1 | /* USER CODE BEGIN Header */
2 | /**
3 | ******************************************************************************
4 | * @file : main.c
5 | * @brief : Main program body
6 | ******************************************************************************
7 | * @attention
8 | *
9 | * Copyright (c) 2022 STMicroelectronics.
10 | * All rights reserved.
11 | *
12 | * This software is licensed under terms that can be found in the LICENSE file
13 | * in the root directory of this software component.
14 | * If no LICENSE file comes with this software, it is provided AS-IS.
15 | *
16 | ******************************************************************************
17 | */
18 | /* USER CODE END Header */
19 | /* Includes ------------------------------------------------------------------*/
20 | #include "main.h"
21 |
22 | /* Private includes ----------------------------------------------------------*/
23 | /* USER CODE BEGIN Includes */
24 |
25 | /* USER CODE END Includes */
26 |
27 | /* Private typedef -----------------------------------------------------------*/
28 | /* USER CODE BEGIN PTD */
29 |
30 | /* USER CODE END PTD */
31 |
32 | /* Private define ------------------------------------------------------------*/
33 | /* USER CODE BEGIN PD */
34 | /* USER CODE END PD */
35 |
36 | /* Private macro -------------------------------------------------------------*/
37 | /* USER CODE BEGIN PM */
38 |
39 | /* USER CODE END PM */
40 |
41 | /* Private variables ---------------------------------------------------------*/
42 |
43 | /* USER CODE BEGIN PV */
44 |
45 | /* USER CODE END PV */
46 |
47 | /* Private function prototypes -----------------------------------------------*/
48 | void SystemClock_Config(void);
49 | static void MX_GPIO_Init(void);
50 | /* USER CODE BEGIN PFP */
51 |
52 | /* USER CODE END PFP */
53 |
54 | /* Private user code ---------------------------------------------------------*/
55 | /* USER CODE BEGIN 0 */
56 |
57 | /* USER CODE END 0 */
58 |
59 | /**
60 | * @brief The application entry point.
61 | * @retval int
62 | */
63 | int main(void)
64 | {
65 | /* USER CODE BEGIN 1 */
66 |
67 | /* USER CODE END 1 */
68 |
69 | /* MCU Configuration--------------------------------------------------------*/
70 |
71 | /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
72 | HAL_Init();
73 |
74 | /* USER CODE BEGIN Init */
75 |
76 | /* USER CODE END Init */
77 |
78 | /* Configure the system clock */
79 | SystemClock_Config();
80 |
81 | /* USER CODE BEGIN SysInit */
82 |
83 | /* USER CODE END SysInit */
84 |
85 | /* Initialize all configured peripherals */
86 | MX_GPIO_Init();
87 | /* USER CODE BEGIN 2 */
88 |
89 | /* USER CODE END 2 */
90 |
91 | /* Infinite loop */
92 | /* USER CODE BEGIN WHILE */
93 | while (1)
94 | {
95 | /* USER CODE END WHILE */
96 |
97 | /* USER CODE BEGIN 3 */
98 | HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_0);
99 | HAL_Delay(1000);
100 | }
101 | /* USER CODE END 3 */
102 | }
103 |
104 | /**
105 | * @brief System Clock Configuration
106 | * @retval None
107 | */
108 | void SystemClock_Config(void)
109 | {
110 | RCC_OscInitTypeDef RCC_OscInitStruct = {0};
111 | RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
112 |
113 | /** Configure the main internal regulator output voltage
114 | */
115 | HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
116 |
117 | /** Initializes the RCC Oscillators according to the specified parameters
118 | * in the RCC_OscInitTypeDef structure.
119 | */
120 | RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
121 | RCC_OscInitStruct.HSIState = RCC_HSI_ON;
122 | RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1;
123 | RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
124 | RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
125 | if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
126 | {
127 | Error_Handler();
128 | }
129 |
130 | /** Initializes the CPU, AHB and APB buses clocks
131 | */
132 | RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
133 | |RCC_CLOCKTYPE_PCLK1;
134 | RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
135 | RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
136 | RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
137 |
138 | if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
139 | {
140 | Error_Handler();
141 | }
142 | }
143 |
144 | /**
145 | * @brief GPIO Initialization Function
146 | * @param None
147 | * @retval None
148 | */
149 | static void MX_GPIO_Init(void)
150 | {
151 | GPIO_InitTypeDef GPIO_InitStruct = {0};
152 |
153 | /* GPIO Ports Clock Enable */
154 | __HAL_RCC_GPIOA_CLK_ENABLE();
155 |
156 | /*Configure GPIO pin Output Level */
157 | HAL_GPIO_WritePin(GPIOA, GPIO_PIN_0, GPIO_PIN_SET);
158 |
159 | /*Configure GPIO pin : PA0 */
160 | GPIO_InitStruct.Pin = GPIO_PIN_0;
161 | GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
162 | GPIO_InitStruct.Pull = GPIO_NOPULL;
163 | GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
164 | HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
165 |
166 | }
167 |
168 | /* USER CODE BEGIN 4 */
169 |
170 | /* USER CODE END 4 */
171 |
172 | /**
173 | * @brief This function is executed in case of error occurrence.
174 | * @retval None
175 | */
176 | void Error_Handler(void)
177 | {
178 | /* USER CODE BEGIN Error_Handler_Debug */
179 | /* User can add his own implementation to report the HAL error return state */
180 | __disable_irq();
181 | while (1)
182 | {
183 | }
184 | /* USER CODE END Error_Handler_Debug */
185 | }
186 |
187 | #ifdef USE_FULL_ASSERT
188 | /**
189 | * @brief Reports the name of the source file and the source line number
190 | * where the assert_param error has occurred.
191 | * @param file: pointer to the source file name
192 | * @param line: assert_param error line source number
193 | * @retval None
194 | */
195 | void assert_failed(uint8_t *file, uint32_t line)
196 | {
197 | /* USER CODE BEGIN 6 */
198 | /* User can add his own implementation to report the file name and line number,
199 | ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
200 | /* USER CODE END 6 */
201 | }
202 | #endif /* USE_FULL_ASSERT */
