STM32F4 wakeup Interrupt
OP #3767537
bin gerade echt am verzweifeln.
Ich versuche mit der RTC und dem Wakeup register einen 128Hz Interrupt
zu erzeugen. Für die RTC wird der interne (ungenaue) Quarz verwendet,
für die aktuellen testzwecke reicht das aus.
void init()
    /* Enable the PWR clock */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
    /* Allow access to RTC */
    PWR_BackupAccessCmd(ENABLE);
    /* Enable the LSI OSC */
    RCC_LSICmd(ENABLE);
    /* Wait till LSI is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET)
    /* Select the RTC Clock Source */
    RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);
    /* Configure the RTC data register and RTC prescaler */
    RTC_InitTypeDef RTC_InitStructure;
23
    RTC_InitStructure.RTC_AsynchPrediv = 0x7F; // prescaler set to optain a 1 Hz signal of the 32kHz LSI
24
    RTC_InitStructure.RTC_SynchPrediv = 0xFF; // prescaler set to optain a 1 Hz signal of the 32kHz LSI
25
    RTC_InitStructure.RTC_HourFormat = RTC_HourFormat_24;
26
27
    /* Check on RTC init */
28
    if (RTC_Init(&RTC_InitStructure) == ERROR)
29
30
        return;
31
32
33
    /* Enable the RTC Clock */
34
    RCC_RTCCLKCmd(ENABLE);
35
36
    /* Wait for RTC APB registers synchronisation */
37
    RTC_WaitForSynchro();
38
39
    rtc_InitWakeUpInterrupt(16);
40
41
42
43
void rtc_InitWakeUpInterrupt(uint8_t wakeUpCounter)
44
45
    NVIC_InitTypeDef NVIC_InitStructure;
46
    EXTI_InitTypeDef  EXTI_InitStructure;
47
48
    // NVIC init
49
    NVIC_InitStructure.NVIC_IRQChannel = RTC_WKUP_IRQn;
50
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
51
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
52
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
53
    NVIC_Init(&NVIC_InitStructure);
54
55
    // ext Interrupt 22 einstellen (fuer WakeUp)
56
    EXTI_ClearITPendingBit(EXTI_Line22);
57
    EXTI_InitStructure.EXTI_Line = EXTI_Line22;
58
    EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
59
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
60
    EXTI_InitStructure.EXTI_LineCmd = ENABLE;
61
    EXTI_Init(&EXTI_InitStructure);
62
63
    // zum einstellen muss Wakup disabled sein
64
    RTC_WakeUpCmd(DISABLE);
65
66
    // Teiler 16 => 32,768kHz:16 => 2048 Hz
67
    RTC_WakeUpClockConfig(RTC_WakeUpClock_RTCCLK_Div16);
68
    // WakeUp Counter einstellen
69
    RTC_SetWakeUpCounter(wakeUpCounter); //set to 16 -> 128 interrupts per second (32768Hz / Div16 = 2048; 2048 / 128 = 16
70
71
    // enable Interrupt
72
    RTC_ITConfig(RTC_IT_WUT, ENABLE);
73
74
    // enable Wakeup
75
    RTC_WakeUpCmd(ENABLE);
76
77
78
void RTC_WKUP_IRQHandler(void)
79
80
    if(RTC_GetITStatus(RTC_IT_WUT) != RESET)
81
82
        // Interrupt Flags loeschen
83
84
        RTC_ClearITPendingBit(RTC_IT_WUT);
85
86
87
        doSomething();
88
89
90
ich nutze das aktuelle emBlocks als IDE und den mitgelieferten GCC
bei dem code oben wird RTC_WKUP_IRQHandler gar nicht aufgerufen.
wenn ich ein "RTC_ClearITPendingBit(RTC_IT_WUT);" ans ende der
"rtc_InitWakeUpInterrupt" funktion setze wird auch nicht meine
RTC_WKUP_IRQHandler funktion aufgerufen sondern nur noch die im
startup_stm32f4yy.S definierte "def_irq_handler    RTC_WKUP_IRQHandler
", dort wird aber kein Interrupt flag zurückgesetz und somit bleibt er
auf ewig da hängen.
ich wäre für jeden hilfreichen tip sehr dankbar
