conversion float nach int
OP #7328846
MCU ATtiny13A IDE Microchip Studio
Hab hier ein conversion Problem von float nach int bzw. umgekehrt. Ist dies mit einem 8-bit MCU überhaupt ohne weiteres möglich? Der Compiler wills einfach nicht bauen.
float min = 40.f; float max = 200.f;
int adcValue = ADCH; float adcValueNormalized = (float)adcValue / 255.f;
OCR0B = (int)(min * (1.f - adcValueNormalized) + max * adcValueNormalized);
Danke Uwe
OP #7328869
hier die Fehlerliste.
Severity  Code  Description  Project  File  Line
Error    ATtiny13A-PWM.elf section `.text%16' will not fit in region `text'  ATtiny13A-PWM    1
Error    Could not allocate section .text, size = 10 bytes, attributes = code  ATtiny13A-PWM  addsf3.o  0
Error    Could not allocate section .text, size = 2 bytes, attributes = code  ATtiny13A-PWM  C:/Program Files (x86)/Atmel/Studio/7.0/Packs/atmel/ATtiny_DFP/1.10.348/xc8/avr/lib/avr25/tiny-stack/memx-const/crtattiny13a.o  0
Error    recipe for target 'ATtiny13A-PWM.elf' failed  ATtiny13A-PWM  C:\Microchip-Studio-Projekte\AVR-Projekte\ATtiny13A-PWM\ATtiny13A-PWM\Debug\Makefile  106
Error    ld returned 1 exit status  ATtiny13A-PWM  collect2.exe  0
Error    Could not allocate section .text.exit, size = 14 bytes, attributes = code  ATtiny13A-PWM  exit.o  0
Error    Could not allocate section .text.__dummy_fini, size = 2 bytes, attributes = code keep  ATtiny13A-PWM  exit.o  0
Error    Could not allocate section .text.__dummy_funcs_on_exit, size = 2 bytes, attributes = code  ATtiny13A-PWM  exit.o  0
Error    Could not allocate section .text.__dummy_simulator_exit, size = 2 bytes, attributes = code  ATtiny13A-PWM  exit.o  0
Error    Could not allocate section .text, size = 10 bytes, attributes = code  ATtiny13A-PWM  fixsfsi.o  0
Error    Could not allocate section .text, size = 122 bytes, attributes = code  ATtiny13A-PWM  floatsisf.o  0
Error    Could not allocate section .text, size = 12 bytes, attributes = code  ATtiny13A-PWM  fp_inf.o  0
Error    Could not allocate section .text, size = 6 bytes, attributes = code  ATtiny13A-PWM  fp_nan.o  0
Error    Could not allocate section .text, size = 34 bytes, attributes = code  ATtiny13A-PWM  fp_round.o  0
Error    Could not allocate section .text, size = 68 bytes, attributes = code  ATtiny13A-PWM  fp_split3.o  0
Error    Could not allocate section .text, size = 14 bytes, attributes = code  ATtiny13A-PWM  fp_zero.o  0
Error    Could not allocate section .text, size = 4 bytes, attributes = code  ATtiny13A-PWM  mulsf3.o  0
Error    Could not allocate program memory  ATtiny13A-PWM  RUNCOMPILERTASK  0
Error    Could not allocate section .text._Exit, size = 2 bytes, attributes = code  ATtiny13A-PWM  _Exit.o  0
Gast #7328888
ROM ? Meinst du den 1kB Programmspeicher? Der ist mit den paar Zeilen schon ausgeschöpft?
Nun ja, die HW kann kein float - das muss emuliert werden. Beim Einbinden des Codes für die Addition (addsf3.o) fliegt er raus.
PS: Das ".size%16" sagt mir aber nichts - AVR Eigenheit?
Gast #7328892
Folgender Code liefert bei mir 96,3 % Speicherauslastung. die fp-lib braucht fast ein kilobyte.
#include <avr/io.h>
int main(void) {
  volatile float fl1, fl2 = 2.33, fl3 = 0.66;
  fl1 = fl2 + fl3;
  fl1 = fl2 - fl3;
  fl1 = fl2 * fl3;
  fl3 = fl2 / fl3;
Persönliche Seite #7328929
Hier ein Bespiel mit ISO/IEC TR18037 "Embedded-C" Fixed-point:
#include <stdfix.h>
#include <avr/io.h>
int main (void)
    accum min = 40.0k;
    accum max = 200.0k;
    accum adcValue = ADCH;
    accum adcValueNormalized = adcValue / 255.0k;
    accum ocr = min * (1.0k - adcValueNormalized) + max * adcValueNormalized;
    OCR0B = (uint8_t) ocr;
"accum" ist ein 32-Bit Fixed-Point Typ mit Signatur s16.15, also Signed mit 16 Vorkomma-Bits.
Für "Embedded-C" gibt's keinen eigenen GCC-Schalter, man muss GNU-C verwenden, also etwa
avr-gcc -Os fix.c -save-temps -mmcu=attiny13a -o fix.elf -std=gnu99
Codegröße im ELF ist 460 Bytes mit avr-gcc v8, also inclusive Startup-Code und Lib-Funktionen (32-Bit Fixed-Point Multiplikation und Division mit Rundung zum Nächsten).
Mit "unsigned accum" und Konstanten (Suffix "uk") fällt die Codegröße auf unter 300 Bytes.
Mit weiterer [unsigned] accum Arithmetik wächst die Code größe dann nur noch langsam, weil man die Lib-Funktionen ja nur 1x braucht.
Gast #7328967
Der ist schon in dem Moment ausgeschöpft, wo du an float denkst. Wie kann man auf die Idee kommen, bei insgesamt nur 1kB verfügbarem Programmspeicher eine Float Library einzubinden?
OP #7329009
Ist das eine rhetorische Frage? Ich antworte mal trotzdem.
Vermutlich aufgrund meiner Unwissenheit, daß der Tiny13 keine Hardwareunterstützung für Gleitkommazahlen bietet.
Hab ja auch Microstudio und den Tiny erst seit gestern.
@Johann L.: Danke für den Beitrag.
Gast #7329026
Das machen Microcontroller so gut wie nie. So etwas gibt es erst bei recht fetten Kloppern wie einem ARM-Cortex M4, der aber in einer mehrere Größenordnungen anderen Liga spielt als irgendein AVR, ob Tiny oder Mega.
Gast #7329032
Zu den allermeisten Mikrocontrollern gibt es Datenblätter. Manchmal lohnt es sich, dort einen Blick reinzuwerfen.
OP #7329036
Hab die 178 Seiten PDF seit gestern hier vorliegen, und sogar mal reingeschaut um herauszufinden wie ich Phase Correct PWM, ADC und Timer konfiguriere.
Habs halt nicht wie einen Roman von Anfang bis Ende gelesen. Dafür war ich zu ungeduldig.
Gast #7329329
Uwe schrieb:
Werde wohl nun mit dem Attiny13 float-Operationen vermeiden.
Ich würde sogar noch einen Schritt weiter gehen: auf Mikrocontrollern mit so wenig RAM (hier 64 Bytes, für Daten und Stack) würde ich C vermeiden!
Wenn man den Compiler nicht seeehr intim kennt, fliegt man in Null-Komm-Nix auf die Schnauze. Und selbst wenn man ihn gut kennt, kommt man nicht drum herum, den generierten Kode zu überprüfen - ein Register-spill zuviel und es bleibt kein Stack für IRQs oder einen weiteren Funktionsaufruf übrig. Beim AVR kommt noch dazu, dass alle Daten (auch read-only) ins RAM kopiert werden. Wenn man da nicht ordentlich PROGMEM benutzt, reicht's evtl nichtmal für den main-Aufruf.
Insbesondere sollte man fremde Libraries, die nicht explizit auf so geringen Speicherbedarf getrimmt sind[1], nicht ohne Code-Review benutzten. Die FP-Routinen z.B. würden für jede Temp-Variable, die sie evtl benötigen, ~10% des RAMs belegen. Wieviele brauchen sie für die verschiedenen Funktionen? Wie tief sind Funktionsaufrufe geschachtelt? Usw.
Klar, man kann einfach "Augen-zu" losprogrammieren und ausprobieren - das sind dann die Programme, die undefiniert absemmeln[2] und wo dann das Problem in der HW gesucht wird (das Programm ist ja "ausprobiert" und läuft!) :-(
Assembler ist auf AVRs ziemlich angenehm - ruhig mal ausprobieren[3] ;-)
-- [1] Die geben dann an, wieviel Resourcen (Stack/RAM/ROM/Takte) sie benötigen. Bei so geringem Speicher ist das kein "nice to have" sondern zwingend notwendig! [2] Z.B. IRQ zum unpassenden Zeitpunkt, wo der Stack gerade gut belegt war. [3] So wenig Speicher ist einer der wenigen Fälle, wo ich Assembler propagiere ...
#7329338
Ich würde sogar noch den Schritt weitergehen, und so etwas wie den ATtiny13 überhaupt nur dann einzusetzen, wenn es dafür einen sehr, sehr guten Grund gibt. Und den gibt es beim To augenscheinlich nicht.
Oliver
OP #7329716
Werd ich machen. Muß mich mal mit den mnemonics auseinandersetzen.
Ich habe den Tiny13 gewählt, weil ich für mein Projekt genau eine PWM und ein ADC benötige. Wollte deshalb keinen größeren MCU.
Uwe
Moderator Persönliche Seite #7329731
Dann hättest du dir vorher auch Gedanken um die weiteren benötigten Ressourcen, insbesondere hinsichtlich der Software machen sollen.
Mal ehrlich, für ein Hobbyprojekt in einstelligen Stückzahlen würde ich mir die Platzknappheit eines 1-KiB-Controllers nicht so ohne weiteres antun. Ein ATtiny25 kostet nur ein paar Cents mehr und bietet schon doppelte Ressourcen, und mit dem ATtiny85 im gleichen Gehäuse hast du reichlich Reserven während der Entwicklungsarbeit.
Bei wirklich finanziell knapp aufgestellten Projekten ist das was anderes, aber da macht man sich (s.o.) halt auch wirklich schon mal vorher Gedanken, dass die Software damit zurecht kommen kann.
OP #7329781
Danke, ich werde eure Tipps beim nächsten Projekt beherzigen.
Die einfache PWM Steuerung ist nun fertig.
Program Memory Usage : 368 bytes 35,9 % Full Data Memory Usage : 4 bytes 6,3 % Full Warning: Memory Usage estimation may not be accurate if there are sections other than .text sections in ELF file
Grüße Uwe
