Altera Avalon MM Read Master Template: max transfer length of 20 bytes?
Gast #3083719
Hi everyone,
I have sucessfully integrated the Altera Avalon MM Read Master template.
However, this only works properly up to the length of 20. (word size is
32 bit)
When I define the transfer length to be 24, i.e. 6 words, then there are
only 5 dataavailable assertions with 5 buffered data. What I find
interesting is, that the signal early_done does get asserted, meaning
the last read is actually posted, but the signal done is never asserted,
so somehow the result cannot be returned.
I already used a FIFO of size 64, so should be big enough I think.
Is this a known issue? Or anyone an idea what the problem could be?
Best regards,
Jimmy
  • [vhdl]VHDL-Code[/vhdl]
