Veditor "file not found, check filecase"-error
Gast #3073908
since changing from veditor 0.7 and Windows XP to veditor 1.1 and
Windows 7 I have a problem.
The situation is the following: There are two projects, one with the
make.exe in it and linked to the other project, which contains the vhd
source. Now when I have an error which is not found by the veditor
parser (e.g. writting st_ulogic instead of std_ulogic) the external
compiler gives an error. The veditor error parser catches this error but
is unable to map it onto the sourcefile and reports a missing file (
"... is not found in the project. MS Windows users, check filename
case!!!").
I also tried it with veditor 0.7 and I got the same error. Of course I
compared the filename, everything seems to be fine and as it says
filename case I tried it with everything written in lower case (apart
from the drives name).
When everything is in the same project it works fine but it would be
preferable to have it split in two projects.
Do you have any idea how to solve this issue?
Regards,
Max
  • [vhdl]VHDL-Code[/vhdl]
