SPI RAM Chip mit eingebautem Video Controller
OP #4052590
Gerade auf der VLSI Website entdeckt.
VS23S010C-L
Ein SPI/Parallel RAM Chip mit eingebautem PAL/NTSC Video Controller.
Samples und komplettes Datenblatt scheint es schon zu geben.
Sowas wollte ich schon immer haben :)
Die Grafikeinheit ist frei programmierbar was Auflösung und
Farbtiefe betrifft. Natürlich durch die 128K RAM begrenzt.
http://www.vlsi.fi/en/products/vs23s010.html
Features
Flexible 1.5V - 3.6V operating voltage
131,072 x 8-bit SRAM organization
Available in two packages
VS23S010C-L: LQFP48 7x7mm
VS23S010C-S: Narrow SOIC8, 150 mils wide
Serial Peripheral Interface (SPI) compatible
Byte, Page, and Sequential modes
Supports Single, Dual and Quad input read and write
Fast operation: the whole memory can be filled or read in 262176 cycles
(Quad-I/O SPI)
XHOLD and XWP pins
8-bit Parallel Interface (Simplified 8080 and NAND FLASH Type Interface,
VS23S010C-L only)
Sequential read and write in 4-byte blocks
Fast operation, the whole memory can be filled in 131076 cycles and read
in 131077 cycles
Integrated video display controller (VS23S010C-L only)
Supports NTSC and PAL composite video formats
NTSC requires 3.58 or 28.64 MHz (8x colour carrier) crystal / clock
input
PAL requires 4.43 or 35.47 MHz (8x colour carrier) crystal / clock input
Fully configurable by user
9-bit Video DAC and 8x video PLL
High operating frequencies
Up to 36 MHz for SPI
Over 35 MHz for Video Display Controller
15 MHz for 8-bit parallel interface (VS23S010C-L only)
Low-power CMOS technology
Read current 200 µA at 1 MHz (Single I/O, SO=0, TA=+85°C, VDD=3.3V)
Industrial temperature range from -40°C to +85°C
Pb-Free and RoHS compliant package
Availability
