Failed to process makespec for platform 'devices/linux-rasp-pi2-g++'
OP #4464458
Hallo everybody, I tried to cross compile Qt for pi2 by follow this
tutorial http://visualgdb.com/tutorials/raspberry/qt/embedded/
but never succed. now i try this tutorials
(https://wiki.qt.io/RaspberryPi2EGLFS)
configuration:
./configure -release -opengl es2 -device linux-rasp-pi2-g++
-device-option
CROSS_COMPILE=~/raspi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-r
aspbian/bin/arm-linux-gnueabihf-  -sysroot ~/raspi/sysroot -opensource
-confirm-license -make libs -prefix /usr/local/qt5pi -extprefix
~/raspi/qt5pi -hostprefix ~/raspi/qt5 -v
i got this error by the configuration
Project ERROR: Compiler
/home/raspberry/raspi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-r
aspian/bin/arm-linux-gnnueabihf-g++  not found. Check the value of
CROSS_COMPILE -device-option
Could not read qmake configuration file
/home/raspberry/raspi/qtbase/mkspecs/devices/linux-rasp-pi2-g++/qmake.co
nf.
Error processing project file: /dev/null
OP
soweit habe ich den fehler gelöst lag bei einer schreibfehler in der
configuration.Jedoch habe ich folgende Fehler nach Aüsführung von dem
make
aspbian/bin/../lib/gcc/arm-linux-gnueabihf/4.8.3/../../../../arm-linux-g
nueabihf/bin/ld.gold:  error: cannot open
/home/raspberry/raspi/sysroot/usr/lib/arm-linux-gnueabihf/libz.so: Datei
oder Verzeichnis nicht gefunden
/home/raspberry/raspi/sysroot/usr/lib/arm-linux-gnueabihf/libglib-2.0.so
:  Datei oder Verzeichnis nicht gefunden
/home/raspberry/raspi/sysroot/usr/lib/arm-linux-gnueabihf/librt.so:
/home/raspberry/raspi/sysroot/usr/lib/arm-linux-gnueabihf/libm.so: Datei
Makefile:1210: recipe for target '../../lib/libQt5Core.so.5.6.0' failed
make[2]: *** [../../lib/libQt5Core.so.5.6.0] Error 1
make[2]: Leaving directory '/home/raspberry/raspi/qtbase/src/corelib'
Makefile:194: recipe for target 'sub-corelib-make_first' failed
make[1]: *** [sub-corelib-make_first] Error 2
make[1]: Leaving directory '/home/raspberry/raspi/qtbase/src'
Makefile:45: recipe for target 'sub-src-make_first' failed
make: *** [sub-src-make_first] Error 2
