Error 61 Lable not found
Gast #2555971
Guten Abend,
bin gerade dabei mein externes Sram an einem ATmega 32 anzusteuern aber
ich
habe arge Probleme mit den Unterprogrammen ich hab mich schon auf den
Kopf gestellt aber ich versteh nicht warum der Kompiler den Fehler Label
not found
ausgibt vll könnt ihr meinen fehler erkennen.
Mfg Thomas I.
$regfile = "m32def.dat"
$crystal = 16000000
$hwstack = 50
$swstack = 50
$framesize = 80
$baud = 19200
'Sram Adresse
Config Porta = Output
'Sram Port
Config Portc = Output
'Latch Pin
Config Portb.0 = Output
'Befehlspins
Config Portb = Output
Config Portd.4 = Output
Config Portd.5 = Output
Config Portd.6 = Output
Config Portd.7 = Output
Latchpin Alias Portb.0
Chipselect Alias Portb.3
Sramout Alias Portb.2
Sramwrite Alias Portb.1
Declare Sub Wbyte(byval Var As Byte , Byval Adresse As Word)
Declare Function Rbyte(byval Adresse As Word) As Byte
Dim Zahler As Word
Dim Bufferbyte As Byte
Dim Taste As Byte
Print "S-ram Programm"
Print "Weiter mit Taste"
Taste = Waitkey()
Do
   Bufferbyte = 1
   For Zahler = 1 To 100
      Gosub Wbyte(bufferbyte , Zahler)
      Bufferbyte = Bufferbyte + 2
   Next
Print "Gespeichert"
Wait 1
Print "Lesen"
      Bufferbyte = Rbyte(zahler)
      Print Bufferbyte
      Waitms 200
   Next
Print "Gelesen"
Taste = Waitkey()
Loop
End
Local Hnibble As Byte
Local Lnibble As Byte
Latchpin = 0
Chipselect = 0
Sramout = 1
Sramwrite = 1
Lnibble = Lnibble + Adresse
Shift Adresse , Right , 8
Hnibble = Hnibble + Adresse
Porta = Lnibble
Latchpin = 1
Porta = Hnibble
Portc = Var
Sramwrite = 0
Sramwrite = 1
End Sub
Config Portc = Input
Latchpin = 0
Chipselect = 0
Sramout = 1
Sramwrite = 1
Porta = Lnibble
Latchpin = 1
Porta = Hnibble
Sramout = 0
End Function
