Linker in CrossStudio for Arm
OP #2430771
Hallo ich bin mit meinem Projekt kurzfristig von Keil auf CrossStudio
umgestiegen. Jetzt habe ich Probleme beim Linkersript:
Rebuild active project — 3.8 seconds — 35 errors
  Rebuilding “AduC7128” in configuration “ARM Flash Debug” — 35 errors
    Compiling adc.c
    Compiling dds.c
    Compiling main.c
    Compiling uart.c
    Assembling crt0.s
    Assembling Analog_ADuC7000_Startup.s
    Compiling Analog_ADuC7000.c
    Compiling Analog_ADuC702x_Eval_Board.c
    Generating linker script
    Linking AduC7128.elf — 35 errors
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: region UNPLACED_SECTIONS is full (ARM Flash Debug/AduC7128.elf section .text)
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: region UNPLACED_SECTIONS is full (ARM Flash Debug/AduC7128.elf section .rodata)
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: region UNPLACED_SECTIONS is full (ARM Flash Debug/AduC7128.elf section .init)
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: region UNPLACED_SECTIONS is full (ARM Flash Debug/AduC7128.elf section .vectors)
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: region UNPLACED_SECTIONS is full (ARM Flash Debug/AduC7128.elf section .text.libc)
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: region UNPLACED_SECTIONS is full (ARM Flash Debug/AduC7128.elf section .data)
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: region UNPLACED_SECTIONS is full (ARM Flash Debug/AduC7128.elf section .bss)
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: section .init [00000000 -> 0000022f] overlaps section .rodata [00000000 -> 0000070f]
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: section .vectors [00000000 -> 0000003b] overlaps section .init [00000000 -> 0000022f]
23
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: section .text.libc [00000000 -> 0000007f] overlaps section .vectors [00000000 -> 0000003b]
24
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: section .data [00000000 -> 00000027] overlaps section .text.libc [00000000 -> 0000007f]
25
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: section .bss [00000000 -> 00001163] overlaps section .data [00000000 -> 00000027]
26
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: section .text [00000000 -> 0000246b] overlaps section .bss [00000000 -> 00001163]
27
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: ARM Flash Debug/AduC7128.elf: section .vectors lma 0x0 overlaps previous sections
28
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: ARM Flash Debug/AduC7128.elf: section .text.libc lma 0x0 overlaps previous sections
29
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: ARM Flash Debug/AduC7128.elf: section .init lma 0x0 overlaps previous sections
30
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: ARM Flash Debug/AduC7128.elf: section .rodata lma 0x0 overlaps previous sections
31
      C:/Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/gcc/bin/ld: ARM Flash Debug/AduC7128.elf: section .text lma 0x0 overlaps previous sections
32
      ARM Flash Debug/crt0.o: In function `memory_set':
33
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__stack_und_end__'
34
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__stack_abt_end__'
35
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__stack_irq_end__'
36
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__stack_fiq_end__'
37
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__stack_svc_end__'
38
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__stack_end__'
39
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__data_load_start__'
40
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__data_start__'
41
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__data_end__'
42
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__text_load_start__'
43
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__text_start__'
44
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__text_end__'
45
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__fast_load_start__'
46
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__fast_start__'
47
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__fast_end__'
48
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__ctors_load_start__'
49
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__ctors_start__'
50
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__ctors_end__'
51
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__dtors_load_start__'
52
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__dtors_start__'
53
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__dtors_end__'
54
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__rodata_load_start__'
55
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__rodata_start__'
56
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__rodata_end__'
57
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__bss_start__'
58
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__bss_end__'
59
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__heap_start__'
60
      C:/ADUC7128/Crossworks Projekt/../../../../../../Programme/Rowley Associates Limited/CrossWorks for ARM 1.7/source/crt0.s:298: undefined reference to `__heap_end__'
61
Build failed
Ich habe die Files direkt von der Webseite als Package heruntergeladen.
Muss ich noch irgendwelche Einstellungen machen?
