AT90CAN128: Map the code stack in internal SRAM ?
Gast #2268137
im Datenblatt zum AT90CAN128 steht folgendes:
Miss-functioning when code stack is in XRAM
If the stack pointer (SP) targets the XRAM and if the execution of an
instruction is split to serve a rising interrupt, the last operation of
this instruction, executed after pushing out the return address from
XRAM, may be disturbed providing wrong data to the system. Example: -
the “OUT” instruction can be executed twice
- the “MOV” instruction can update a register with un-predictable data.
Problem fix / workaround
Map the code stack in internal SRAM.
Mir ist nicht ganz klar, was da zu tun ist.
Kim
