uVision und different mspace
Gast #2531524
Hallo
beim Versuch ein Codebesispiel zu compilieren sagt mir der kompiler
folgendes :
MMC_DATALOGGER.C(1227): warning C259: '=': pointer: different mspace
dies betrifft folgende funktion:
void MMC_FLASH_Init (void);            // Initializes MMC and configures it to
                                       // accept SPI commands;
                                       // Reads <length> bytes starting at
                                       // <address> and stores them at <pchar>;
unsigned char MMC_FLASH_Read (unsigned long address, unsigned char *pchar,
                         unsigned int length);
                                       // Clears <length> bytes starting at
                                       // <address>; uses memory at <scratch>
                                       // for temporary storage;
unsigned char MMC_FLASH_Clear (unsigned long address, unsigned char *scratch,
                                       // Writes <length> bytes of data at
                                       // <wdata> to <address> in MMC;
                                       // <scratch> provides temporary storage;
unsigned char MMC_FLASH_Write (unsigned long address, unsigned char *scratch,
                          unsigned char *wdata, unsigned int length);
                                       // Clears <length> bytes of FLASH
                                       // starting at <address1>; Requires that
23
                                       // desired erase area be sector aligned;
24
unsigned char MMC_FLASH_MassErase (unsigned long address1,
25
                                   unsigned long length);
und zwar an dieser stelle mit @ gekennzeichnet
   idata unsigned long flash_page_1;   // Stores address of first FLASH page;
   idata unsigned long flash_page_2;   // Stores address of second FLASH page;
   idata unsigned int card_status;     // Stores MMC status after each MMC
                                       // command;
   idata unsigned int counter;         // Counter for clearing bytes in local
                                       // block copy;
   unsigned char xdata *index;         // Index into local block used for
                                       // clearing desired data;
   if(length > 512) return 0;          // Test desired clear length;  If
                                       // length > 512, break out and return
                                       // zero;
                                       // Calculate first FLASH page address;
   flash_page_1 = address & ~(PHYSICAL_BLOCK_SIZE-1);
                                       // Calculate second FLASH page address;
   flash_page_2 = (address+length-1) & ~(PHYSICAL_BLOCK_SIZE-1);
   if(flash_page_1 == flash_page_2)    // Clear space all in one FLASH block
   {                                   // condition;
                                       // Read first FLASH block;
      card_status = MMC_Command_Exec(SET_BLOCKLEN,
23
                                 (unsigned long)PHYSICAL_BLOCK_SIZE,
24
                                 EMPTY);
25
      card_status = MMC_Command_Exec(READ_SINGLE_BLOCK,flash_page_1,scratch);
26
                                       // Set index to address of area to clear
27
                                       // in local block;
28
    @@  index = (unsigned int)(address % PHYSICAL_BLOCK_SIZE) + scratch;
29
      counter = 0;
30
      while(counter<length)            // Clear desired area in local block;
31
32
         *index++ = 0x00;
33
         counter++;
34
35
                                       // Tag first FLASH page for erase;
36
      card_status = MMC_Command_Exec(TAG_SECTOR_START,flash_page_1,EMPTY);
37
      card_status = MMC_Command_Exec(TAG_SECTOR_END,flash_page_1,EMPTY);
38
                                       // Erase first FLASH page;
39
      card_status = MMC_Command_Exec(ERASE,EMPTY,EMPTY);
40
                                       // Write local copy of block back out
41
                                       // to MMC;
42
      card_status = MMC_Command_Exec(WRITE_BLOCK,flash_page_1,scratch);
43
44
   else                                // Clear space crosses FLASH block
45
   {                                   // boundaries condition;
46
                                       // Follow same procedure as for single
47
                                       // block case above;  Read first block
48
                                       // clear data from start address to end
49
                                       // of block;  Erase block in FLASH;
50
                                       // Write local copy back out;
51
52
53
                                 EMPTY);
54
55
56
      counter = (unsigned int)(flash_page_2 - address);
57
      while(counter > 0)
58
59
         *index++ = 0xFF;
60
         counter--;
61
62
63
64
65
                                       // Same process as above, but using
66
                                       // second FLASH block;  Area to be
67
                                       // cleared extends from beginning of
68
                                       // second FLASH block to end of desired
69
                                       // clear area;
70
      card_status = MMC_Command_Exec(READ_SINGLE_BLOCK,flash_page_2,scratch);
71
   @@   index = scratch;
72
      counter = (unsigned int)(length - (flash_page_2 - address));
73
      while(counter > 0)
74
75
         *index++ = 0xFF;
76
         counter--;
77
78
      card_status = MMC_Command_Exec(TAG_SECTOR_END,flash_page_2,EMPTY);
79
80
      card_status = MMC_Command_Exec(WRITE_BLOCK,flash_page_2,scratch);
81
82
für die hilfe vielen dank im voraus
