Quartus II: warum wird mein Zählernicht synthetisiert?
Gast #590601
Hallo!
Ich verstehe nicht, warum mir Quatus II den Zähler puls_spacing_counter
in folgendem process nicht synthetisieren will:
process(clk)
begin
    if(clk'event and clk = '1') then
        if(is_clk_out_m_in = '0') then
            if(conv_integer(imp_data_from_sr) > 0) then
                puls_data_complete(10 downto 0) <= imp_data_from_sr;
                puls_data_complete(23 downto 11) <= conv_std_logic_vector(puls_spacing_counter, 13);
                reset_counter <= '1';
                get_puls_data_complete <= '1';
            end if;
        end if;
        if(is_clk_out_m_in = '1') then
            if(reset_counter = '1') then
                puls_spacing_counter <= 0;
                get_puls_data_complete <= '0';
            else
                puls_spacing_counter <= puls_spacing_counter + 1;
            end if;
        end if;
    end if;
23
end process;
Mehr Prozesse hat das Entity nicht in seiner Architektur. Es bekommt den
Vector imp_data_from_sr von einer integrierten Komponete, und es soll
nun dieser Vector mit dem Inhalt des Zählers in einen neuen Vector
(puls_data_complete) geschrieben werden.
Leider kommt Quartus ständig mit diesen Warnungen, und die Bits 23-11 in
puls_data_complete bleiben immer leer.
Warning: Reduced register "reset_counter" with stuck data_in port to
stuck value VCC
Warning: Reduced register "puls_spacing_counter[0]" with stuck data_in
port to stuck value GND
Warning: Reduced register "puls_spacing_counter[2]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[3]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[4]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[5]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[6]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[7]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[8]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[9]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[10]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[11]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[12]" with stuck data_in
Warning: Reduced register "puls_data_complete[11]" with stuck data_in
Warning: Reduced register "puls_data_complete[13]" with stuck data_in
Warning: Reduced register "puls_data_complete[14]" with stuck data_in
Warning: Reduced register "puls_data_complete[15]" with stuck data_in
Warning: Reduced register "puls_data_complete[16]" with stuck data_in
Warning: Reduced register "puls_data_complete[17]" with stuck data_in
Warning: Reduced register "puls_data_complete[18]" with stuck data_in
Warning: Reduced register "puls_data_complete[19]" with stuck data_in
Warning: Reduced register "puls_data_complete[20]" with stuck data_in
Warning: Reduced register "puls_data_complete[21]" with stuck data_in
Warning: Reduced register "puls_data_complete[22]" with stuck data_in
Warning: Reduced register "puls_data_complete[23]" with stuck data_in
Warning: Reduced register "puls_spacing_counter[1]" with stuck data_in
Warning: Reduced register "puls_data_complete[12]" with stuck data_in
Was mache ich hier falsch?
Maik
Gast #590612
Erstes Warning sagt, dass reset_counter immer auf '1' sei.
Das heisst, dass du nie an die Stelle kommst, wo gezählt wird. Also
optimiert die Synthese den Zähler raus, da er offensichtlich nicht
gebraucht wird.
Schau mal nach, wie reset_counter gebildet wird!
Gast #590613
Okay, ich habe es selber herausbekommen. Ich musste den reset_counter
natürlich noch einmal zurücksetzen, damit der Counter nicht bei jedem
Prozessaufruf gelöscht wird.
Gast #590615
Hi Schlumpf!
Gerade habe ich es ja selber herausbekommen. Wie du siehst, hattest du
aber recht. Vielen Dank für die schnelle Hilfe . . .
Maik
Gast #590622
Wenn is_clk_out_m_in = '1', weist du puls_spacing_counter <= 0 zu, da
reset_counter immer '1' ist.
Wenn dann is_clk_out_m_in = '0' ist, dann übernimmst du eben genau diese
0 in
  • [vhdl]VHDL-Code[/vhdl]
