511] usbcore: registered new interface driver cdc_ether [ 1.311828] usbcore: registered new interface driver cdc_eem [ 1.321411] usbcore: registered new interface driver cdc_ncm [ 1.341522] usbcore: registered new interface driver cdc_acm [ 1.356140] usbcore: registered new interface driver cdc_wdm [ 1.362243] usbcore: registered new interface driver uas [ 1.373260] usbcore: registered new interface driver usb-storage [ 1.384674] usb 1-1: new high-speed USB device number 2 using musb-hdrc [ 1.391784] usbcore: registered new interface driver libusual [ 1.398345] usbcore: registered new interface driver usbserial [ 1.536102] usb 1-1: New USB device found, idVendor=04b4, idProduct=6572 [ 1.543151] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.550689] usb 1-1: Product: USB2.0 Hub [ 1.566741] usbcore: registered new interface driver usbserial_generic [ 1.573638] usbserial: USB Serial Driver core [ 1.585510] usbcore: registered new interface driver ftdi_sio [ 1.604553] usbcore: registered new interface driver option [ 1.621276] usbcore: registered new interface driver pl2303 [ 1.640228] usbcore: registered new interface driver qcserial [ 1.652801] usbcore: registered new interface driver sierra [ 2.053924] usbcore: registered new interface driver usbhid [ 2.059844] usbhid: USB HID core driver [ 2.064147] usbcore: registered new interface driver r8712u [ 2.345092] usb 1-1.1: new high-speed USB device number 3 using musb-hdrc [ 2.446014] usb 1-1.1: New USB device found, idVendor=18a5, idProduct=0243 [ 2.453247] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.460968] usb 1-1.1: Product: STORE N GO [ 2.465301] usb 1-1.1: Manufacturer: Verbatim [ 2.469879] usb 1-1.1: SerialNumber: 070B2A5AAD5D7139 [ 2.476501] scsi0 : usb-storage 1-1.1:1.0 [ 6.886138] usb 1-1.4: new high-speed USB device number 4 using musb-hdrc [ 6.988281] usb 1-1.4: New USB device found, idVendor=1c9e, idProduct=f000 [ 6.995513] usb 1-1.4: New USB device strings: Mfr=3, Product=2, SerialNumber=4 [ 7.003234] usb 1-1.4: Product: USB Modem [ 7.007476] usb 1-1.4: Manufacturer: USB Modem [ 7.012145] usb 1-1.4: SerialNumber: 1234567890ABCDEF [ 7.024291] scsi1 : usb-storage 1-1.4:1.0 [ 617.089538] usb 1-1.4: USB disconnect, device number 4 [ 620.417877] usb 1-1.1: USB disconnect, device number 3 [ 622.446197] usb 1-1.3: new high-speed USB device number 5 using musb-hdrc [ 622.547393] usb 1-1.3: New USB device found, idVendor=18a5, idProduct=0243 [ 622.554656] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 622.562377] usb 1-1.3: Product: STORE N GO [ 622.566711] usb 1-1.3: Manufacturer: Verbatim [ 622.571289] usb 1-1.3: SerialNumber: 070B2A5AAD5D7139 [ 622.581542] scsi2 : usb-storage 1-1.3:1.0 [ 1133.050323] usb 1-1.3: USB disconnect, device number 5 [ 1137.386199] usb 1-1.4: new high-speed USB device number 6 using musb-hdrc [ 1137.487457] usb 1-1.4: New USB device found, idVendor=18a5, idProduct=0243 [ 1137.494720] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 1137.502441] usb 1-1.4: Product: STORE N GO [ 1137.506774] usb 1-1.4: Manufacturer: Verbatim [ 1137.511352] usb 1-1.4: SerialNumber: 070B2A5AAD5D7139 [ 1137.521789] scsi3 : usb-storage 1-1.4:1.0 [ 1986.437377] usb 1-1.4: USB disconnect, device number 6 [ 1997.166198] usb 1-1.4: new high-speed USB device number 7 using musb-hdrc [ 1997.268310] usb 1-1.4: New USB device found, idVendor=1c9e, idProduct=f000 [ 1997.275573] usb 1-1.4: New USB device strings: Mfr=3, Product=2, SerialNumber=4 [ 1997.283294] usb 1-1.4: Product: USB Modem [ 1997.287536] usb 1-1.4: Manufacturer: USB Modem [ 1997.292205] usb 1-1.4: SerialNumber: 1234567890ABCDEF [ 1997.304199] scsi4 : usb-storage 1-1.4:1.0 Wie man sieht werden die Treiber geladen. Sind ja auch feste drin... Aber warum es nach scsi4 : usb-storage 1-1.4:1.0 kein node angelegt wird verstehe ich nicht. Liegt das an udev? Oder an irgendwelchen komischen Kernel optionen?
  Tuxi schrieb: > Liegt das an udev? Vermutlich. Nodes werden (seit Jahren) nur mehr von udev angelegt. Läuft ein udevd? und was steht in (sys/kernel/uevent_helper? (sollte leer sein)
  Ist leer!
root@phyCORE-AM335x:~ cat /sys/kernel/uevent_helper
Hier wird es gestartet:
root@phyCORE-AM335x:~ dmesg | grep udev
>[    4.257812] udevd[600]: starting version 182
Hier meine udev sachen:
root@phyCORE-AM335x:/etc/udev ls
udev.conf
root@phyCORE-AM335x:/etc/udev cd /lib/udev/
root@phyCORE-AM335x:/lib/udev ls
ata_id                     keymap                     scsi_id
cdrom_id                   keymaps                    udevd
collect                    mtd_probe                  write_cd_rules
findkeyboards              rule_generator.functions   write_net_rules
keyboard-force-release.sh  rules.d
root@phyCORE-AM335x:/lib/udev cd rules.d/
root@phyCORE-AM335x:/lib/udev/rules.d ls
42-usb-hid-pm.rules                75-net-description.rules
50-udev-default.rules              75-persistent-net-generator.rules
51-block.rules                     75-probe_mtd.rules
60-cdrom_id.rules                  75-tty-description.rules
60-persistent-alsa.rules           78-sound-card.rules
60-persistent-input.rules          80-drivers.rules
60-persistent-serial.rules         95-keyboard-force-release.rules
60-persistent-storage-tape.rules   95-keymap.rules
60-persistent-storage.rules        95-udev-late.rules
75-cd-aliases-generator.rules
Das System ist mit ptxdist gebaut worden und hat nur die Sachen dabei
die es dort bei ptxdist gibt.
  Tuxi schrieb: > Hier meine udev sachen: Willkommen in der udev-hell. Leider kann ich dir nicht weiterhelfen, ich bin selber heilfroh wenn das zeug bei mir tut. Wenn man aber ein bisschen LKML mitliest, dürfte es nur mehr eine Frage der zeit sein, bis der ganze Krempel von Linus persönlich rausgeschmissen wird.
  Hier mal was mein udev sagt beim ab und wieder anstecken vom UMTS-Stick root@phyCORE-AM335x:~ udevadm monitor monitor will print the received events for: UDEV - the event which udev sends out after rule processing KERNEL - the kernel uevent [ 39.346588] usb 1-1.4: USB disconnect, device number 3 KERNEL[39.349655] remove /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0/ host0/scsi_host/host0 (scsi_host) KERNEL[39.354752] remove /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0/ host0 (scsi) UDEV [39.355149] remove /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0/ host0/scsi_host/host0 (scsi_host) UDEV [39.355423] remove /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0/ host0 (scsi) KERNEL[39.357254] remove /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0 (usb) UDEV [39.358780] remove /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0 (usb) KERNEL[39.360520] remove /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.4 (usb) UDEV [39.363663] remove /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.4 (usb) [ 50.074432] usb 1-1.3: new high-speed USB device number 4 using musb-hdrc [ 50.176361] usb 1-1.3: New USB device found, idVendor=1c9e, idProduct=f000 [ 50.183593] usb 1-1.3: New USB device strings: Mfr=3, Product=2, SerialNumber=4 [ 50.191345] usb 1-1.3: Product: USB Modem [ 50.195587] usb 1-1.3: Manufacturer: USB Modem [ 50.200256] usb 1-1.3: SerialNumber: 1234567890ABCDEF KERNEL[50.203476] add /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1[ 50.213745] scsi1 : usb-storage 1-1.3:1.0 -1/1-1.3 (usb) KERNEL[50.208084] add /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.3/1-1.3:1.0 (usb) KERNEL[50.216385] add /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.3/1-1.3:1.0/ host1 (scsi) KERNEL[50.216660] add /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.3/1-1.3:1.0/ host1/scsi_host/host1 (scsi_host) UDEV [50.222184] add /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.3 (usb) UDEV [50.225296] add /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.3/1-1.3:1.0 (usb) UDEV [50.227463] add /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.3/1-1.3:1.0/ host1 (scsi) UDEV [50.229782] add /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.3/1-1.3:1.0/ host1/scsi_host/host1 (scsi_host)
  Ich habe nur "normale" 12.04-Linuxserver. Damit verglichen fehlt Dir mind. 40-usb_modeswitch.rules und/oder 80-udisks.rules
  Kann man es auch ohne den UDEV Kram machen? Habe den jetzt entfernt. Ist übrigens der 3.2 er Kernel.
  Habe im Kernel nun USBDEVICEFS aktiviert. Kann ich es darüber irgendwie hinbekommen? Es gibt irgendwie fast keine Infos dazu, was man machen muss wenn keine /dev/sd* angelegt wird. überall geht es nur um automount der Dinger nach /media... Genauso wieso kein /ttyUSB0 auftaucht. Ich hab hier ein Beaglebone stehen wo der Kram geht mit der Archlinux Dist. Kann ich da irgendwie die Files rüberkopieren? Oder direkt das ganze /root ?
  wahrscheinlich unterstützt der Treiber den Stick nicht. Sprich der meldet sich mit einer idVendor/idProduct die der Linux-Treiber nicht kennt. Mal den Stick an einen Windows-PC stecken und im Gerätemanager mal schauen womit er sich meldet. Hersteller, Vendor-ID ,Product-ID notieren und im Inet googeln ob auch andere damit unter Linux probleme haben/ lösungen haben.
  Das halte ich für extrem unwahrscheinlich.
  gerade noch mal deinen ersten Post gelesen: Die devices werden doch angelegt: "[ 44.764282] usb 1-1.3: new high-speed USB device number 6 using musb-hdrc" entsprechend unter /dev: "usbdev1.6" "[ 35.454284] usb 1-1.4: new high-speed USB device number 5 using musb-hdrc" entsprechend unter /dev: "usbdev1.5"
  Ja die gibt es auch da. Aber die kann man nicht mounten.
  Da kommt beim mounten immer: failed Block Device required.
  ... schrieb: > gerade noch mal deinen ersten Post gelesen: > Die devices werden doch angelegt: von Server: ein Wechsel zw. USB-SCSI-Ausgaben. Bei Deinem System auch? [ 4.065503] usb 2-5: new high-speed USB device number 4 using ehci-pci [ 4.205886] usb-storage 2-1:1.0: USB Mass Storage device detected [ 4.206271] scsi3 : usb-storage 2-1:1.0 ... [ 4.206845] usbcore: registered new interface driver usb-storage ... [ 5.207259] scsi 3:0:0:0: Direct-Access ADATA USB Flash Drive 1.00 PQ: 0 ANSI: 5 [ 5.207722] sd 3:0:0:0: Attached scsi generic sg4 type 0 [ 5.208479] sd 3:0:0:0: [sdc] 30883840 512-byte logical blocks: (15.8 GB/14.7 GiB) $ scsi_readcap -v /dev/sg4 Wenn sonst in Deinem System nichts SCSI-mäßiges gemountet ist, wird der erste Stick unter /dev/sda[0-9] ansprechbar sein.
  An dem Dingen ist nichts außer ein USB-Hub mit dem Stick und eine 2. SD-Card dran. Nach: [ 1997.304199] scsi4 : usb-storage 1-1.4:1.0 kommt nichts weiter. Die Nodes unter dev werden erst gar nicht angelegt. Mittlerweile habe ich auch das System wieder ohne udev aufgesetzt. Habe mich hieran orientiert: http://processors.wiki.ti.com/index.php/UsbgeneralpageLinux-v3p1
  Aha, hab was rausgefunden. Das Board nutzt mdev von der Busybox. udev wurde zwar gestartet als ich es mit hinein compiliert hatte aber dann lief praktsich udev & mdev parallel. Denke daher ging es nicht. Würde jetzt bei mdev bleiben. Kennt sich jemand damit aus? Oder hat vielleicht fertige Regeln zum mounten von USB-Sticks und UMTS-Sticks mit usb_modeswitch? Versuche folgendes zu Adaptieren: http://www.draisberghof.de/usb_modeswitch/bb/viewtopic.php?f=3&t=1091&view=unread Aber nach dem Script geht dieses ja nur wenn ich nur 1 USB-Device nutze oder? Speziell hier: #get the busnumber by incrementing the MINOR variable by one declare -i InterfaceNumber InterfaceNumber=$MINOR let "InterfaceNumber += 1" # create a symlink to the device. This is needed for # usbmodeswitch to find the device MOUNTPOINT=/dev/bus/usb/001/00$InterfaceNumber case "$ACTION" in add) huawei_add;; remove) huawei_remove;; esac Genauso: sd[a-z]([0-9]+) 0:0 660 * /etc/automount demnach müsste mein USB-Stick doch erstmal als sd* erkannt werden oder? Was ja schon nicht passiert. Wenn ich mdev -c ausführe (noch ohne die beim Link aufgeführten Änderungen) bekomme ich z.B. /dev/1-1.1 angelegt wenn der USB-Stick steckt.
  Wenn du sowieso den Kernel selbst baust, könntest du das devtmpfs aktivieren, Dann erzeugt (und entfernt) der Kernel die Device Nodes selbst. Und zwar genau passend zur vorhandenen Hardware. Das ist viel zuverlässiger, als es udev oder mdev können. CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y Aber unabhängig davon müsste der Kernel die Partionen auf dem Verbatim-Stick anzeigen?
  Hab gerade mal nachgeschaut. Die Sachen sind im Kernel aktiviert. Meine Kconfig ist im Anhang. Aber mdev wird bei busybox mit installiert. In der config steht aber fast nichts drin.
  Tuxi schrieb: > Hab gerade mal nachgeschaut. Die Sachen sind im Kernel aktiviert. > > Meine Kconfig ist im Anhang. mich irritiert der nicht leere Eintrag der Option CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug" udev ist der Nachfolger von hotplug. Ich würde ihn testweise entfernen.
  Hm, ja das Problem ist es basiert alles auf einem BSP von Phytec. Wobei ich die Files an ein eigenes Board angepasst habe und nun noch den Kernel passend bekommen muss. Im BSP ist udev nicht aktiviert. Jedoch TMPFS und MDEV und dieser Eintrag war auch bereits drin. Da ist irgendwie durcheinander. Wenn ich also udev aktivieren muss ich mdev rausnehmen. Auch das tmpfs? Und diesen genannten Eintrag?
  Tuxi schrieb: > Hm, ja das Problem ist es basiert alles auf einem BSP von Phytec. > Wobei > ich die Files an ein eigenes Board angepasst habe und nun noch den > Kernel passend bekommen muss. > Im BSP ist udev nicht aktiviert. Jedoch TMPFS und MDEV und dieser > Eintrag war auch bereits drin. MDEV ist nach "Building Embedded Linux Systems, Seite 193" BusyBox' UDEV-Ersatz: http://books.google.de/books?id=I-hVqkX6A9cC&pg=PA193&lpg=PA193&dq=TMPFS++MDEV&source=bl&ots=awJqi6LkWn&sig=3WgR6DL6EIEj0BRI2Y1fg8HW2ro&hl=de&sa=X&ei=mYoFVIuiJ6724QSe0oCIDw&ved=0CC4Q6AEwAQ#v=onepage&q=TMPFS%20%20MDEV&f=false MDEV http://git.busybox.net/busybox/plain/docs/mdev.txt Ist bei Dir MDEV installiert und aktiv?
  Ja das war es. Bin jetzt nocheinmal alles durchgegangen. Habe mdev und CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug" rausgenommen. Und statt dessen udev reingenommen. Bin jetzt mal gespannt ob es klappt...
  Tuxi schrieb: > Und statt dessen udev reingenommen. Das ist mit sicherheit falsch: Für udev muss der Eintrag (zumidnest der im /sys/kernel/uevent_helper) leer sein, udev fängt die Events auf andere Art und Weise ab.
  Also der Eintrag ist leer. Meine mit udev reingenommen, das ich udev bei der ptxdist config aktiviert habe und die rules vom Beaglebone rüberkopiert habe. Anschließend alle die Feler produziert haben wieder gelöscht. Startet jetzt auch alles schön, aber die Einträge kommen trotzdem nicht.
  Tuxi schrieb: > Startet jetzt auch alles schön, aber die Einträge kommen trotzdem nicht. was neues von dmesg?
  Hier das aktuelle dmesg:
[    0.171264] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.171264] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.171508] NET: Registered protocol family 1
[    0.171783] NetWinder Floating Point Emulator V0.97 (double
precision)
[    0.182708] VFS: Disk quotas dquot_6.5.2
[    0.182769] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[    0.183166] msgmni has been set to 496
[    0.184082] io scheduler noop registered
[    0.184112] io scheduler deadline registered
[    0.184173] io scheduler cfq registered (default)
[    0.184814] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.186065] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a
OMAP UART0
[    0.853851] console [ttyO0] enabled
[    0.858062] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a
OMAP UART1
[    0.865844] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a
OMAP UART2
[    0.873565] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a
OMAP UART3
[    0.881347] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a
OMAP UART4
[    0.889099] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a
OMAP UART5
[    0.904052] brd: module loaded
[    0.911346] loop: module loaded
[    0.914733] at24 1-0052: 4096 byte 24c32 EEPROM, writable, 32
bytes/write
[    0.922607] st: Version 20101219, fixed bufsize 32768, s/g segs 256
[    0.930175] Fixed MDIO Bus: probed
[    0.934051] ------------[ cut here ]------------
[    0.938995] WARNING: at fs/sysfs/dir.c:481 sysfs_add_one+0x88/0xa8()
[    0.945678] sysfs: cannot create duplicate filename
'/class/mdio_bus/0'
[    0.952636] Modules linked in:
[    0.955871] Backtrace:
[    0.958465] [<c0017d78>] (dump_backtrace+0x0/0x10c) from [<c03a0d00>]
(dump_stack+0x18/0x1c)
[    0.967346]  r6:c00f9c08 r5:00000009 r4:cf01dd28 r3:c0533e94
[    0.973327] [<c03a0ce8>] (dump_stack+0x0/0x1c) from [<c003dec8>]
(warn_slowpath_common+0x54/0x6c)
[    0.982696] [<c003de74>] (warn_slowpath_common+0x0/0x6c) from
[<c003df84>] (warn_slowpath_fmt+0x38/0x40)
[    0.992675]  r8:00000001 r7:cf029000 r6:cf029000 r5:cf1e0f90
r4:ffffffef
[    0.999572] r3:00000009
[    1.002349] [<c003df4c>] (warn_slowpath_fmt+0x0/0x40) from
[<c00f9c08>] (sysfs_add_one+0x88/0xa8)
[    1.011688]  r3:cf029000 r2:c04774f8
[    1.015472] [<c00f9b80>] (sysfs_add_one+0x0/0xa8) from [<c00fa4a8>]
(sysfs_do_create_link+0xf8/0x1e0)
[    1.025177]  r7:cf01dd80 r6:cf0a0450 r5:cf1e0f90 r4:cf1df1d0
[    1.031188] [<c00fa3b0>] (sysfs_do_create_link+0x0/0x1e0) from
[<c00fa5a4>] (sysfs_create_link+0x14/0x18)
[    1.041259] [<c00fa590>] (sysfs_create_link+0x0/0x18) from
[<c01aaecc>] (device_add+0x300/0x594)
[    1.050537] [<c01aabcc>] (device_add+0x0/0x594) from [<c01ab17c>]
(device_register+0x1c/0x20)
[    1.059539] [<c01ab160>] (device_register+0x0/0x20) from [<c01df3b4>]
(mdiobus_register+0x80/0x174)
[    1.069061]  r4:cf1dd804 r3:cf1de940
[    1.072845] [<c01df334>] (mdiobus_register+0x0/0x174) from
[<c039b13c>] (davinci_mdio_probe+0x1e4/0x2d0)
[    1.082824]  r8:00000000 r7:cf06ad80 r6:cf067608 r5:cf1dea80
r4:cf067600
[    1.089721] r3:00000000
[    1.092498] [<c039af58>] (davinci_mdio_probe+0x0/0x2d0) from
[<c01aeb2c>] (platform_drv_probe+0x20/0x24)
[    1.102478]  r7:c054aae8 r6:c0563a08 r5:c058ee70 r4:cf067608
[    1.108489] [<c01aeb0c>] (platform_drv_probe+0x0/0x24) from
[<c01ad78c>] (driver_probe_device+0xb4/0x2c8)
[    1.118560] [<c01ad6d8>] (driver_probe_device+0x0/0x2c8) from
[<c01ada34>] (__driver_attach+0x94/0x98)
[    1.128356]  r8:00000000 r7:cf1b61c0 r6:cf06763c r5:c054aae8
r4:cf067608
[    1.135437] [<c01ad9a0>] (__driver_attach+0x0/0x98) from [<c01ac4e4>]
(bus_for_each_dev+0x4c/0x94)
[    1.144866]  r6:c01ad9a0 r5:c054aae8 r4:00000000 r3:c01ad9a0
[    1.150878] [<c01ac498>] (bus_for_each_dev+0x0/0x94) from
[<c01ad3b4>] (driver_attach+0x24/0x28)
[    1.160125]  r6:c0549378 r5:c054aae8 r4:c054aae8
[    1.165008] [<c01ad390>] (driver_attach+0x0/0x28) from [<c01ad008>]
(bus_add_driver+0x188/0x270)
[    1.174255] [<c01ace80>] (bus_add_driver+0x0/0x270) from [<c01adcf8>]
(driver_register+0x80/0x144)
[    1.183715] [<c01adc78>] (driver_register+0x0/0x144) from
[<c01aed44>] (platform_driver_register+0x4c/0x60)
[    1.193969] [<c01aecf8>] (platform_driver_register+0x0/0x60) from
[<c04fdf1c>] (davinci_mdio_init+0x14/0x1c)
[    1.204345] [<c04fdf08>] (davinci_mdio_init+0x0/0x1c) from
[<c0008764>] (do_one_initcall+0x128/0x1a8)
[    1.214050] [<c000863c>] (do_one_initcall+0x0/0x1a8) from
[<c04de88c>] (kernel_init+0x84/0x120)
[    1.223236] [<c04de808>] (kernel_init+0x0/0x120) from [<c0040ca8>]
(do_exit+0x0/0x654)
[    1.231567]  r5:c04de808 r4:00000000
[    1.235382] ---[ end trace 6525b897aae0ae1a ]---
[    1.240325] mii_bus 0 failed to register
[    1.244476] davinci_mdio: probe of davinci_mdio.0 failed with error
-22
[    1.251525] PPP generic driver version 2.4.2
[    1.256317] PPP BSD Compression module registered
[    1.261260] PPP Deflate Compression module registered
[    1.267425] PPP MPPE Compression module registered
[    1.272613] usbcore: registered new interface driver rtl8192cu
[    1.278900] usbcore: registered new interface driver cdc_ether
[    1.285064] usbcore: registered new interface driver cdc_eem
[    1.291076] cdc_ncm: 04-Aug-2011
[    1.294525] usbcore: registered new interface driver cdc_ncm
[    1.300506] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[    1.307495] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.314178] usbcore: registered new interface driver cdc_acm
[    1.320129] cdc_acm: USB Abstract Control Model driver for USB modems
and ISDN adapters
[    1.328613] usbcore: registered new interface driver cdc_wdm
[    1.334625] usbcore: registered new interface driver uas
[    1.340240] Initializing USB Mass Storage driver...
[    1.345489] usbcore: registered new interface driver usb-storage
[    1.351806] USB Mass Storage support registered.
[    1.356781] usbcore: registered new interface driver libusual
[    1.362976] usbcore: registered new interface driver usbserial
[    1.369171] USB Serial support registered for generic
[    1.374542] usbcore: registered new interface driver
usbserial_generic
[    1.381439] usbserial: USB Serial Driver core
[    1.386077] USB Serial support registered for FTDI USB Serial Device
[    1.392913] usbcore: registered new interface driver ftdi_sio
[    1.398986] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[    1.405151] USB Serial support registered for GSM modem (1-port)
[    1.411651] usbcore: registered new interface driver option
[    1.417510] option: v0.7.2:USB Driver for GSM modems
[    1.422790] USB Serial support registered for pl2303
[    1.428131] usbcore: registered new interface driver pl2303
[    1.433959] pl2303: Prolific PL2303 USB to serial adaptor driver
[    1.440338] USB Serial support registered for Qualcomm USB modem
[    1.446777] usbcore: registered new interface driver qcserial
[    1.452850] USB Serial support registered for Sierra USB modem
[    1.459075] usbcore: registered new interface driver sierra
[    1.464935] sierra: v.1.7.16:USB Driver for Sierra Wireless USB
modems
[    1.471923]  gadget: using random self ethernet address
[    1.477416]  gadget: using random host ethernet address
[    1.483428] usb0: MAC 2e:dd:ee:91:cb:4d
[    1.487518] usb0: HOST MAC 9e:fc:7d:ce:c2:11
[    1.492065]  gadget: Ethernet Gadget, version: Memorial Day 2008
[    1.498413]  gadget: g_ether ready
[    1.502014] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    1.507659] musb-hdrc musb-hdrc.0: new USB bus registered, assigned
bus number 2
[    1.515563] usb usb2: New USB device found, idVendor=1d6b,
idProduct=0002
[    1.522735] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[    1.530334] usb usb2: Product: MUSB HDRC host driver
[    1.535552] usb usb2: Manufacturer: Linux 3.2.0-SMA musb-hcd
[    1.541503] usb usb2: SerialNumber: musb-hdrc.0
[    1.547302] hub 2-0:1.0: USB hub found
[    1.551269] hub 2-0:1.0: 1 port detected
[    1.556335] mousedev: PS/2 mouse device common for all mice
[    1.562835] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as
rtc0
[    1.577972] tps65910-rtc tps65910-rtc: rtc core: registered
tps65910-rtc as rtc1
[    1.587493] i2c /dev entries driver
[    1.592224] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    1.600463] cpuidle: using governor ladder
[    1.604919] cpuidle: using governor menu
[    1.609222] sdhci: Secure Digital Host Controller Interface driver
[    1.615722] sdhci: Copyright(c) Pierre Ossman
[    1.622161] _regulator_get: omap_hsmmc.2 supply vmmc not found, using
dummy regulator
[    1.630493] _regulator_get: omap_hsmmc.2 supply vmmc_aux not found,
using dummy regulator
[    1.639190] omap_hsmmc omap_hsmmc.2: could not set regulator OCR
(-22)
[    1.646057] ------------[ cut here ]------------
[    1.650939] WARNING: at drivers/regulator/core.c:1442
_regulator_disable+0xec/0x11c()
[    1.659210] unbalanced disables for dummy
[    1.663421] Modules linked in:
[    1.666625] Backtrace:
[    1.669219] [<c0017d78>] (dump_backtrace+0x0/0x10c) from [<c03a0d00>]
[    1.678131]  r6:c0182c54 r5:00000009 r4:cf01dd90 r3:c0533e94
[    1.684112] [<c03a0ce8>] (dump_stack+0x0/0x1c) from [<c003dec8>]
[    1.693450] [<c003de74>] (warn_slowpath_common+0x0/0x6c) from
[    1.703430]  r8:cf055a08 r7:00000000 r6:cf043e30 r5:fffffffb
r4:cf043e00
[    1.710327] r3:00000009
[    1.713104] [<c003df4c>] (warn_slowpath_fmt+0x0/0x40) from
[<c0182c54>] (_regulator_disable+0xec/0x11c)
[    1.722991]  r3:c0481fb0 r2:c0481a38
[    1.726776] [<c0182b68>] (_regulator_disable+0x0/0x11c) from
[<c0182ca8>] (regulator_disable+0x24/0x50)
[    1.736663]  r6:cf043e30 r5:00000000 r4:cf043e00 r3:00000000
[    1.742645] [<c0182c84>] (regulator_disable+0x0/0x50) from
[<c0299334>] (omap_hsmmc_235_set_power+0x78/0x10c)
[    1.753082]  r6:00000000 r5:00000000 r4:cf203e40 r3:cf062ec0
[    1.759094] [<c02992bc>] (omap_hsmmc_235_set_power+0x0/0x10c) from
[<c0501ed4>] (omap_hsmmc_probe+0x730/0xab8)
[    1.769622] [<c05017a4>] (omap_hsmmc_probe+0x0/0xab8) from
[    1.779449] [<c01aeb0c>] (platform_drv_probe+0x0/0x24) from
[    1.789520] [<c01ad6d8>] (driver_probe_device+0x0/0x2c8) from
[    1.799316]  r8:00000000 r7:cf1fdbc0 r6:cf055a3c r5:c05597f0
r4:cf055a08
[    1.806427] [<c01ad9a0>] (__driver_attach+0x0/0x98) from [<c01ac4e4>]
[    1.815856]  r6:c01ad9a0 r5:c05597f0 r4:00000000 r3:c01ad9a0
[    1.821838] [<c01ac498>] (bus_for_each_dev+0x0/0x94) from
[    1.831085]  r6:c0549378 r5:c05597f0 r4:c05597f0
[    1.835968] [<c01ad390>] (driver_attach+0x0/0x28) from [<c01ad008>]
[    1.845214] [<c01ace80>] (bus_add_driver+0x0/0x270) from [<c01adcf8>]
[    1.854675] [<c01adc78>] (driver_register+0x0/0x144) from
[    1.864929] [<c01aecf8>] (platform_driver_register+0x0/0x60) from
[<c01aed78>] (platform_driver_probe+0x20/0x6c)
[    1.875640] [<c01aed58>] (platform_driver_probe+0x0/0x6c) from
[<c0501798>] (omap_hsmmc_init+0x18/0x24)
[    1.885528]  r4:c051262c r3:00000000
[    1.889312] [<c0501780>] (omap_hsmmc_init+0x0/0x24) from [<c0008764>]
[    1.898864] [<c000863c>] (do_one_initcall+0x0/0x1a8) from
[    1.908020] [<c04de808>] (kernel_init+0x0/0x120) from [<c0040ca8>]
(do_exit+0x0/0x654)
[    1.916351]  r5:c04de808 r4:00000000
[    1.920135] ---[ end trace 6525b897aae0ae1b ]---
[    1.925354] usb 1-1: new high-speed USB device number 2 using
musb-hdrc
[    1.933532] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.940521] usbcore: registered new interface driver usbhid
[    1.946411] usbhid: USB HID core driver
[    1.950561] usbcore: registered new interface driver r8712u
[    1.956756] oprofile: hardware counters not available
[    1.962066] oprofile: using timer interrupt.
[    1.966583] nf_conntrack version 0.5.0 (3970 buckets, 15880 max)
[    1.973419] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.979187] TCP cubic registered
[    1.982574] NET: Registered protocol family 17
[    1.987304] Registering the dns_resolver key type
[    1.992309] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 3
[    2.000396] ThumbEE CPU extension supported.
[    2.005706] Power Management for AM33XX family
[    2.015472] Detected MACID=1c:ba:8c:97:c3:ed
[    2.021881] input: gpio-keys as
/devices/platform/gpio-keys/input/input0
[    2.033081] tps65910-rtc tps65910-rtc: setting system clock to
2000-01-01 05:33:38 UTC (946704818)
[    2.045196] PHY 0:00 not found
[    2.048461] PHY 0:02 not found
[    2.096710] mmc0: host does not support reading read-only switch.
assuming write-enable.
[    2.107238] mmc0: new high speed SDHC card at address 0007
[    2.113494] mmcblk0: mmc0:0007 SD4GB 3.70 GiB
[    2.119934]  mmcblk0: p1 p2
[    2.167388] usb 1-1: New USB device found, idVendor=04b4,
idProduct=6572
[    2.174438] usb 1-1: New USB device strings: Mfr=0, Product=1,
SerialNumber=0
[    2.181976] usb 1-1: Product: USB2.0 Hub
[    2.186981] hub 1-1:1.0: USB hub found
[    2.191223] hub 1-1:1.0: 4 ports detected
[    2.786468] usb 1-1.1: new high-speed USB device number 3 using
musb-hdrc
[    2.887756] usb 1-1.1: New USB device found, idVendor=18a5,
idProduct=0243
[    2.895050] usb 1-1.1: New USB device strings: Mfr=1, Product=2,
SerialNumber=3
[    2.902832] usb 1-1.1: Product: STORE N GO
[    2.907196] usb 1-1.1: Manufacturer: Verbatim
[    2.911804] usb 1-1.1: SerialNumber: 070B2A5AAD5D7139
[    2.918884] scsi0 : usb-storage 1-1.1:1.0
[    3.076324] IP-Config: Guessing netmask 255.0.0.0
[    3.081604] IP-Config: Complete:
[    3.085021]      device=eth0, addr=109.0.0.0, mask=255.0.0.0,
gw=255.255.255.255,
[    3.092773]      host=109.0.0.0, domain=, nis-domain=(none),
[    3.098785]      bootserver=255.255.255.255,
rootserver=255.255.255.255, rootpath=
[    4.651550] kjournald starting.  Commit interval 5 seconds
[    4.661773] EXT3-fs (mmcblk0p2): using internal journal
[    4.667358] EXT3-fs (mmcblk0p2): recovery complete
[    4.676574] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data
mode
[    4.683959] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    4.694030] devtmpfs: mounted
[    4.697967] Freeing init memory: 212K
>[    5.167510] udevd[68]: starting version 182
[    7.397155] usb 1-1.3: new high-speed USB device number 4 using
musb-hdrc
[    7.499267] usb 1-1.3: New USB device found, idVendor=1c9e,
idProduct=f000
[    7.506561] usb 1-1.3: New USB device strings: Mfr=3, Product=2,
SerialNumber=4
[    7.514343] usb 1-1.3: Product: USB Modem
[    7.518615] usb 1-1.3: Manufacturer: USB Modem
[    7.523315] usb 1-1.3: SerialNumber: 1234567890ABCDEF
[    7.536468] scsi1 : usb-storage 1-1.3:1.0
  Ich weiß nicht weiter. Egal was ich versuche.. Habe nun im Kernel einfach mal alle USB Support Treiber reingepackt.. Es ändert nichts. Mehr als sowas: [ 8.550659] usb 1-1.1: new high-speed USB device number 4 using musb-hdrc [ 8.652618] usb 1-1.1: New USB device found, idVendor=1c9e, idProduct=f000 [ 8.659881] usb 1-1.1: New USB device strings: Mfr=3, Product=2, SerialNumber=4 [ 8.667602] usb 1-1.1: Product: USB Modem [ 8.671844] usb 1-1.1: Manufacturer: USB Modem [ 8.676513] usb 1-1.1: SerialNumber: 1234567890ABCDEF [ 8.689910] scsi1 : usb-storage 1-1.1:1.0 kommt nicht... Habe zwar dann unter /dev/bus/usb/001/ Files die die angesteckten Dinger repräsentieren. Aber die zu mounten geht leider auch nicht.
  Tuxi schrieb: > Ich weiß nicht weiter. > Egal was ich versuche.. Das HW-Manual (http://www.phytec.de/fileadmin/user_upload/downloads/Manuals/L-771e_1_01.pdf) "sagt" auf Seite 5 2x USB OTG. Seiten 43 und 89: Die USB-Schnitstellen können je nach Konfig und dem richtigen Kabel/Stecker: Host, Device oder OTG Richtig gejumpert?
  Jap, Multiplexer und Host/Device/OTG ist richtig gesetzt. Wird auch im dmesg angezeigt.
  Tuxi schrieb: > Ist übrigens der 3.2 er Kernel. ab dem 3.12er Kernel gibt es Support für AM335x USB support ---> USB Physical Layer drivers ---> AM335x USB PHY Driver This driver provides PHY support for that phy which part for the AM335x SoC und man kann den Modus des Muduls musb_hdrc (Host only mode, Gadget only mode, Dual Role mode) vorab selektieren.
  Das funktioniert ja auch alles. USB 1 ist im Host Modus und USB 0 im Device Modus. An USB1 hängt ein USB-Hub und an dem werden die Sticks angesteckt. Diese werden ja auch erkannt. Bis hierhin kommt er ja : [ 52.380000] scsi0 : usb-storage 1-1.1:1.0 Was fehlt ist sowas: [ 53.380000] scsi 0:0:0:0: Direct-Access SanDisk SanDisk Cruzer 8.02 PQ: 0 ANSI: 0 CCS [ 53.380000] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 53.400000] sd 0:0:0:0: [sda] Attached SCSI removable disk Ich habe mittlerweile mdev ans laufen bekommen. Jetzt bekomme ich in /dev folgendes: 1-1.1 ram13 tty25 tty57 1-1.4 ram14 tty26 tty58 bus ram15 tty27 tty59 console ram2 tty28 tty6 cpu_dma_latency ram3 tty29 tty60 full ram4 tty3 tty61 i2c-1 ram5 tty30 tty62 input ram6 tty31 tty63 kmem ram7 tty32 tty7 kmsg ram8 tty33 tty8 log ram9 tty34 tty9 loop-control random tty35 ttyO0 loop0 root tty36 ttyO1 loop1 rtc0 tty37 ttyO2 loop2 rtc1 tty38 ttyO3 loop3 spidev1.0 tty39 ttyO4 loop4 tty tty4 ttyO5 loop5 tty0 tty40 ttyS0 loop6 tty1 tty41 ttyS1 loop7 tty10 tty42 ttyS2 mem tty11 tty43 ttyS3 mmcblk0 tty12 tty44 urandom mmcblk0p1 tty13 tty45 usbdev1.1 mmcblk0p2 tty14 tty46 usbdev1.2 network_latency tty15 tty47 usbdev1.4 network_throughput tty16 tty48 usbdev1.5 null tty17 tty49 vcs ppp tty18 tty5 vcs1 psaux tty19 tty50 vcsa ptmx tty2 tty51 vcsa1 ram0 tty20 tty52 watchdog ram1 tty21 tty53 zero ram10 tty22 tty54 ram11 tty23 tty55 ram12 tty24 tty56 Die 1-1.1 und 1-1.4 wurden anscheinend von mdev angelegt. Desweiteren ist das da: root@109:/dev root@109:/dev cd bus/ root@109:/dev/bus ls usb root@109:/dev/bus cd usb/ root@109:/dev/bus/usb ls 001 root@109:/dev/bus/usb cd 001/ root@109:/dev/bus/usb/001 ls 001 002 004 005 root@109:/dev/bus/usb/001 Aber die 1-1.1 kann ich nicht mounten. Da kommt immer no block device.
  Achja das mdev.conf und das usb script ist von hier : http://blog.stuart.shelton.me/archives/891 mdev wird in der rcS eingebunden. Und es gibt einen S10mdev das unter init.d nochmals drin ist.
  Das bekomme ich angezeigt beim einstecken und beim abziehen: root@109:/dev [ 281.692504] usb 1-1.1: new high-speed USB device number 7 using musb-hdrc [ 281.793792] usb 1-1.1: New USB device found, idVendor=18a5, idProduct=0243 [ 281.801116] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 281.808898] usb 1-1.1: Product: STORE N GO [ 281.813262] usb 1-1.1: Manufacturer: Verbatim [ 281.817871] usb 1-1.1: SerialNumber: 070B2A5AAD5D7139 [ 281.842651] scsi4 : usb-storage 1-1.1:1.0 [ 281.973724] 692 00:04:39.%N mdev usb helper started as '/lib/mdev/usb' [ 281.973724] in '/dev', MDEV 'usbdev1.7', ACTION 'add', DEVPATH '/devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.1/usb_devic e/usbdev1.7', [ 281.973754] SUBSYSTEM 'usb_device', SEQNUM '489' root@109:/dev [ 287.481903] usb 1-1.1: USB disconnect, device number 7 [ 287.629516] 701 00:04:45.%N mdev usb helper started as '/lib/mdev/usb' [ 287.629547] in '/dev', MDEV 'usbdev1.7', ACTION 'remove', DEVPATH '/devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.1/usb_devic e/usbdev1.7', [ 287.629577] SUBSYSTEM 'usb_device', SEQNUM '493' root@109:/dev
  Tuxi schrieb: > [ 53.380000] scsi 0:0:0:0: Direct-Access SanDisk SanDisk Cruzer > 8.02 PQ: 0 ANSI: 0 CCS > [ 53.380000] sd 0:0:0:0: Attached scsi generic sg0 type 0 > [ 53.400000] sd 0:0:0:0: [sda] Attached SCSI removable disk wenn Du bei diesem System ein $ ls /dev/s* ausführst, bekommst Du pro Device ein Character- und Blockdevice (pro Gerät eins, pro Partition eins) Beispiel (USB-Stick, eine Partition) brw-rw---T 1 root floppy 8, 48 Aug 19 14:17 /dev/sdd brw-rw---T 1 root floppy 8, 49 Aug 19 14:17 /dev/sdd1 crw------- 1 root root 21, 5 Aug 19 14:17 /dev/sg5 Tuxi schrieb: > mmcblk0 > mmcblk0p1 > mmcblk0p2 Sind diese Devices vom Flash des Systems? Btw: Hub abstecken, System neu starten $ ls -lrt ausführen, Stick direkt anschließen, erneut $ ls -lrt ausführen. Welches Devices wurden neu angelegt?
  Die mmcblk ist die microSD Karte wovon das Linux bootet. Wenn ich eine weiter SD Karte in den 2. Slot Stecke wird diese auch erkannt und kann gemounted werden. Das mit dem Hub abstecken geht nicht... Ist eine Platine.
  Du kannst die Devices auch mal von Hand anlegen $ mknod /dev/sda b 8 0 $ mknod /dev/sda1 b 8 1
  Hab ich auch schonmal gemacht. Dann hab ich da die 2 Dinger aber mounte geht nicht weil er nicht weiß das es der USB Stick sein sollte...
  DirkZ schrieb: > Tuxi schrieb: >> Ist übrigens der 3.2 er Kernel. > > ab dem 3.12er Kernel gibt es Support für AM335x > > USB support ---> > USB Physical Layer drivers ---> > AM335x USB PHY Driver Wenn es weder mit UDEV noch mit MDEV funktioniert, würde ich den 3.12er-Kernel mal versuchen. Zumal dort extra der Menüpunkt "AM335x USB PHY Driver" aufgeführt wird.
  Ich versuche es mal. Aber ich glaube so einfach ist das nicht. Die ganzen Patches die von Phytec im BSP bereitgestellt werden gehen nur auf dem 3.2er. Bei dem 3.12 oder 3.14 ist das Board gar nicht in der Auswahl drin. Ich denke ich werde den 3.2er nehmen müssen. Jetzt noch alles auf 3.14 zu portieren dauert glaub länger.
  OK, ich bin vom Vanilla-Kernel ausgagangen. Zurück auf Anfang und die aktuellen Files von deren FTP-Server draufspielen, dann müsste es funktionieren. Falls nicht, könnte auch ein HW-Defekt vorliegen.
  Soo, war ein guter Rat nochmal komplett bei 0 anzufangen. Läuft jetzt alles. Usb_modeswitch zwar noch nicht von selbst obwohl die scripte richtig sind. Ist aber egal ruf ich einfach mit system() auf. Nun hänge ich am nächten Problem. Ich versuche mit pppd eine Verbindung über den UMTS-Stick aufzubauen. Am Beaglebone mit wvdial ging es. Nun möchte ich ohne wvdial arbeiten. root@phyCORE-AM335x:/etc/chatscripts pon Tmobil nodetach Plugin rp-pppoe.so loaded. Using interface ppp0 kernel does not support PPP filtering local IP address 10.64.64.64 remote IP address 10.112.112.112 Das kommt. Aber der Stick blinkt weiterhin, was bedeutet das er sich nicht eingewählt hat. root@phyCORE-AM335x:/etc/chatscripts cat Tmobil TIMEOUT 120 ECHO ON ABORT '\nBUSY\r' ABORT '\nERROR\r' ABORT '\nNO CARRIER\r' '' 'ATZ' # HIER KANN MAN DEN APN EINSTELLEN: internet.t-mobile == T-Mobile OK 'AT+CGDCONT=1,"IP","internet.t-mobil","0.0.0.0",0,0' OK 'ATDT*99***1#' CONNECT \d\c root@phyCORE-AM335x:/etc/ppp/peers cat Tmobil noauth connect "/usr/sbin/chat -v -f /etc/chatscripts/Tmobil" # /dev/ttyUSB muss ggf. angepasst werden. Bei einigen ist es ttyUSB0 bei anderen ttyUSB2 defaultroute /dev/ttyUSB3 115200 persist debug passive noipdefault usepeerdns replacedefaultroute #USERNAME UND PASSWORD MÃSSEN BEI T-Online GAR NICHT ANGEGEBEN WERDEN, KANN ABER VARIIEREN #user "tm" #password "tm" Leider weiß ich nicht ob der rest mit der resolve.conf und alles was sonst noch dazu gehöhrt z.B. /etc/network.d/interface da habe ich: auto ppp0 iface ppp0 inet eingetragen. Ist für mich leider ein Blindflug, da ich keine Ahnung habe. Bin erst seit kurzem bei "Embedded Linux" da so tief eingestiegen. Bisher war vieles "KlickiBunti openSuse/Fedora" oder Archlinux am Beaglebone.
  Achja vom BBB weiß ich das /dev/ttyUSB3 der richtige ist. Das Modem hat auch geantwortet als ich mal mit echo den AT Befehl für den Pin hingeschickt habe. Kam ein OK zurück. Habe den Pin aber nun deaktiviert.
  Tuxi schrieb: > Ich versuche mit pppd eine Verbindung über den UMTS-Stick aufzubauen. > Am Beaglebone mit wvdial ging es. Nun möchte ich ohne wvdial arbeiten. Warum nicht wvdial? Du könntest das UMTS-Modem damit einrichten. Dann weißt Du, das es überhaupt am phyCore funktioniert. Du hast jetzt ein anderes Board und möchtest ein anderes Programm nehmen, ggf. noch 'ne andere Distri. Tuxi schrieb: > local IP address 10.64.64.64 > remote IP address 10.112.112.112 das sind lokale Klasse-A IPs. Tuxi schrieb: > Leider weiß ich nicht ob der rest mit der resolve.conf und alles was > sonst noch dazu gehöhrt z.B. /etc/network.d/interface da habe ich: resolv.conf wird idR von resolverconf erstellt/überschrieben, wenn die betr. Schnittstelle aktiv ist. (etc/network/if-up.d) hier mal schauen https://wiki.archlinux.org/index.php/3G_and_GPRS_modems_with_pppd https://wiki.archlinux.org/index.php/pppd
  So, kurze Rückmeldung: Alles läuft. Sofern ich nocheinmal einen externen Hub zwischen dem eingebauten und dem UMTS-Stick habe. Ohne wählt sich der Stick nicht ein. Denke das wird wohl mit der Versorgung zusammenhängen. Wobei ich die eigentlich extra stark ausgelegt habe... Oder aber EMV Geschichten... Werde ich später mal genauer untersuchen... Aber vielen Dank an DirkZ!
 Thread beobachten
 Thread beobachten Seitenaufteilung abschalten
