ISE 10.1 does not reload the user constraints file
Gast #2965834
Hei,
I have to use ISE 10.1 because I have a spartan2 design (must be 5V
tolerant).
If I create a new project and add a user constraints file with some
pins, and then I delete some pins (not yet used) the mapper complains
that the pins I deleted from the ucf are unconnected. As if the pins
were still there.
Choosing clean all project files and re-run all does not solve the
problem...
Any ideas ?
ps: I am planning on using the command line tools if I can avoid this
problem.
Any tips are welcome.
  • [vhdl]VHDL-Code[/vhdl]
