24VDC Motor Features: Nominal voltage: 24VDC Voltage range: 12 - 24VDC Current @ maximum efficiency: 1.43A Speed @ maximum efficiency: 22,600 RPM Torque @ maximum efficiency: 88.5 g-cm Efficiency: 60.9% Terminal type: 0.24" solder tabs Shaft diameter: 0.091" Shaft length: 0.512" Size: 1.083" diameter x 1.279" depth
