Hallo! Nach Neuinstallation der aktuellsten SW kommt folgende Fehlermeldung: "You are not running the Agilent Logic Analysis application from the locally active workspace. Continue with the application startup is highly discouraged! Another workspace is active! You should remove and re-install the product software again.......... Currently active workspace: < no active workspace >" Nach erneuter Installation tritt der Fehler immer noch auf. Kennt jemand das Problem? M.f.G.
