Wer von Euch sucht Elektronikbauteile
OP #2699920
Anbei ein Auszug meiner zu verkaufenden Bauteile:
Stückz.  Bezeichnung
4  MAX274BCNG       4th- And 8th-Order, Continuous-time Active Filters
95  MAX274BENG  4th- And 8th-Order, Continuous-time Active Filters
34  MAX481EPA  Low-Power / Slew-Rate-Limited RS-485/RS-422 Transc.
10  MAX483CSA  TXRX RS485/RS422
15  MAX691CWE  Microprozessor Supervisory Circuits
5  MAX691ACSE  Microprozessor Supervisory Circuits
17  MAX220CSE  5V-Powered, Multichannel RS-232 Drivers/Receivers
12  MAX743EPE  Dual Output, Switch-mode Regulator
18  MAX8211CPA  Microprocessor Voltage Monitors with Program. Volt.
Detec.
8  MAX874EPA  Low-Dropout, Precision Voltage Reference
3  MAX707CSA  Low-Cost, uP Supervisory Circuits
12  MAX707EPA  Low-Cost, uP Supervisory Circuits
3  AD7528JN  CMOS Dual 8 Bit buffered multiplaying DAC
6  A7543KN  12-BIT DAC
4  AD582KD  Low Cost Sample/Hold Amplifier
14  AD536AKD  True RMS-to-DC Converter
11  AD521JD  IC AMP INST 40MHZ PREC LN
18  AD524BD  Precision Instrumentation Amplifier
6  AD624BD  Precision Instrumentation Amplifier
12  SAB80C535-N T40/85  High-Performance 8-Bit Single Chip
Microcontroller
1  AM8085APC  CMOS single-chip 8-bit microcontroller
2  M80C85A-OKI  CMOS single-chip 8-bit microcontroller
4  M80C85A-2-OKI  CMOS single-chip 8-bit microcontroller
9  D80C85A-OKI  CMOS single-chip 8-bit microcontroller
2  D8085AHC-2 NEC  CMOS single-chip 8-bit microcontroller
2  D8085AH-2 Intel  CMOS single-chip 8-bit microcontroller
6  M5L8085AP  CMOS single-chip 8-bit microcontroller
3  D80287-6  Arithmetic Coprocessor
7  PCB80C552-5-16WP  CMOS single-chip 8-bit microcontroller
2  PC80C31BH DIL Intel  CMOS 8-BIT SINGLE-CHIP MICROCOMPUTER
44  TMP80C35AP-6  CMOS 8-BIT SINGLE-CHIP MICROCOMPUTER
2  P8035L  CMOS 8-BIT SINGLE-CHIP MICROCOMPUTER
3  DP8212N National  Dil  8-Bit Input/Output Port
6  PB8224 NEC  CLOCK GENERATOR AND DRIVER FOR 8080A CPU
8  M81C55  CMOS Static RAM with I/O Ports and Timer
1  TMP82C37AP-5  CMOS High Performance Programmable DMA Controller
1  D82C37AC-5  CMOS High Performance Programmable DMA Controller
35  M82C51A  UNIVERSAL SYNCHRONOUS ASYNCHRONOUS RECEIVER TRANSMITTER
8  M5L8251AP-5  UNIVERSAL SYNCHRONOUS ASYNCHRONOUS RECEIVER TRANSMITTER
3  M82C51A-2 OKI Dil  UNIVERSAL SYNCHRONOUS ASYNCHRONOUS RECEIVER
TRANSMITTER
8  D8251 AFC   NEC Dip  PROGRAMMABLE COMMUNICATIONS INTERFACE
6  D8251AC  PROGRAMMABLE COMMUNICATIONS INTERFACE
13  M8253C-2  Programmable Interval Timer - NEC
2  D82C52-5  Programmable Interval Timer - NEC
1  P8253-5  Programmable Interval Timer - NEC
2  D8255AC-2 NEC  CHMOS PROGRAMMABLE PERIPHERAL INTERFACE
5  SAB8256A-P Dil  UART-USART Circuit - MUART,3 MHz System Clock
4  SAB8256A-C Dil  UART-USART Circuit - MUART,3 MHz System Clock
4  P8257-5  PROGRAMMABLE DMA CONTROLLER
1  D8259AC-2  PROGRAMMABLE INTERRUPT CONTROLLER
13  P82530-6 Intel Dip  Serial Communications Controller
8  PIC16C57-XT/SO   8-bit microcontroller
5  ADC0848CCJ  8-Bit Microprocessor Compatible A/D Converter with
Multiplexer (-40/+80)
14  UCN5818AF  BiMOS II 32-BIT SERIAL-INPUT, LATCHED SOURCE DRIVERS WITH
ACTIVE-DMOS PULL-DOWNS
9  IMSC011-P20S  Inmos Dil  Link-Adapter
20  HM3E-65728BN-5 (Matra Har.)  2K × 8 High Speed CMOS SRAM
35  M6927 OKI Dil-Geh.  1200 bps Single Chip FSK MODEM
55  SDA2121-2X  PLL with I2C bus for AM/FM receivers
18  PZ5032I10A44  Electrically-Erasable Complex PLD
